Question about Hitachi 50VS810 Television
Hitachi 50vs810 heat light just blinks - Hitachi 50VS810 Television
    Genius:
  • 1,622 Answers
Hi, Heat is the enemy of electronics, and these sets operate hot. You might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
If you wish to repair it yourself what type of electronic training do you have?
What type of TV test equipment do you own?
Do you own and know how to operate an oscilloscope?
If you decide this is not something that you can do I expect this repair will be about $250 to $450, depending on how many parts are found to be out of factory specifications, if the problem is a bad circuit board, and if the board can be repaired or has to be replaced. A small TV repair shop will often charge less for the repair than a large electronics repair facility.
Should you require further clarification, never hesitate to ask. It would be my pleasure to clarify my answer to your question. If after reviewing the above information, you have additional questions, I will be glad to answer them. My goal is your 100% satisfaction with all questions I answer.
Posted on May 25, 2011
Hitachi 50VS810 50" Rear Projection HDTV blue power button blinking
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 08, 2018 | Hitachi 50VS810 50" Rear Projection HDTV
Hitachi 50vs810. Blinking Temp light. No picture No sound.
Spoke to a local repair shop. The tech told me that there is a wiring harness that has four fans on it. One of the four fans has failed. The complete harness needs to be replaced. There is another risk. Depending on the state of the TV when the fan failed, it might have cost you a bulb as well. The tech quoted me $250 to $300 to repair the television. Add about $120 more for a bulb.
Feb 16, 2011 | Hitachi 50VS810 50" Rear Projection HDTV
Temp ligt blinking in my 50vs810 tv
have you had the set cleaned if not do so the fans are proberly cloged with dust
Dec 02, 2009 | Hitachi 50VS810 50" Rear Projection HDTV
Blinking lamp light
The lamp is bad and needs replaced, i have the same problems with my Mitsubishi 58" DLP
Oct 01, 2009 | Hitachi 50VS810 50" Rear Projection HDTV
HITACHI 50VS810 WON'T TURN ON. .
If the set comes on momentarily, see if the lamp fan is turning. If not , the fan is probably bad.
Hope this helps,
skyassoc
Jun 26, 2009 | Hitachi 50VS810 50" Rear Projection HDTV
50vs810 hitachi ultravision
red lamp light is blinking---tv won't come on
Aug 25, 2008 | Televison & Video
Overheat led blinking
Did you ever get a answer to this question? I have a hitachi 50vs810 with the same problem. I found the same sensor "tokin ohd3-90m."
I ohmed across mine and it shows open. I then held my lighter under it and it stayed open. I suspect this part is bad so I tried jumping it out. No change. Still have the same blinking temp light.
So... in the end I don't know if I tested it right or not either. Good luck and let me know if you learned anything that can help me out.
Apr 09, 2008 | Hitachi 50VS810 50" Rear Projection HDTV
Hitachi 50VS810
This TV is just blinking lights in sequential order. TV is not turning on at all. Please help
Oct 24, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
