Question about Craftsman Air Tools & Compressors
I have a craftsman oiless air compressor. All tools that I attach have low pressure to start. After I hold the attachment wide open for about 10 seconds, it will eventually break loose and the air flows normally. Once I let off the attachment and try to use again, it does the same thing. It seems like it could be a valve or something. Example: I have an attachment for pumping tires that has a handle. I have my compressor set at 80 psi but when I initially hold the handle it is only blowing maybe 5 psi. After holding the handle for about 10 seconds, it "breaks loose" and the air flows freely at 80 psi. I need to have the compressor set at 65 psi or more or it will not even "break loose". What is going on here?
    Problem Solver:
  • 20 Answers
Check your hose or couplers for restiction --------- try exchaging with know good ones------- the rubber seal in the female coupler may be the culprit ------------torn// deteriated// comming apart & blocking off air flow....
Posted on Jun 06, 2011
How do i service or change brushes in my 1955 craftsman oiless sprayer
Contact Craftsman unless it is now too old and if so check with a small appliance/tool repair shop in your area
Oct 15, 2014 | Air Tools & Compressors
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Some of the craftsmen compressors have pistons that are coated on the top of the dome. Once the coating wears off, they have severe loud piston slap. If you continue to run it the way it is, it will snap the connecting rod in half or break the piston and possibly the cylinder.
Sep 21, 2017 | Craftsman 33 gal Air Compressor 6 hp...
My Craftsman 15 Gal Air Compressor trips the electric breaker at start up no mater where I plug it in.
Just fixed my compressor. It would start ok when the tank was empty but trip the breaker if it tried to start with pressure. Searched and read about weak caps, or problem with check valve or pressure switch leaving pressure in the pump head, etc. Turned out that the black plastic box which holds the 2 start up caps and is attached to the end of the motor with 2 screws had cracked on the bottom. The black box had tilted out enough that the start up caps switch was not engaging. Pushed on the lower part of the box and it started perfectly. Fixed it for the cost of some 2 part epoxy. Maybe not your fail, but definitely worth checking out first.
Apr 12, 2012 | Craftsman 15 gal Air Compressor 3 hp UMC...
How do i change the oil in a 1.5hp 3gl craftsman air compressor
if your compressor is not an oiless unit there will be a plug or dipstick at a low point of the cylindrer head assembly. Most people pull the plug and lean on its side over a suitable container to drain. fill with craftsman compressor oil or equivalent, do not over fill.
Oct 04, 2010 | Garden
When tank is low on pressure, the motor cuts in but compressor struggles to turn and trips.
some compressors require an air release that drains the pump head when the compressor reaches full pressure if this is not working the compressor tries to start with full pressure on the pistons which is hard on the motor. If you always heard a small release of air when the compressor shut off yours probably had this feature. drain all the air out and if it starts fine that may be where the problem is. If its one of the smaller oiless ones the motor start capacitor is probably bad
Jul 10, 2009 | Psi Air Tools & Compressors
Oiless SearCompressor will not reach shutoff pressure of 120 PSI
There are only two reasons it will not reach shut off pressure. 1, there is a leak inside or outside of the compressor, leaking air faster than the compressor will deliver it. ( Do you hear hissing when you first shut off the compressor? If so this might be your problem) Second, the compressor is worn out, or needs repair. - Valves, rings, diaphhram etc. Take it to a repair shop.
Good Luck
Mar 17, 2009 | Craftsman Air Tools & Compressors
Need help wiring new pressure switch for craftsman air compressor
Assuming that you are wiring for 115v. Lets start with the ground. The cord that attaches to the wall outlet will have three wires, green, black , and white. Insert the cord thru one of the openings of the pressure switch and attach the green wire to the ground screw. Next look very closely at the contacts and notice that they are arrainged in pairs. There is a small brass bar with two contacts that completes the circuit for each line. Start with L1 and attach white wire from cord, then attach white wire from motor to the screw terminal that small brass bar bridges to (should be T1). Next attach black wire from cord to L2 and black wire from motor to remining screw. Remember that the small brass bar with two contacts is the bridge and simply connects white to white and black to black. Enjoy
Dec 16, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
74 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
