Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
No air flow to refrigerator section
Model GD5RHAXNT00 (Whirlpool) there is no air going into refrigerator from the freezer. Have you seen this?
  • 943 Answers
Hi thanks for the question yes lots of times i would check the fan motor in freezer you should be able to hear the fan going with the freezer door open if not replace the fan motor in freezer and also check for frost build up in freezer thanks the appliance doc
Posted on Sep 27, 2008
The freezer works fine but the refrigerator will not get cold.
On most new refrigerators there is damper that opens and allows the cold air from the freezer to circulate through the fresh food side.
I have seen this same problem caused by over stuffing either the freezer side and or the fresh foods side. On the sides of the fresh foods section there are normally vents which allow cold air from the freezer side to flow. If these are covered up, the air cannot circulate and without air circulation, the temp rise.
Both freezer side and fresh food side work because air is allowed to circulate around your product. I saw a refrigerator that the bottom half was 70 degrees and top half 38 degrees. The shelf about halfway down was completely blocking airflow. Threw out a bunch of boldly items and bags, rearranged items so air could flow and unit started working properly again.
If the damper is not opening, I have seen them freeze shut. It may have to be thawed.
There is also on some models a recirculation fan that gets turned on to circulate cold air from freezer. If this fan burns out or is blocked, it may need to be replaced.
You can go to searspartsdirect.com with your make and model number and get a complete drawing and parts breakdown for most refrigerators. And more important, you can buy them and have the part typically in two days at your door.
Hope this help!
Apr 19, 2016 | Refrigerators
WHIRLPOOL SID BY SIDE FRIDGE MODEL GD5RHAXNT00 LIGHT HAS GONE OUT IN REFRIGERATOR AND TEMP GUAGE IS NOT SHOWING A READING
What youre experiencing is a common main control board failure.
The main control board for this model is no longer produced. But, don't scrap your refrigerator because new control boards are no longer available -- Save your appliance and high replacement costs and let us remanufacture the control board for you. This is a common control board failure that FixYourBoard.com can repair. We remanufacture the main control board in your model and back our work with an industry leading two year warranty. W10135090 Whirlpool ELECTRONIC CONTROL BOARD MAIN CIRCUIT BOARD
May 26, 2014 | Kenmore 57029 Side by Side Refrigerator
Freezer working, but fridge is not. when you turn it off then back on its kicking on but fridge is not getting cold.
Check the air return on the bottom left wall of the refrigerator side. Check for cold air flow at the top of the refrigerator when the compressor is running. If you feel no air flow, open the freezer door and see if you detect significantly more air flow after opening the freezer door. This could indicate a return air flow restriction and make sure that there no blocking of air vent at the top of refrigerator section that supplies the cold air from the freezer.Check the door seal gasket on the refrigerator for leaks.
If there is still same problem then you need to replace evaporator fan.
Hope this helps.
Shane
Mar 05, 2011 | Whirlpool Refrigerators
FREEZER FREEZERS BUT THE REFIGERATOR WONT GET COLD
If the vents and air flow paths in the refrigerator are proper, then check the back wall of the freezer for excessive frost. A defrost system problem could be preventing the refrigerator from cooling properly. If you do see excessive frost on the evaporator in the freezer, you may be able to restore proper cooling in the refrigerator by storing your food in an ice chest and then shutting off the refrigerator/freezer and letting the unit completely defrost for about 24 hours. Leave the doors open for air circulation. After the frost on the evaporator has defrosted, plug the unit back in and see if the refrigerator and freezer will cool properly.
Hope this helps.
Shane
Mar 01, 2011 | Whirlpool Refrigerators
My refrigerator is not working, but my freezer is
Usually there is a air flow problem from it not defrosting(all the evaporator coils are frosted up with moisture preventing air flow-defrost problem ) or the fan motor is not turning in the back of the freezer section above the evaporator....
All of the cooling in the top or refrigerator section is done by air flow circulating across the coils in the freezer to get temps down to 38 degrees or so. You have to listen for the fan running in the freezer section, feel for air at the top back of the refrigerator(the damper control) Sometimes a bi-metal thermostat in the defrost circuit is also used in series with the evaporator fan motor, if it is open the fan will not run........(this I have seen) Also check the vents for the return air to the freezer(behind the crispers are not covered accidentally) Hope this helps........
Jan 10, 2011 | Maytag MFD2560HES Bottom Freezer French...
Whirlpool Model ED5SHAXML12 is freezing food in refrigerator even when dial is at off. Happened from one day to the next.
At the refrig controls , the freezer control , controls how much air goes into the refrigerator section . Open the refrig door , and up at the top left , put your hand over the damper (air vent) . Turn the freezer control from high to low , and feel the difference in the air flow . If you turn your freezer control to a lower setting , less cold air will enter the refrig . Think of it as : the freezer control adjusts the temperature , and the refrig control , tells how long to run the compressor . In actuality , this is how it works . However , with the dial (refrigerator thermostat) in the off position and refrig still running , this indicates a bad thermostat . Pt # 2198202 .
Sep 09, 2009 | Whirlpool Refrigerators
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Aug 10, 2007 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
213 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
