Question about Kenmore Top Freezer Refrigerator
The ice maker backed up and put extra ice on the back of the freezer causing ice tray to stick out and freezer did not close. Pulled extra ice out and closed freezer but freezer is working (2-3 days the ice cream was not frozen, some other food frozen some not. Refrigerator is at 50 to 52 degrees for last 2 days, milk went bad..
  • Kenmore Master
  • 3,740 Answers
Hi and wlecome to FixYa, I am Kelly. You really have 2 problems.... 1 the inlet water valve has failed causing the water in the ice tray. The only remedy for this is to replace the inlet water valve. If you can squeeze the rubber fill tube at the back of the icemaker and it is / was frozen solid the inlet water valve is for sure bad.
Turn off the water supply to the ice maker until the water valve is replaced or the current problems you have WILL repeat.
The other problem you have is due to the door being open the evaporator coils iced up big time and the normal defrosting process is not removing all of the ice. Unplug the unit and direct a fan into the freezer compartment for just over 2 hours with the freezer contents removed. While the unit is manually defrosting... open the back of the unit by removing the lower fiberboard cover and clean the condensor coils and fan along with the drip pan / tray.
After 2 hours clean up the water mess and return the unit to normal service. It should work just fine.
Thanks for choosing FixYa,
Kelly
Posted on May 25, 2011
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
I have a GE Profile pfss6pkx. The ice maker has stopped making ice and makes a clicking sound. Do I need a new ice maker or is there something I should try first?
Hello Dave;
My name is Peter. I am a retired field service refrigeration technician.
1.) Press the test button while hold the bottom freeze light switch in. The light switch is in the front top part of the freezer. Observe what happens.
2.) Your ice maker will not work if unless you reach temperature. look in the back of your freezer wall. Is there frost or ice build up?
3.) Do you have ice on the bottom of your freezer section? Then you have a frozen drain, ice built up and can not reach desired temperature.
4.0 You have a non repairable ice maker. Sometime these flex types become jammed with a ice cube in the mold. Check this out.
5.) Your ice maker has a sensor. This may be bad, but I do not think this is the problem.
Get back to me on what you find from the above.
Jan 16, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
Refrigerator: GE model GT22KCPCRCC New ice maker: GE model WR30X10093 Problem: with old ice maker installed, ice tray was over filling with water causing ice blocks in ice bucket, freezer and into the...
What your describing sounds to me like a classic case of the water valve sticking open, as you have stated and replacing it will resolve your problem.
Gene
Jul 31, 2011 | GE Refrigerators
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Ice maker is making ice cubes AND pouring water
the apparatus that distributes the water into the tray had been knocked out of balance when taking the tray out. We pulled the ice maker and replaced the apparatus back in it's proper location .
Aug 07, 2009 | Freezers
My old whirlpool refrig. with frostless freezer on top model # ET20DKXSN 00 has started to form frost in the back of the freezer where the ice cube trays are stored. It seems to be coming from the around...
check the back of the refrigerwtor there shpoould be a opening where the water goe into the freezer for the ice maker. you need to seal it up so that the moiust air from outside does not enter the freezer.
Feb 24, 2009 | Refrigerators
Magic Chef Side by Side MOdel RC224RDA
I have the same problem. It turned out to be a problem with the doors. When my kids go to get a snack and close the fridge door (read slam the door) the air pressure pops the seal open on the freezer door causing the ice cubes to begin melting. The bottom items stay frozen (warm air rises). It took me a long time to work this out.
Remove the ice maker tray. Remove the ice blob, being careful to put the u-shaped wire ice-level sensing wire thing, in the up position or the system will dump ice and water all over the freezer. Put all back clean and dry and buy a velcro adhesive strip and install it on top of the freezer door to prevent the door from always blowing open.
Hope this helps
Jul 03, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
Water freezing on the tray section under the freezer drawer.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 15, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Ice Maker Not Making Ice
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
Nov 01, 2007 | Frigidaire 20.6 cu. ft. Top Freezer...
Kenmore Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
