Question about Zebra Z4Mplus Label Printer
Good morning. my printer will not calibrate. Could you please help me out?
  • Zebra Master
  • 4,338 Answers
Perform a Manual Calibration:
Perform a media and ribbon sensor calibration to reset the sensitivity of the sensors so the
media and ribbon are detected more accurately. If you change the type of ribbon or media,
your printer may operate better if you perform this calibration.
Calibrate Media and Ribbon Sensors
Use this procedure to adjust the sensitivity of the printer's sensors. In a
printer that has the Thermal Transfer option installed, both media and
ribbon sensors are adjusted. In a Direct Thermal printer (no Thermal
Transfer option installed), only media sensors are adjusted, and the LCD
displays for ribbon do not appear in this procedure.
Important • This procedure must be followed exactly as presented.
All of the steps must be performed even if only one of the sensors
requires adjustment. You may press the left arrow at any step in this
procedure to cancel the procedure.
How to select this parameter:
1. Press ENTER to start the calibration procedure.
The LOAD BACKING/REMOVE RIBBON prompt displays.
2. Open the printhead.
3. Remove approximately 8 in. (203 mm) of labels from the backing,
and pull the media into the printer so that only the backing is between
the media sensors.
4. Remove the ribbon (if used).
5. Close the printhead.
6. Press ENTER.
The message CALIBRATING PLEASE WAIT displays.
The printer adjusts the scale (gain) of the signals that it receives from
the media and ribbon sensors. On the sensor profile, this essentially
corresponds to moving the peak of the graph up or down to optimize
the readings for your application.
RELOAD ALL displays.
7. Open the printhead and pull the media forward until a label is
positioned under the media sensor.
8. Reload the media and ribbon (if used).
9. Close the printhead.
10. Press ENTER.
The printer does a calibration; during this process, the printer
determines the label length. To see the new readings on the new scale,
print a sensor profile.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on May 25, 2011
Prints ok from computer but when I make a copy, the copy is blurred.
Can you please remove all cartridges, and put them back and perform a quick calibration? I will fix the issue. Also please make sure use a good ink cartridge, the refill one does create this issue. Upgrade firmware will be the next step if quick calibration doesn't help. Please let me know.
Thanks
Jun 22, 2011 | Brother MFC 490cw Color Inkjet...
How do I shut off the auto calibration on start-up? Every morning 1 am wasting 4 labels and ribbon for calibration.
Can only be done by sending a ZPL command. The ZPL manual can be downloaded from the Zebra web site.
Apr 28, 2011 | Zebra Stripe S600 Thermal Label Printer
Hi there can you help with my HP2605? Since i replace a blue cartridge (a compatibal one. We have been using compatible cartridges for over year and so far so good.)3 weeks ago the printing is not week....
click on the alignment button and have the machine automatically start the realignment process
it is not color realignment but printer head alignment that is the problem
May 04, 2017 | HP LaserJet 2605dn Printer
My printer gets stuck on initializing...or calibrating. I have unplugged, rebooted and have gotten it to say "ready" but still will not print.
After you power on the printer, does it ALWAYS do calibration, and if so, does the calibration cycle complete or just goes on and on?
From your description, it sounds like the printer will come to the READY ... eventually after calibration. That's a good sign. The fact that it does not print could be other factors.
1. first, get a high speed parallel cable and hook the printer directly up to your computer. Be sure your commnications are good.
1a. if you only have ethernet connection to the printer, then you'll need to print out the information page so that you can find the IP address of the printer. If the printer's IP address shows all zeros, then the IP address for the printer's jet direct card has not been defined. Instead of going on about how to install a new port, drivers, etc. please tell me where you're at.
Jan 06, 2010 | HP LaserJet 4600dn Color Printer
How to calibrate hp 1410 all-in-one printer?
Hi genevieve
Click on the following link,
Scroll down the pages until you see the heading "Vertical Lines"
If you read this paragraph you will see how calibration is done.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu05212&tmp_track_link=ot_faqs/top_issues/en_nz/buu05212/loc:7&lc=en&dlc=en&cc=nz&product=441115
Good luck
If this answer help you, please give a rating.
luciana44
Nov 29, 2009 | HP PSC 1410 All-In-One InkJet Printer
I replaced the printer head but it won't calibrate
Press menu.
Press �� until Calibrate Printer is selected.
Press OK. A new screen appears with Print Calibration Page selected.
Press Start and follow the instructions on the LCD screen to complete the calibration.
If you want to clean them...
Press Menu to display the Main Menu.
Press �� until Clean Printhead is selected.
Press OK to go to the Clean Printhead menu.
Press OK to perform a Basic Clean.
Regards.
Apr 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Very Light Printer on HP Color LaserJet 3500
Table 7-33. Causes for distortion or blurring
Cause Solution
Transfer unit is defective. Replace the transfer unit. Calibrate the printer
after replacing the transfer unit. See Calibrate
Now, later in this chapter.
Defective secondary transfer roller If it does not rotate smoothly or it is deformed,
replace the secondary transfer roller.
DC controller PCB is defective. Replace the DC controller PCB. Calibrate the
printer after replacing the DC controller. See
Calibrate Now, later in this chapter.
Calibrate Now
Use the following procedure to calibrate the printer whenever you replace the DC controller,
the formatter, the color misregistration sensor (PS12), the transfer unit, or the laser/scanner.
1. Press to enter the MENUS.
2. Press to highlight configure device.
3. Press to select configure device.
4. Press to highlight PRINT quality.
5. Press to select PRINT quality.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
hope this helps
pdouglasss
Dec 17, 2008 | HP Color LaserJet 3500 Printer
Kodak aio 5100 all in one just prints red/pink
An inter active website is being provided by Kodak to help their customer w/ this issue.....Try using www.kodak.com/go/itg and use missing colors for sub class if this does'nt solve the issue call Tech. support. (1 800 421 6699)
Nov 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Canon color laser printer 5000
I cannot calibrate the Canon LBP 5000 color printer. The option is grayed out. I have the same problem. Please send me an e-mail to ali.ayash@yahoo.com when you get the solution.
Thanks in advance.
Apr 02, 2008 | Canon Wordtank G55
Zebra Z4Mplus Label Printer Logo
448 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
