I will give u the solution follow me:
1/ charge the battery using a direct ac/dc adapter using its wires and straight 12 volts
u can do that by thouch the wires on the + - ples of the battery :
the negative wire in the -
and the positive wire on +
keep giving it that charge for 35 seconds and see
2/ put the battery on its place
3/turn it on and see what happends
4/ if nothing happend un need to flash ur pda try bto download a flash tool from the official site
5/ if nothing happend and u still under warrantgly be quick and return it back to the dudes!!!(company)
dont forget rating me thats what its tagke hehe^^
here is the update tool for ur device Sir thank u for using FIx ya
Inadvertently, you did a soft reset. Like most current electronic devices, a reset can and may revert a stuck/frozen/hanged to default factory conditions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Incidentally, the reset is done by pressing the "Mode"(reset/lap) and "Power" buttons at the same time.
Additionally, you may want to update the unit to the latest available firmware here.
Looks like its dead.
Best solution, sell it on ebay as is (ud be suprised how many people would bid on it for spare parts) and use that money, with a little bit on top from you to buy a new one
Cheers
That can be a problem with charging part of the unit or the unit is completely dead, if its still under warranty you can try to replace it from the manufacturer..
Hope that helps.............
garmin edge 305 less than one year old does turn on even when plugged in.
GArmin Edge 305 is dead. ONe year old and it doesn't have life even when it's charging-that was the oringal post.
I since held down two random keys and the thing powered up. Any ideas why?
