Question about Canon PIXMA MX350 Wireless All-in-One Inkjet Printer
HOW TO RESET INK LEVEL IN CANON PIXMA MX350 AFTER A REFILL?
mtspace
  • 103 Answers
SOURCE: reset Ink levels for canon mx310
I've heard that with canon there is a way around the ink-level chip monitoring on the cartridge by doing the following:
  1. Power off printer
  2. Hold RESUME button then press and hold POWER, the beeper will sound once.
  3. Hold POWER and release RESUME
  4. Press RESUME twice
  5. Release POWER button
  6. When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
  7. Press POWER to set data
Posted on Jan 05, 2008
SOURCE: Cannon Pixma 160 - How do I reset the ink level indicator
crapt the driver
Posted on Oct 21, 2008
  • 4 Answers
SOURCE: Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Posted on Jan 09, 2009
  • 352 Answers
SOURCE: Canon pixma mp240 ink reset
Thats funny, cause I took the cartridges out and left the lid up, unplugged it, plugged it back in with my finger on the power button and tapped the stop/reset button twice. Put the cartridges in, pressed the color start, after some moaning a test page printed. I unplugged it again, plugged it back in and I had full ink Levels!!!
Posted on Jan 27, 2010
SOURCE: Canon PIXMA MP190 reset ink?????
I have a canon printer MP190. How do I do the reset after completing my ink cartridge to the syringe?
Posted on Mar 02, 2010
Canon pixma mx350 printer ink level shows exclamation mark about the icon
If you are using an ink refill kit (or buying ink that has been refilled, the ink level will not show accurately) also, if refilling yourself you must clean the pint area of the cartridge with alcohol before installation, and then run the 'clean print head' tools from you Canon menus.
I recommend buying Canon ink, at least for 1 in 4 refills to reset your ink levels.
Nov 20, 2013 | Canon PIXMA MX350 Wireless All-in-One...
Reset ink level on canon mg2120 after ink refill
The following procedures may be used to reset the Canon printer ink level monitoring following the installation of a refilled Canon 30, 31, 40, 41, 50, 51, 210, 211, 240, or 241 integrated ink cartridges. In most cases, the error/alert will need to be cleared to enable printing. Ink waste container reset procedures are also provided below.
NOTE: for multi-cartridge installation, the procedure(s) may need to be repeated twice.
For PGI-5, PGI-9PBK, CLI-8, PGI-220 CLI-221 PGI-225 CLI-226 PGI-250 CLI-251 Cartridges: These are new Canon cartridges which have an embedded chip on each cartridge. If you just refill the ink, the printer will still reads the cartridge as empty. You have two choices:
Purchase a "refillable cartridge" from www.asapinkjets.com
BCH or other sellers. These refillable cartridges have an auto-reset chip (non OEM) and will reset automatically.
Use a chip resetter (e.g., search Canon + model number + resetter on eBay). Follow the instruction below to refill your original cartridge, and use the resetter to reset the chip.
Inkjet Cartridges and Toner Refills
Aug 29, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
I've changed the ink cartridges in my MP120 twice and the display is still showing that the ink level is low. How do I get the printer to reset to show the correct ink level?
After the refill it indicate your ink level is low.... Don worry about that its nature... it doesn't happen any thing... All the canon printer indicate like that... thanks
Aug 26, 2011 | Canon PIXMA MP160 All-In-One InkJet...
How do I reset ink level on Canon MX350
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
3. hold the Power button, release Resume Button.
4. Without releasing the Power Button, double click "Resume" button and then release Both Buttons.
5. Click "Resume" for four times then click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 26, 2011 | Canon PIXMA MX350 Wireless All-in-One...
WHERE CAN I FIND THE SERIAL NUMBER
at the bottom of the printer.... there should be some sticker in silver.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 12, 2011 | Canon PIXMA MX350 Wireless All-in-One...
How do I reset my printer when I refill my cartridges myself?
Did you mean reset ink level counter? It can't. But you can released ink level counter by pressing reset button for 12 second.
Dec 31, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Ca i recharge catridge form cnon pixma MX 330?, i
All catridges are made to show the ink levels only for 1st use, once you refill the cartridge you need to reset the ink level chip, some cartrides level cannot be reset, some can be re-set.
There are solution available for some specific printer ink cartridges on how to re-set the ink level.
You can google and loacte the solution giving cartridge number in the search field of google.
Dec 07, 2009 | Canon PIXMA MX310 All-In-One Printer
I refilled the ink with a refill kit
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On your printer this happen with push consistently buttons for black copy (for turn of level on black cartridge) and color copy (for turn of level in color cartridge). The printer
shows empty cartridges but it will printing.
Oct 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon MX700 cannot detect remaining ink level
Try to run the reset tool for canon printers which will reset the printer.
http://www.ziddu.com/download/2620692/IPtools.zip.html
Jul 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MX350 Wireless All-in-One Inkjet Printer Logo
2,331 people viewed this question
old marine
old marine
