Question about Texas Instruments TI-30XA Calculator
How do i get 2nd ans - Texas Instruments TI-30XA Calculator
  • Texas Instru... Master
  • 7,993 Answers
The ANS variable stores the last result calculated and displayed. Examine the calculator looking for a key on top of which is marked ANS. If that does not exist, look for a key near which is marked on the body of the calculator ANS. In the last case, you access the last result by pressing the key sequence 2nd followed by the key that has the marking.
Posted on May 25, 2011
Can only select 1st neutral an 2nd gear
Hi Meihana and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. Shift lever is loose on the shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
http://pnwriders.com/threads/r1-wont-shift-past-2nd-gear.169723
Can shift above 2nd gear
Wont shift past 2nd gear
Shifting stuck won go past 2nd gear
Apr 06, 2016 | Motorcycles
Exponent function keys
Which exponent function?
To enter an exponent of ten, use 2nd [EE].
To raise ten to an exponent, use 2nd [10^x].
To raise e to an exponent, use 2nd [e^x].
To raise an arbitrary number to an exponent, use ^.
Feb 23, 2012 | Texas Instruments TI-84 Plus Calculator
How do I convert DMS to DD with a ti84 plus?
To enter an angle in DMS format, enter the number of degrees, 2ND [ANGLE] 1 to indicate degrees, enter the number of minutes, 2ND [ANGLE] 2 to indicate minutes, enter the number of seconds, ALPHA ["], then ENTER.
ANGLE is on the APPS key, " is on the + key.
You can convert an angle from decimal to DMS with the ->DMS command, 2ND [ANGLE] 4
Jan 10, 2011 | Office Equipment & Supplies
How to convert Pressures on a TI-89?
The same way you convert any other units other than temperature, using the Units menu (2ND 3) and the -> operator (2ND MODE).
As an example, to convert 1.1 atmospheres to mm of mercury:
1.1 2ND 3 2ND Down Down Down Down Down  ENTER 2ND MODE 2ND 3 2ND Down Down Down Down Down Right Down Down Down Down Down ENTER ENTER
You should see 836. _mmHg
Feb 17, 2010 | Texas Instruments TI-89 Calculator
How to do nPr or nCr on TI-30x Solar (scientific calc.)
If you have an older version on the TI30x Solar (not TI30Xa or newer) then you must use a different key sequence for nPr/nCr.
52 [2nd][x/y] 5 [2nd][nCr] gives 2598960 (the x/y button is above the Pi symbol on my version).
8 [2nd][x/y] 3 [2nd][nPr] gives 336
This took me forever to find out, so hopefully it will help someone!
Jan 27, 2010 | Texas Instruments TI-84 Plus Silver...
How to find area between 2 curves
The TI84Plus has a Shade( function which allows you to represent the area you want to calculate.
The simplest syntax of the command is
Shade( lower_function, upper_function, Xleft, Xright, pattern, patern_resol) where Xleft is the left limit, Xright is the right limit, pattern is the shading pattern and pattern_resol is the resolution of the shading. Only the area where lower_function is less than upper_function is shaded. Unfortunately this command does give the value of the shaded area.
To find the area between two curves
  1. Draw the curves
  2. Find the left intersection point using [2nd][CALC][5:intersect]. Sorry I will not describe the procedure. The X value of the intersection point is stored in Ans memory.
  3. Press [2nd][QUIT] to go to main calculator screen.
  4. Store the Ans result in say A: [2nd][Ans][STO->][ALPHA] A
  5. Return to the graph by pressing [GRAPH].
  6. Find a second intersection point. Result is stored in Ans memory.
  7. Press [2nd][Quit] to return to main calculator screen
  8. Press [2nd][Ans][STO->][ALPHA] B to store the X value of the second intersection point in B.
  9. Use the CATALOG to paste the fnInt( command to calculate the integral : [2nd][CATALOG][[APLHA] F and scroll to select fnInt( and press [ENTER]
  10. To complete the command you need the identifiers Y1 and Y2.. You access the identifiers Y1 and Y2 by pressing [VARS][Y-VARS][1:Function][1:Y1] and [VARS][Y-VARS][1:Function][2:Y2]
  11. The command should appear as fnInt( Y2-Y1,A,B)
  12. Press [ENTER] to obtain your value.
Hope it helps.
Thank you for using FixYa.
Do not forget to rate the solution.
Dec 03, 2009 | Texas Instruments TI-83 Plus Calculator
Code PO732 2004 Ford Expedition
Trouble Code: P0732 (4.6L V8 VIN W Auto)
Incorrect Second Gear Ratio Print this code dataprint_icon_codes.gif Number of Trips to Set Code: 2
OBD II Monitor Type: CCM Details
Indicators: MIL Details
Trouble Code Conditions:
Engine started, vehicle operating with 2nd Gear commanded "on", and the PCM detected an incorrect 2nd gear ratio during the test.
Possible Causes:
  • 2nd Gear solenoid harness connector not properly seated
  • 2nd Gear solenoid signal shorted to ground, or open
  • 2nd Gear solenoid wring harness connector is damaged
  • 2nd Gear solenoid is damaged or not properly installed
Refer to the mechanical section to diagnose transmission concerns
Trouble Code: P0732 (5.4L V8 VIN L Auto)
Possible Causes:
Refer to the mechanical section to diagnose transmission concerns.
Oct 26, 2009 | 2004 Ford Expedition
Help with puzzle 100 seven squares
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 28, 2008 | Nintendo Professor Layton & the Curious...
Cant solve puzzle 100 in professor layton cant go on im desperate
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
Auto transmission not smooth 1st to 2nd
Admitting a lack of familiarity with your car, this is often caused by an improper adjustment of the transition point from one gear (or clutch) to another.
1st is still not disengaged when 2nd is engaging but this is normally an adjustable point.
I've also seen this caused by the use (or adding) of the wrong fluid; the beasts are fussy about that sometimes.
Jun 19, 2008 | 1990 Mazda MX-5
Texas Instruments TI-30XA Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
