Question about Sony MDR-IF5000 Headphones
I'm experiencing a static noise whenever the headphones make the slightest movement. I think it may have to do with dust inside the unit. Any suggestions on repairs?
I found by spraying contact cleaner onto the switch and volume control the static went away on my MDR-IF5000 headphones
Posted on Dec 29, 2011
No Sound, Sound device not showing up on HP a1240n motherboard D33005
you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
cleaning your computer of dust using a fine air blower from a compressor making VERY sure that
there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD you might even remove the sound card to clean the socket dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jul 24, 2012 | HP Pavilion a1240n (EG136AA) PC Desktop
I have installed t sound driver.. but i can hear a constant sound whenever i use it and if i talk over t headfones even the other side who is hearing me can hear the noise also... how can i solve this??
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Feb 14, 2012 | Intel D915GAV Motherboard
I have a pioneer VSX 920 receiver that thinks i have headphones pluged in. I have no sound from the speakers and when trying to go in speaker related settings it displays: PHONESIN on the receiver. If I...
I think I just fixed a unit with the same problem. I opened the cover and found where the wire from the headphone jack plugs into a board just beside the power supply transformer. When removed, the unit appeared to select speakers as the output. Since the headphones are never used by the owner, I simply left the headphone cable unplugged. Unfortunately, I didn't have speakers to test it with but the unit appeared to be working correctly.
Sep 07, 2011 | Pioneer SX-315
When I turned on the power for my 'Logitech X-240' speakers, there was a loud static noise coming from the speakers. I unplugged the speakers from the subwoofer, and as I began to plug them back...
hope this helps
Aug 31, 2011 | Logitech X-240 Computer Speakers
Altec-Lansing VS-2120 speakers problem: Right speaker gives no sound, although computer checks out on other speakers, and headphone plugged into this speaker set works on both channels. Also get static...
try swapping the speakers around if the problem still persists either the speaker is faulty or
hope this helps you
Aug 30, 2011 | Computers & Internet
Dear Sirs! I have got Gigabyte GA-EP31-DS3L rev. 2.1 motherboard, with Intel Dual Core E2220 1M_800MHz CPU at 2.4 GHz; 2 pcs of 1 GB GEIL PC6400 800 MHz DDR2 RAM in VALUE KIT2 CL5; Samsung 500 GB 7200 RPM...
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 06, 2011 | Gigabyte (GA-EP31-DS3L) Motherboard
Im getting a wierd sound when i unplug my headphones what do i do
Open up your computer the speakers plug/outlet and the headphone plug is usually at the back of the computer
to check the lead attached to the rear of the input plugs make sure the connections are good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Mar 19, 2011 | Dell Audio Players & Recorders
I have static in the right ear of my headphones. They started doing this when only two weeks old. I have changed batteries, tried adjusting the sliding fit mechanism and everything else I could think of....
the static that you have on the headphones is probably because a loss connection or no floating ground- it means that should be a cable inside that isolate all the noise its probably loss if you can open them you should be able to see the cable its better to take it to a technician
Aug 19, 2010 | Audio Players & Recorders
Static noise in headphones over music
well dumby all you got to do is get some new headphones, it's like 10$ stupid
Jun 01, 2010 | AKG K 206 Consumer Headphones
Regardless of the audio source I connect my Bose QuietComfort 3 Headphones to, I can hear a small amount of static, especially at lower volumes. I have used another pair of headphones to test the devices...
Hello and Welcome to FixYa!
Yes Sir, as you have cross checked the audio so other possibilities have been ruled out, the only problem can be with your Head Phone unit, usually what happens is somewhere from inside the wire get cracked, or short resulting in noise or static, so the solution is to replace the wire, but the unit is a delicate thing so I'll never advice to D.I.Y.
I hope you have a clear picture now,
Regards, Waqar.
Oct 10, 2009 | Bose QuietComfort 2 Consumer Headphones
Sony MDR-IF5000 Headphones Logo
385 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
