Question about Juster 3D-108 Computer Speakers
No sound in my juster 3D-108 superwoofer - Juster 3D-108 Computer Speakers
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 25, 2011
I'm running Windows 8. Do I need a driver for my Juster SP-660 Speakers?
Unless you already hear something from the speakers when you hooked them up, the answer is yes.
Mar 04, 2015 | Juster Multimedia Computer Speaker System...
I think the rocker switch has gone, as there is no resistance when I operate the switch, no red light & the speakers are dead. I have checked ths mains fuse which is OK. My JUSTer speakers have a...
There is a sprung piece of metal in the switch which sounds like it has snapped.After 12 years its no surprise. Try and get an RS Spares catalogue and you will probably find the switch in there.
good luck.
Jun 19, 2011 | Juster Computer Speakers
I need a driver for my Juster 3d-101 for windows 7 where or how can I get one?
why do you need a driver for your speakers? Have you no sound at all? Windows only needs drivers for the sound card not the speakers. Please explain what the problem is and make and model of sound card or computer
Apr 09, 2011 | Juster 3D-102 Computer Speakers
What is the power adapter needed for the Pro Juster 691Pa speaker system?
Computer Speakers Juster (External, Powered), (Adapter, 9V, -Outer, +Center) JusterDC-691PAYZNJ891701998
Aug 22, 2010 | Juster AC-691 Computer Speakers
What dc output voltage does it take for my juster 692p
From any port on a powered USB hub, you can draw up to 500 milliamps at 5 volts. This gives two and a half watts to play with; the peak draw of the SP-692p probably won't exceed two watts.
Hope this initial info/idea helps.
Let me know for any clarifications.
Apr 06, 2010 | Juster AC-691 Computer Speakers
Sound wont come out speakers
Not to sound like I am taking the pi**, but arae you sure you plugged into earphone/audio out????
Try using a pair of earphones you know work and if you get sound then the speakers could be faulty.
Nov 06, 2009 | Juster Computer Speakers
What kind of external power supply does the media speaker needs?
Juster-Avia 3D-107 Media speakers.
I wanted to know what kind of external power supply it needed. I open the case and saw 4 diodes which tells me is a bridge rectifier circuit. I also looked at the filter cap and saw ????uF at 28 volts. Therefor, I did the Scientific Wild *** Guess( A.K.A. SWAG METHOD)
12 volts AC out at 1.6 amps or higher.
Apr 28, 2009 | Juster 3D-102 Computer Speakers
Juster speakers 3D-503 no sound
the problem is that since u cleared off your hard drive you lost the drivers for the audio card so its not the speakers. you have to go to your computers manufacturer's website and go to help and support and get the driver for your system model's audio card if you tell me the model of your computer i will locste the driver for you and get you the direct link.
please rate me. thank you.
May 24, 2008 | Audio Players & Recorders
I NEED HELP
Please post the make / model number, and I will be glad to link you to the site to obtain the sound driver.
Jan 09, 2008 | Juster Computer Speakers
Sound not working
You can goto the manufacture web site for the speakers and download the latest device drivers and install them on your computer.
Oct 07, 2007 | Juster SP-692 Computer Speakers
Juster 3D-108 Computer Speakers Logo
73 people viewed this question
Top Juster Audio Players & Recorders Experts
Martin Murray
Victorman
Victorman
Vladimir Frolov
Are you a Juster Audio Player and Recorder Expert? Answer questions, earn points and help others
