Question about Eiki LC X999 Multimedia Projector
I have an Eiki Projector LCX999 and know that if it is unplugged before it has a chance to cool down, that it will not turn on again unless it is reset. How do you reset this machine?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
These older types will always try to finish the cooldown period of previous use. It is in the firmware
Posted on Apr 17, 2014
SOURCE: Projector overheats after 30 minutes and shuts down
Is the fan in your projector still working in high speed or not spining?
Posted on Dec 16, 2008
SOURCE: Shuts off after using it for a while....Eiki LC-NB2UW
I have the exact problem. I have been using a portable fan next to the projector to keep it cooler it allows me to use the projector for work. I know that this is not the "fix" but it helps. If someone has the solution, I would like to fix the projector.
Posted on Mar 04, 2009
  • 87 Answers
SOURCE: Our Eiki LC-986 projector has worked flawlessly
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Posted on Jun 15, 2009
projdoc
  • 2237 Answers
SOURCE: No power to Eiki EIP-2500 projector
there is a fuse on the power supply. if the fuse is good, you'll need to replace the power supply.
Posted on Nov 18, 2009
fathitkf
  • 1871 Answers
SOURCE: Eiki lc-nb3s projector... fan comes on but no lamp
Please check on of these solutions :
1:Remove the lamp from the projector. Ensure that it has no cracks, discoloration or "smoky" appearance.
2:Try removing and reseating the lamp, or to try another lamp.
3:Reset your lamp timer. Most projectors have no way of knowing if you physically have replaced your lamp. They rely on the user resetting the lamp timer
4:Pull the lamp back out of the unit, give is a brisk shake and reseat the lamp. Occasionally there is some buildup on the lamp contacts or filament during manufacturing.
5:Are the input and output vents blocked or obstructed in any way?
6:Are the filters dirty or clogged? Most manufacturers will recommend filter cleaning on a monthly basis depending on usage
7:Remove any extension cords, power strips and/or surge suppressors. Many current model projectors will not even try to ignite the lamp if they detect drops or fluctuation in voltage supplied to the unit. This is a safety feature to reduce stress on the lamp.
PLEASE DON'T FORGET TO RATE !
Posted on Apr 12, 2010
My church has an EIKI LC-X986 projector that turns on for about 2 seconds then shuts down. The lamp is brand new and the filters are clean. I know the signal is working as I can see it for those 2...
Have a close look at the fan and check if there is a make and model number on it.
If you cant see anything, unscrew the fan and check on the hidden sides.
see what voltage it is. ie 12v dc or 24v dc
Ring the EIKI agent and ask them how much for a replacement rear fan, the EIKI part number, and also if they can supply the manufacturer of it and their part number.
Check that the fan connector is OK, and the socket where it plugs in.
Check that the fan turns freely.
report back what you find
Mar 24, 2011 | Eiki LC-X986 Projector
Fan will not turn off after lamp cools down. fan will run for days.
is this after auto shut down ? check menu setting if this is set to READY, then it will wait until signal appears again at the input. You can set this better to "shut down", PJ will go to standby after cooling period and fans will stop.
Nov 10, 2010 | Eiki LC-X50M Projector
I have an eiki xbl20 projector that i mounted upside down. How do I get the image to turn right side up?
Nov 20, 2009 | Eiki LC-XB15 Multimedia Projector
When this projector runs for an hour or so it shuts off & has to cool down before turning it back on
clean it out with canned air. dust collects inside and holds in the heat that the projector is trying to expell. also make sure the fans are spinning.
Nov 04, 2009 | Eiki LC-X1100 Multimedia Projector
I have a eiki lc-xnb5m projector that seems to be shutting down if it's ceiling mounted, but runs fine on a cart. I know it sounds strange, but, is there some sort of gravity sensor or levelling sensor or...
there is a heat sensor, i had a same problem, and it turned out to be this dumb thing, if projector get's to heated up it shut's down to save the electrical components from burnig out
Oct 29, 2009 | Eiki LC-XNB5M projector lamp Projector...
In few minutes after turn on the projector (Eiki Lc-xnb4m) , it shut off automaticlly. and i connect notebook with the projector ,no any reaction. i don't know how to operate it?
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Aug 22, 2009 | Eiki LC-XE10 Projector Multimedia...
EIKI XB23 PROJECTOR WON'T GO ON
Do you hear the fan start up? or does the projector lamp come on (you start to see an image)?
If yes to either:
When the temperature inside the projector reaches a
certain level, the projector will be automatically shut down
to protect the inside of the projector. The POWER indicator
is blinking while the projector is being cooled down. When
the projector has cooled down sufficiently (to its normal
operating temperature), it can be turned on again by
pressing the POWER ON-OFF button.
Note:
After the temperature inside the projector returns to normal, the
WARNING indicator still continues to blink. When the projector is
turned on again, the WARNING indicator stops blinking.
Then check the matters below:
– Did you provide appropriate space for the projector to be
ventilated? Check the installing condition to see if
ventilation slots are not blocked.
– Is the projector not installed near the ventilation duct of
air-conditioning equipment which may be hot? Install the
projector away from the ventilation duct of airconditioning
equipment.
– Are the air filters clean? Clean the air filters periodically. Let me know if you need to know how to do this.
If no to either:
When the projector detects an abnormal condition, it is
automatically shut down to protect the inside and the
WARNING indicator will be red. In this case, disconnect the
AC power cord and reconnect it, and then turn the projector
on once again for check. If the projector cannot be turned
on and the WARNING indicator emits a red light, disconnect
the AC power cord and contact the service station for check
and repair.
Please let me know if this helped solve the problem. If not, is there anything else you observed - whether or not you believe it's relevant.
1ak+f4pj7cbm32cuniyi2gaaaaaelftksuqmcc
Jun 26, 2009 | Optoma EP716 Multimedia Projector
How to read the hours on an eiki projector lamp
simple!!! (if you know it..)
press the UP button on the projector for 20 seconds, and the hours used will be displayed briefly in the left upper corner of the screen.
Found the solution on Eiki web site, in FAQ section.
http://www.eiki.com/resources/resourcedownload.ashx?filename=/lamp_replacement/lc-xnb4_m_s_ms_lamp_replacement.pdf
Jun 20, 2009 | Eiki Projector lamp Projector Lamp for...
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
Sep 21, 2008 | Eiki LC NB2UW Multimedia Projector
Eiki LC X999 Multimedia Projector Logo
60 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
