Question about Alfred Karcher K255 Electric Pressure Washer
Karcher 2.35d is our model we have just purchased
Karcher 2.35d is our model we have just purchased a karcher T300 plus, patio cleaner, we do not know how to attach this to the jet wash, one problem may be that we can not release the spray lanch from the triger gun is there a way to do this and then do you think the models we have will fit together
4 Suggested Answers
  • 92 Answers
SOURCE: no pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Posted on Apr 29, 2009
  • 187 Answers
SOURCE: Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
Posted on May 07, 2009
SOURCE: I have tried to use my Karcher washer model 411A
you have to lower the pressure at the lance for the detergent to be drawn into the hose. It works on a venturi principle.
on the lance you will have to twist or pull back the end for it to go into low pressure mode.
the easiest way to check it is working is to take out the lance extension , the bit that fits into the trigger on a bayonet fitting. run the machine and see if it then draws in detergent.
If it doesnt draw detergent then look to see if there is a detergent valve fitted to the filter that goes into the bottle and check that it is fully open. sometimes ther is a non return valve fitted into the filter too.
it could be that this non return valve has stuck. A poke with a bit of stiff wire should free it off its seat if it is that problem.
hope this helps a little
Posted on Jul 18, 2009
What kind of detergent is suitable for washing concrete patio slabs during pressure washing
KARCHER MAKE A STONE CLEANING DETURGANT THAT WORKS WELL ON ALL TYPES OF CONCRETE.
Mar 13, 2016 | Karcher Garden
Karcher lance fitting
if they are the plastic version, replace them as they tend to "expand" as they age and won't fit properly.
Jul 08, 2014 | Garden
Karcher paatio cleaner attachment cleaning in suiggly lines
Squiggly lines are sign of nozzles being partially clogged. Try using a needle to clear nozzles. You will need to remove the nozzles to do this. When re-installing the nozzles make sure they are in line with the pressure bar.
Mar 13, 2013 | Karcher KE302007A Classic Series Pressure...
My Kärcher K2.080 pressure cleaner (1450psi /
According to my search, Karcher has a 2 year warranty on this product. If you can get the serial number and model number off of it. They should be able to identify when it was made and then can honor that warranty. Otherwise the pump seals appear to be damaged by your description of the problem. Hope I've helped.
Best, Mark
Dec 28, 2010 | Karcher Electric Cold Water Pressure...
How do i use the patio & deck cleaner on the karcher k5.68MD, when i add the liquid, what do i need to do for it to be pump up into the hose.
The nozzle on the end of the wand either twists or pulls out to get you into soap mode, the liquid you have in the tank come out real slow, it does not come out with the high speed nozzle. The idea is to soak the job with detergent, then blast it off with the high pressure water. Hope this helps.
Mar 23, 2010 | Karcher Garden
When the patio cleaner is attached,the Karcher 5.68 pressure washer now keeps stopping and starting.It works fine on high pressure lance.It worked fine when bought from new a few days ago. We tried...
None of these fixes works for me and the original poster, like me what he's saying is when he swaps the high pressure lance for the patio attachment it pulses on and off, but when that happens, you can swap back to high pressure lance and it's fine. This means it's the patio attachment not any valves or power source, I have the same problem
Mar 09, 2010 | Karcher Garden
Alfred Karcher K255 Electric Pressure Washer Logo
203 people viewed this question
Top Alfred Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Alfred Garden Expert? Answer questions, earn points and help others
