Question about GE APH10AA Air Conditioner
GE model #APE07AHM1...Unit will not come on...vent open...no memory showing on unit, only has memory showing on the remote...fan turns freely...help, please
2 Suggested Answers
SOURCE: E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Posted on Jul 27, 2010
GE APE07AHM1 Won't Run
This unit has a famous problem with the control panel. Try to use the remote to turn it on, instead of the panel. I had the same problem.
Jul 18, 2013 | GE APH10AA Air Conditioner
GE microwave fan turns on when door opened
The problem is caused by one or two bad door switches.
Apr 27, 2012 | Microwave Ovens
Fan outside is blowing but nothing comming out of vents
Without knowing more information here are some quick checks. First check the return
vent and filter to see if it is blocked or clogged as well as the vents to see if they are open as well. I have seen filters in two locations in one home.
Second, if your thermostat has a "FAN"
setting, then try this and see if anything happens. If not then several things control the
fan itself. The fan relay, and the limits inside the unit.
The fan should turn freely by hand WITH ALL POWER OFF TO UNIT FROM ALL SOURCES.
If it is hot then chances are it has failed, If it is cool but turns freely by hand then I would
suggest replacing the capacitor first if there are no obvious broken wires or such.
Discharge cap to chassis and replace only with exact microfarad (MFD) ane equal or higher voltage.
Feb 26, 2011 | Heating & Cooling
My ge ac model APE07AHM1 is not blowing cold air. What could be the problem?
This is an old question, but I am having the same problem with APE07AHM1 that I bought second hand. I'd like to recharge it.
The answer by binev_78 seems to be for outdoor AC compressor units but this is a portable stand alone unit, no outdoor unit.
Aug 30, 2009 | GE APH10AA Air Conditioner
Stainless steel GE XL 1800 spacemaker works ok except the vent fan doesn"t come on when cooking, which gets to hot and shuts off. The fans work when you push the vent fan buttons and the vent covers...
So the fan motor's 21VAC winding is working. That's good.
But either the fan blade is loose on the shaft (a super glue fix) or the fan motor itself had failed.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
The fan motor is shown on the diagram there as reference # 78, part # AP3192806, located behind the control panel and adjacent to the magnetron.
I'm not sure you have to pull the oven from the wall to replace it, but if you do, the oven installation (& removal) instructions are included on the tech sheet inside the unit.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel, and it is very helpful when troubleshooting, testing, and locating components.
You can also download GE owner's manuals and installation instructions here.
If you don't find yours I can send you a copy, or if you need more help, feel free to contact me directly (and please remind me of your full model number from the tag on the unit).
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Jul 12, 2009 | GE APH10AA Air Conditioner
System does not blow cold air, what refrigirant should be used and how to refill it ge room air conditioner model ape07ahm1
if you have a look at the outdoor unit there will be a label with the gas charge and type of gas,usually to charge the system with fresh gas you need to **** the old one out,evac. the coils and charge
Jun 27, 2009 | GE APH10AA Air Conditioner
Active vent keeps opening and closing though fan is off.
When the unit begins the never ending opening and closing cycle, turn the vent fan on for a few seconds and then turn the fan off. This seems to stop the active vent from opening and closing. If this is GE quality, this is the last thing that I am going to purchase. GE refrigerators are garbage and now I am having problems with a new microwave oven.
Apr 27, 2009 | General Electric PVM1870SMSS Microwave...
Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
Sep 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE APH10AA Air Conditioner Logo
118 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
