Question about Whirlpool Corporation Top Load WasherDryer Cover Gray W10214580RP
Whirlpool LSR7233B does not agitate or do any spin cycles. The agitator moves freely when the machine is off, however, does not perform during operation. The timer release arm is new. Also, how do we remove the agitator?
Jimster
  • 240 Answers
SOURCE: My whirlpool top loader won't agitate.
Ok, sorry it took so long to write.  You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you.  What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving.  During the wash cycle, the top half is just sitting still.  If this is wrong, please let me know.  If this is right, you have a sort of simple fix.  Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off.  When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there.  You can put your finger on the lips and lift it straight off.  Then you will see a cap with a bolt in the center.  Remove this bolt (7/16" with long extension).  the agitator dogs (Sears part #387091) 387091.jpg.  You should see these under that last cap tha had the bolt in it.  Remove the auger (just slide it up and off), remove the dog holding cap.  Remove the dogs, but be sure you remember the way they go back in.  Next is the tricky part.  Take the cap upside-down, and place it back in the auger.  Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole.  Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator.  Make sure the locks and stuff fit right between the two.  Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap).  If all goes well and right, you should be able to roll the auger one way and not the other.  If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along.  Good Luck!!!!!     Jim
Posted on Oct 24, 2007
abhishek33
  • 1239 Answers
SOURCE: Whirlpool Washing Machine Won't Agitate
Hi friend...
it is usually caused by anything stucked below tub,if its not then if is actualy timer,,,check them both...
thank u.....
Posted on May 03, 2009
SOURCE: Whirlpool mach. is humming when u turn on but agitator won't move
Hello friend,
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
In case of the agitator not moving check the following:
Motor coupler
Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts
Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer.
Check the above, It seems that your washer needs a repair and would not be possible to do it yourself. So yau will have to call a technician.
Do feel free to get back to us in case of any other assistance if problem is not solved or if you have any other query.
Thanks
Posted on Mar 05, 2010
teeski2002
SOURCE: I have a model number LA5599XPW4, Whirlpool Design
the machine spin out of control
Posted on Nov 27, 2010
SOURCE: Whirlpool washing machine agitator problem
Simply buy the "doggies" and install it them
Posted on Feb 22, 2011
SPLINES STRIPPED
Replace this agitator coupling part number WH49X10042 make sure the inside of the agitator is not stripped.
Feb 05, 2014 | GE Profile WPSR3100W
Is the upper part of the agitator supposed to spin with the lower part? It spins freely when I turn it, but doesn't spin when spin cycle is activated during a cycle.
You have bad agitator dogs . Easily replaceable and inexpensive . Remove the center bolt holding the agitator on and seperate the 2 agitator pieces . You will see 4 teardrop looking pieces ( dogs ) . Replace and your done .
Jun 29, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator stops while in spin cycle
Assuming that this is a basic Whirlpool top load, direct drive, neutral drain washer, the agitator is supposed to stop during the spin cycle.
Please see the following Whirlpool installation and service manual for top load machines.
If you look at the description of how the transmission works, there is an "Agitate Cam" that lifts the "Agitate Gear" out of contact with the main "Agitate Rack" when the machine goes into spin mode
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I have found though that because of the friction between the agitate gear and main drive shaft, including the oil itself, the agitator may move while in spin mode.
Oct 14, 2009 | Whirlpool Washing Machines
Sep 22, 2009 | Whirlpool Washing Machines
Fills but will not agitate, spin, or drain, motor sounds strained
i have a whirlpool that go threw a wash cycle, but will not shin out the water
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Agitator moves slowly on wash cycle/not at all on spin cycle
it sounds like the dogs are worn. try twisting the agitator post by hand,it should move freely in one direction then lock up going the other.its a pretty easy fix if they are.pry off the top of the agitator post off then remove the cap inside,there is a bolt that holds the post down.i'm pretty sure it's 7/16 in. once the bolt is loose,lift the whole agitator out of machine and with your hand inside post turn it upside downand let the dog holder slide out.watch how the dogs fit into the holder, replace with new dogs and reverse the removal process.
if the machine wont spin, check the lid switch. thats usually the cause of a no spin situation.other than that a wet vac is your best bet.hope that helps.
Nov 29, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool top load washing machine - agitator
There are gears inside the agitator that are very cheap and relatively easy to change they are called agitator dogs. Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
Sep 30, 2007 | Washing Machines
Whirlpool Corporation Top Load WasherDryer Cover Gray W10214580RP Logo
103 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
