From Logitech's website, "This is normal behavior of the mouse.
The green battery light of your ]logitech] mouse will come on for a few seconds to indicate the battery condition and then go out. This will occur when you power on your mouse and when you replace the batteries. The battery light goes out after a few seconds to conserve battery power."
For changing the batteries of logitech wireless.I guess a video tutorial will help you out rather than written instructions. Watch it to lean how to replace battery of the logitech cordless mouse ( Logitech MX 1000 Model). If you are having a different model please specify the details of your model.
hi marlys, i am happy to assist , Ya its not too easy to replace battery in logitech cordless mouse,in the back of mouse, you have mouse pad just remove it , you can see they provision to remove the mouse, there been Four screws been inside that mouse pad, But before going to open your mouse just check you have new battery with you, if you connt find in any shops just go to eBay , you can get it thee, If you mansion the excate model name of your mouse mean i will send video for that particular model itself , no issue just check out this video
Hi there as per my logitech mouse the battery removing place is just below the mouse. You can see a arroe sign near in the mouse sencer light. Just unlock & the battery will came out. Thanks & waiting for your feedback.
Hello. Yes, it is quite simple to remove the battery of a Logitech MX Revolution mouse yet for some reason when going through the Logitech product support website it states that it is not possible. Just remove the 4 teflon pads located on the bottom of the mouse and then remove the four screws located under the pads. Once this is done turn the mouse back upright and remove the top off of the mouse. I would suggest temporarily removing the flex cable that holds the top and bottom of the mouse together. There is a small metal clip that holds the battery in place that must now be removed. NOW FOR THE VERY IMPORTANT PART. There are two different generations of the Logitech MX Revolution mouse which have different batteries. The first Generation uses the L-LY11 battery and the newer generation of the MX Revolution uses the L-LL11 battery. There is no way to tell which battery your mouse uses without first opening up the mouse. Once opened you can easily tell which battery your mouse uses. Here is a link to a site that shows you an example of the L-LY11 battery: MX Revolution L-LY11 Battery Here is a link to a site that shows you an example of the L-LL11 battery: L-LL11 Battery for Logitech MX Revolution Mouse As you can see the L-LY11 battery has wires and a plastic connector and the L-LL11 battery has contacts. You should definitely determine which battery your mouse uses ahead of time to eliminate any frustration caused by ordering the wrong battery ahead of time.
the black section on the top of the mouse with the logitech symbol.
Hold the mouse and firmly but gently slide the black cover away from you , underneath are 2 aaa batteries
check the connections at the battery you might have to bend the silver tab closer to the battery or stick a little aluminum foil to the battery as you put it in
