Question about Brother HL 2140 Laser Printer
Error I have a brother hl2140 had a week worked find turned on tried to print nothing happen it only has error light blinking. have looked through all their lit. no answers or support phone number.
  • Anonymous Aug 17, 2008
    error light on Brother HL-21240 printer. No other indication of the problem
Make sure there is not a piece of misfed paper in there. This happened to me and it took a while before I figured it out. Open the upper top and try to remove the toner. If it is stuck, more than likely there is a piece of paper stuck in there. Hope that helps.
Posted on Aug 20, 2008
  • bizmarker Feb 04, 2011
    Thank you very much, it was a stuck piece of paper. Now the toner light is on. Thanks just the same.
Brother hl2140 printer when you turn on the power and it starts to boot up it will begin to out put a blank page & then the next page gets jammed in the drum assembly.
Check Print Spooler Settings in your PC. Delete all print jobs in queue. Check Paper size settings in printer properties (Print tools)
Jan 03, 2017 | Brother Office Equipment & Supplies
Various issues
do a reset by holding the brother go button and it should flash all the buttons which is a quick reset...
now the issue about the noise might be the drum unit thats why theres an light error message
Sep 24, 2013 | HP DeskJet Office Equipment & Supplies
I have error light on. Computer won't print. I just bought the printer and it printed just fine twice. Then I turned off the power when I did not use it. When I tried to print again. the error light is...
The error light that is blinking is actually blinking out a error code. In the back of your manual under troubleshooting there should be a list.
On a printer this new about the only error you should see is a paper jam. IF anything else is wrong I'd just put it in the box and take it back. Rarely do you see something fail this new these days. It happens but not that much.
Once you look up the error code you will know what the problem is. It could be a cable unplugged or a paper jam etc. I can;t see it being serious.
Sep 11, 2011 | Brother HL-2040 Laser Printer
Print want print
If you recently purchased it, just put it back in the box and take it back to the store for a replacement. I wouldn't bother tryng to fix it if you can get a brand new one that works the way it's supposed to.
Apr 02, 2010 | Brother HL 2140 Laser Printer
Print overrun
probably the automatic upgrades of drivers and so ..cause the problem ...it might just replace your driver with a version they consider updated...and which just dont work with your ....printer ...try to reinstall the driver ( clean ) and if it works ..it means that this is the problem ...
Oct 03, 2009 | Brother HL-2040 Laser Printer
HL2140: won't print, error light won't clear Using Windows Vista GRRRRR
This is your printer's manual, you will probably find what you need inside it:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Jun 27, 2009 | Office Equipment & Supplies
HL2140 - DRUM REPLACED APPROX 3 WEEKS AGO, LIGHT KEEPS COMING ON
When you replace a drum in a brother machine you have to tell the machine it's a new drum. The instructions are on a sheet packed with the new drum. With the front door open you hold the panel button until all the lights flash on, then close the door and you're ready to print.
Jun 23, 2009 | Office Equipment & Supplies
All error lights blinking and fan running but won't print...
Yes Mr. Guest and Mr SwT,
Replace the fuser assembly unit.
Definitely the fuser got problem. This can be confirm by pressing the Go button and only the Toner LED will light up.
What had happen was right after the power blackout the fuser has fused together both rollers (heating drum and rubber roller) where the paper pass through in between the rollers. Since there was a power blackout, the printer fan has stop functioning and the heat was unable to disperse out from the printer. Suggest to improve on design to disperse heat using aluminium cage in case of power blackout.
Who ever has a Brother HL-2040 should definitely use together with a UPS.
chekamal
Apr 27, 2008 | Brother HL-2040 Laser Printer
Brother HL 2140 Laser Printer Logo
670 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
