Question about Huffy 26 in. Cranbrook Cruiser Bike
The coaster brakes are not working very well can the be adjusted or cleaned
Aseemble a coaster brake on a bicycle
Ken, Check the attached links,instruction and guides on removal and install coaster brake. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Coaster Hub Overhaul Pedal Brake Hub
How To Install Cog On Coaster Brake Hub
Bicycle Coaster Brake Repair and Service
Oct 01, 2014 | Husky 26"" x 2.125 Industrial Chrome...
How do you convert hand brakes to coaster brakes?
Hi Dan Sink
You will have to either replace the whole wheel with one that comes with a coaster brake or replace the center (drive) assemby and have the wheel re-spoked.
Bud
Sep 30, 2012 | Cycling
Coaster brake adjustment
These aren't really adjustable, but the parts that are wearing out are replaceable, and it involves disassembling the rear hub. Here is a link to a VERY thorough how-to guide, but this just covers one type of coaster brake. There are a couple of different styles, and if you have one of the older ones you can pretty much figure it out by taking it apart.
Here's the link--
http://www.troubleshooters.com/bicycles/1speed/1speed_overhaul.htm
good luck
Sep 12, 2012 | Schwinn Windwood 26 Women s Cruiser...
Coaster wireless remote not working.
I would suggest contacting Coaster directly: http://www.coasterfurniture.com/contactus.aspx
I know they have a 1 year limited warranty on all of their furniture. I believe you can submit a warranty claim through the retailer who sold you the adjustable bed. More details can be found here: http://www.coasterfurniture.com/current/warranty_2011.pdf
Aug 13, 2012 | Coaster 300131Q Adjustable Queen Size Bed...
How to adjust rear brakes on toyota coaster
There are usually two ways to go about adjusting the rear brakes, both involve getting the rear wheels off the ground on jack stands. Look for a small oval shaped rubber plug near the top on the brake backing plate where the brake line goes, there is a star adjuster wheel inside, with screwdriver rotate the wheel upward, there will be a clicking noise, ecah click tightens the brake, rotate the wheel while doing this until the wheel has a slight drag while rotating then stop. The other whay is to remove the wheel and the brake drum, then adjust the star adjuster a little at a time until the brake drums just fits over the brake shoes.
Nov 23, 2011 | Toyota Cars & Trucks
Is there a web site or other material i can get on the cranbrook beach cruiser what i need is a detailed explantion on removing and installing the rear hub with a coaster brake assembly
Yes, http://www.huffy.com/ is their website.
Should not be all that difficult but you will need a few different wrenches. One for the wheels axle nuts and one for the coaster brake assembly. All coaster brakes work the same, so any coaster brake manual will work. Your local shop can also show you how to remove and install the wheel.
Apr 01, 2011 | Huffy Cycling
Disassemble coaster brakes
You will need an adjustable wrench for removing the nuts on the axle.
To disassemble a coaster brake hub, do the following:
Loosen the nut on one end of the axle. All of the parts should then come out on one side of the hub shell.
Mar 02, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
Front brake pads are not resting on the rim
Getting hand-brakes adjusted correctly is often a challenge, but they are adjustable with the right size wrenches. On the other hand, a front hand-brake on a child's one-speed bike is not necessary and is only on the bike to give it sales-appeal. If this is a one-speed bike, then it has a coaster brake (operated by pushing the pedals backwards). Actually the coaster brake is much safer than a front hand brake anyway. If the child applies the coaster brake too heavily, they will just skid. If they apply the front brake too heavily, they will go over the handlebars. If the hand brake is not interfering with the front wheel and is just not very effective, I would just leave it as-is. If the brakes rub on the tire, you should adjust them so they don't rub the tire.
Jul 23, 2010 | Dynacraft 16" Boy's Wheels Bike
How to assemble back tire barrens and other parts pic of how inside parts go 20 inch huffy
I'm guessing this bike has a rear coaster brake. I really don't suggest overhauling a coaster brake hub and it is unlikely a diagram for your huffy exist but here is a link to a general coaster brake hub diagram. It should be very similar to what you are working on.
http://www.wtlw.net/ff/suntour/
Hope this helps!
Jul 18, 2009 | Huffy So Sweet Girls 20-Inch Bike
Huffy 26 in. Cranbrook Cruiser Bike Logo
48 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
