Question about Amana Refrigerators
Where would I find the model number for my Amana side by side refrigerator.The problem I have is that the freezer section is keeping solids frozen,but not ice cream and concentrated juices.I noticed the metal strip on fron of refridgeratoor where the door gasket touches is very hot.
  • 65 Answers
Most of the time when the strip is hot it is due to the condenser coils being clogged. If you pull the kick plate off under the door, you should find some coils with dust, hair, and other various debris that has to be cleaned off the coils. These coils can become insullated with dust bunnies and not allow the freon to release enough of the heat as it flows through the coils. The coils actually run through the cabinet where the metal strip is getting hot. Break out a vacuum and clean off the coils and then give it a day and the unit should begin operating properly again. If you can't find the coils underneath remove the back access panel and they should be located to the right of your fan. Also make sure the fan itself is running. The fan is what moves the air flow under the fridge to cool the coils, if it is not running it can cause the same issue.
Posted on May 25, 2011
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
Cannot find tech data sheet in lower back panel does anyone have a copy of this info
Posted on Oct 26, 2015
  • Amana Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
The model number is usually behind the lower kick panel or lower left chassis below the door gasket seal area. Also upper right side of the freezer compartment and on the tech data sheets in the packet inside the bottom of the unit.
Your statement here:
Tells me as a technican that either your condensor coils in the lower rear of the unit are blocked or the condensor fan is NOT running. Unplug the unit (15 mins minimum off time) Open the fiberboard lower rear cover and clean everything. Coils, Fan and the drip pan / tray in the bottom of the unit. Try to rotate the condensor fan with a finger. It should spin freely. If it does NOT spin freely you can try lubrication with a pariffin based oil / turbine oil to see if will snap out of it. DO NOT use regular oil or 3 in one oil on the fan motor. It will only lock up again in about 30 days... probably for good.
If the condensor fan is NOT working at all... until you get parts you can place a floor fan blowing air into the bottom of the unit and it should work fine as long as the external fan is on.
Thanks for choosing FixYa,
Kelly
Amana model aqbb1921dew
You will have to look in the freezer section and see if there are holes in the left side wall to mount the icemaker and also if you look at the left rear of freezer section to see if there is a spot for the harness to plug in. Also look on the model serial tag inside unit to see if they listthe part number to add on icemaker kit.
Jul 05, 2014 | Amana ABB1927DE Bottom Freezer...
My frezzer works but refrig doesnt cool well
open the freezer door,do you hear the fan blowing,if not hold in the door switch for a few deconds and let it go,if the fan isn't blowing this is your problem.all that happens is the freezer gets cold,the evap fan blows cold air through the damper and into the fridge section so if the freezer is fine you have a bad evap fan motor or the damper isn't opening all the way
Nov 19, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Bottom Freezer of the Amana serial number: ARB2214CW gets over frozen and starts to create snow over frozen food. What number cold should be on to just keep the food solidly frozen without the above...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 20, 2010 | Amana ABB1927DE Bottom Freezer...
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Where is the water filter in the bottom freezer amana energy saver model refrigerator; and how do you change it?
according to the model number that you gave this particular unit does not have a filter built into it. most amana bottom freezers ahve the filter located in the refrig section on the ceiling. there is a thumb latch you push in and a cover lets down to expose the filter. then turn 1/4 turn counterlokwise to remove. if this doesnt sound right post back wiht a complete model number from the refrig and I will take another look for you. thanks for using FixYa peyton
Feb 17, 2009 | Amana ABB1927DE Bottom Freezer...
Amana Side-by-Side refrigerator hot spot
hi tanks for the question there are heaters at the spots you said were hot and those heaters are there to prevent moist air from hitting cold surface and create warer droplets from forming on those surfaces i would remove the back of the fridge and vacuum it out that should solve your problem thanks the appliance doc
Sep 18, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Help, no water but have ice out of door on amana side by side.
The freezer temperature dial is set too cold and it is causing the water to freeze in the tube right where it enters the freezer section.If you turn the temperature selector one or two numbers warmer for the freezer it will help.
You will also have to turn the box off and let the freezer thaw real good so that the line will thaw. Once this has been done, it should work fine.
Jun 08, 2008 | Amana SXD524VW Side by Side Refrigerator
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Amana refrigerator only not working
Few questions first. 1.  What is the entire model # on the sticker inside the fridge section?  2.  Is the fan in the freezer running?  3.  Is there a thick frost build up on the back panel in the freezer (look at the bottom half for a side by side)?
Oct 20, 2007 | Refrigerators
Refrigerators Logo
249 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
