Question about Honeywell Heating & Cooling
My honeywell programable thermostat (PC8900) has a mind of its own. Even though it is programed, at times it will continue to run without homeowners input. Temp set for 75 and continues to run at time below 70 until interupted.
  • 5 Answers
SOURCE: I HAVE PROBLEMS WITH MY
t87 usually are about 5 degrees off. sometimes more because of dirt and dust.get a digital
Posted on Aug 28, 2008
  • 52 Answers
SOURCE: Improper Termperature Readings during AC run
personally i'd just replace the thermostat, but try pulling the front panel off and look on the circuit board and see if there is a jumper for F/C or any other settings. you may try changing its position. you can also remove the batteries for 15 minutes and see if it resets itself. the only other thing it could be is a wiring issue.
Posted on May 29, 2009
mikeangie304
  • 15 Answers
SOURCE: Our thermostat is set at hold with the fan on
it is ok to run your fan continously. constant air filtering as long as it pauses before a/c cycles on. will not use any more electricity than a toaster. is there a fan programing feature on t-stat. if so you will need to turn programing to fan off
Posted on Aug 20, 2009
  • 363 Answers
SOURCE: the fan runs continuously, with thermostat set to
When was the last time you had the coils in the condenser cleaned. Dirty coils can insulate the refrigerant tubes, causing the fan to constantly run in order to try and cool down the refrigerant returning from the evaporator coils(a-coils) in supply ducting, But can.t because the condenser coils are insulated not allowing the heat to escape. I would try this first before replacing expensive parts. It is the small things that we overlook that is most likely the source
Posted on Aug 22, 2009
  • 29 Answers
SOURCE: Outside unit runs continuously, even when system is off.
On A/C units, there is a low voltage line that leads to a contactor, which engages to close the high voltage circuit to the condensor unit. Over time, the accual contacts in the contactor can weld themselves together. Try shutting off your furnace breaker but leaving on the one for the outside condensor unit. If it still runs, your contactor probably needs replaced. Contact a licensed electrician or HVAC contractor and tell them you think your contactor is in need of replacement. Is a fairly simple and quick replace, but the contactor itself is not cheap.
Posted on Oct 10, 2009
The furnace comes on @ 70* when programmed to be 60* at night
you have to switch it to settings and reprogram it. find your owners manual and it will tell you how to program your thermostat
Dec 01, 2012 | Honeywell Programmable Thermostat Heater
I need a manual for a honeywell RTH230 B programable thermostats
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can't find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Sep 22, 2010 | Honeywell Heating & Cooling
CM67ng will not turn heating off
Are you running some type of program on the tstat??
Jul 06, 2017 | Honeywell Programmable Thermostat Heater
Have the honeywell t8001c thermostat - no batteries - it holds the programming fine but not the date/time - what to do?
Go to honeywell.com
If you can’t find what you want, the bottom left and bottom of web
Mar 06, 2010 | Honeywell Programmable Thermostat Heater
Have a ts1f85277 programable thermostat los the instructions on how to reprogram can you help?
HONEYWELL WEBSITE:
Go to honeywell.com
Jan 10, 2010 | Honeywell Programmable Thermostat Heater
Honeywell thermostat not lowering temperature
remove batteries let sit a few minutes reinstall.
if still bad replace they are not servicable
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Honeywell programmable Thermostat won't hold time or program
Most thermostats use a six volt transformer for a power source, similar to a door bell, you can tell if yours does by looking at the wires that are attached to the thermostat.
The wires will be thin with just a single strand if you have these wires then you have a transformer, try and find the transformer (good luck) test it with a voltmeter if it fails the test that's it, if not, call the man. Probably it though.
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Heater comes on at 5:10 am prior to the programmed setting
Access the installer setup menu (You will need the installation manual from the t'stat to do this) and turn off the "intelligent recovery" feature. This feature turns the equipment on in order to bring the conditioned area up to temp at the set time. Or you could set the "wake time" to 6:50!!!
Dec 15, 2008 | Honeywell Programmable Thermostat Heater
Honeywell thermostat RTH230B
Sound like you need new one... take a look on amazon ecobee3 Smarter Wi Fi Thermostat Remote Sensor. It's not worth repairing it..
Jan 06, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
456 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
