Question about GE Heating & Cooling
Window AC unit, Hi speed doesn't work. AC motor
    Genius:
  • 1,015 Answers
It is possible that the high speed went out on the motor but I doubt that. I would replace the switch and see if that takes care of your problem.Good luck and thank you
Posted on May 25, 2011
Blower motor doesn't pump well even the fan switch on high
sounds like blower bearings are dried out and will eventually lock up the blower..sometimes you can spray wd40 in the blower bearings and it will work fine for a while.. also check vacuum controls to the baffle dors in the ductwork..may have some leaks there.. should hear a slight hissing if really bad..repost findings
Feb 09, 2013 | 2005 BMW 545i
Fans only kick on when I run my ac. I replace my coolant sensor still nothing. I have checked the fuses. Where do i go from here?
Sounds like this may be a faulty fan motor, the low speed in these fan assemblys go bad, but the hi speed works when the a/c is turned on. I would check for the cooling fan relay first... you can usually switch this relay with another relay of the same and see if that makes the fan kick on, if it doesn't then i would go with replacing the electric cooling fan motor. Hope this helps
Oct 27, 2012 | 1998 Plymouth Voyager
Fuirnace blower motor doesn't blow very hard and sound rough
Maybe if you put a drop of liquid soap on the shaft for the fan. Since it is a heater, I wouldn't use a lubricant like wd-40. GOOD LUCK. Soap is cheap. Hope it works.
Jul 02, 2012 | Rheem Gas Furnaces 125K BTU 80 AFUE Single...
Heater/AC blower doesn't work at any speed
I would start by looking for a fuse that blew out. Depending on the vehicle, it could be clearly labled. fuse could be under the hood, or under the dash. it the fuse is good, next, could be a short, and most likely in the motor itself. What kind of vehicle; year, model? Dave
Mar 07, 2012 | Cars & Trucks
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
Our Danby model dpac 11006 was working fine yesterday but came to put it on today just to find out the ac doesn't work the fan still blows just no cool air . we do hear something in and out like a...
The intermittent sound you're hearing is probably the compressor trying to start. This could be caused by a bad circuit or the compressor motor is seized If the latter is the case, it's time to start shopping for a new AC. As the cost to repair would be almost as much as a new unit depending on the age of your unit. However, compressors usually have a 5 year limited warranty. So check you Owners Manual for details. It may still be in warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 11, 2011 | Danby Portable Air Conditioner
--2005 GMC Envoy AC Trouble--(compressor still active) Have replaced blower motor (original one had "burn" evidence), resistor and resistor connector. The blower is still not working. Have...
SOUND LIKE BAD BLOWER MOTOR RESISTOR.CHECK BLOWER MOTOR HI BLOW FUSE AND RELAY.YOU WILL NEED OWNERS MANUAL IN GLOVE COMPARTMENT TO LOCATED BLOWER MOTOR FUSES AND RELAYS.
Jun 06, 2011 | GMC Envoy Cars & Trucks
The AC works but the blower fan doesn't
Hello, this could be a bad capacitor or the motor itself is bad. Try replacing the capacitor first.
May 17, 2011 | Gibson GAC105P1A Thru-Wall/Window Air...
We want to change speed on air handler for unit Ruud UBHC-21A00NFA. We disconnected BLACK wire (Hi speed) and put in place of it RED (Lo speed). Is this correct to get Lo-speed on unit? Is there lower...
Hi, It depends on the make and model of the blower motor. You'll need to check this against the schematic (normally located within the electrical cavity) and work it from there. Some are two speed, some three. You can also look at the wires coming from the motor and check those that are taped off. There may be another wire, but check your schematic before changing any of the motor leads to the control board.
Best regards, --W/D--
Apr 28, 2011 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
135 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
