LCD screen says no signal and shows a plug icon.
  • 89 Answers
Is this a desktop pc? if yes, then your cpu is not working. Try to re-seat the Memory module in the cpu
Posted on Aug 16, 2008
SOURCE:
My emx-mcp61p-avl has power but no display no beep. video card is new and compatible with my motherboard. RAM is new also.
Just because the ram and video card is new does not mean they work. But since you say it has power, I'm assuming it boots up all the way except the screen is not displaying.
If this is a laptop try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
If it is a desktop try the steps below.
Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor shows the display, then your original monitor is bad. If the Borrowed monitor does and same as your original monitor and does not show a display then your video card has an issue.
May 30, 2012 | Computers & Internet
Gateway m280 notebook black screen.
Why did you replace the lcd inverter? Were you able to barely see icons on the desktop which is an indication that the lcd inverter is bad? If not, then you need to replace the lcd screen. If you could barely see the icons and you replaced the lcd inverter, then the inverter is bad. Just because the inverter is new does not mean it works. If the video shows on the external monitor, but you can't see anything on the laptop's screen even when you shine a flashlight on it then the lcd screen is bad.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad.
If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 24, 2012 | Gateway Computers & Internet
Gateway laptop powers up but screen does not come up.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your ideo card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 24, 2012 | Computers & Internet
White striaght line on my hp laptop
Sounds like your LCD Screen is bad. I could be your Video Card, but more than likely, it's the LCD Screen. To isolate the problem try the steps below:
May 16, 2012 | HP Computers & Internet
Laptop turns on but screen doesn't show
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 07, 2012 | Acer Computers & Internet
Cant run video plug-in not responding
Video Plug-IN? Are you saying there is no display on the lcd screen?
May 06, 2012 | Computers & Internet
How to open baklit or activate the light
If you're talking about the backlight inside the lcd screen, it would be easier to just replace the lcd screen. Take my word for it.
And how do you know it's the backlight instead of the lcd inverter? Is the screen dark? If so try this:
Apr 14, 2012 | Computers & Internet
Trying to set up Panasonic TH-L32X10A LCD TV. Have plugged into the wall and the screen display says 'No Signal'. How can I fix this? Thank you.
chose the input from the lcd operation on screen manual that is proper for the signal you are using (example) hdmi, AV, or TV. when you choose the correct input selection the lcd will show what ever signal you are sending it.
Apr 18, 2011 | Televison & Video
Battery level
As Suzaku explained:
A battery icon will show up on the LCD screen of your camera when it is already low and needs recharging. It can be found at the lower right side of your LCD screen. The ready light of your camera will also blink red and your camera will turn off if the battery is exhausted.
NOTE:
The icon will not appear if the batery is sufficient and there is no TECH way of making the icon show until the batt needs charging.
Jan 04, 2009 | Kodak EASYSHARE M763 Digital Camera
I cant get my acer aspire one to connect
your describe: connect a laptop VGA out to a monitor but no signal: you need check
1) newer monitor have two signal interface (analog or digital) and you may try to do a logical change the signal way by select buton
2) any laptop have two way display (local LCD or extenal VGA) change by the key (fn+f key showing creen icon)
Nov 08, 2008 | Dell E207WFP LCD Monitor
Open Questions:
Computers & Internet Logo
27 people viewed this question
Ekse
Alun Cox
