Question about Agri-Fab Garden
Gears burnt out on my 45-03152 spreader. what can i do
    Novelist:
  • 171 Answers
Order new ones from agri-fab and replace them, You can get a new manual here: Agri-fab
Posted on Nov 17, 2013
Wheels turn.but spreader plate will not turn
Hi Pat:
Sometimes the spreader plate mechanism will have a bit of material left in it after use, and that will swell up from moisture in the air. Try giving it a really good hosing with your garden hose, and then manually try to work the mechanism back and forth to loosen it up. Be gentle and patient. Some of these devices have plastic gears that break easily.
Jun 10, 2015 | Garden
Seed or fertilizer drops down and just sits there, won't turn anymore
Turn the spreader over and inspect the drive gear, by turning the wheels. If the gearbox is enclosed, you will need to open the cover. If the gears do not mesh, then see if you can tighten up any retaining rings or seals. If the gears are stripped, then you probably need to replace the spreader.
Apr 11, 2015 | Garden
My scotts rotory spreader will not spin
The design is quite simple with one wheel driving a bevel gear in a gear box. If the wheel turns the axle shaft and the center pin in the spreader with the retainer/cotter pin does not turn it is likely something has failed in the gear box.
If both wheel spins and the axle does not turn than the drive wheel has disengaged the axle shaft and the cotter pin in the drive wheel needs to be replaced.
The compounds used in the spreaders are corrosive. Usually the gears and axle become bound due to corrosion. By oiling the bearings and wiggling the wheels they will free up,
Hope this helps?.
Apr 19, 2013 | Scotts Company 589384 Scotts 5000 SQFT...
Cyclone spreader parts
Cyclone spreader parts can be purchased from amazon, take a look here: Amazon com Cyclone spreader parts. Wish you best of luck
May 16, 2012 | Garden
I have a model 33 John Deere manure spreader that has the beater gear box with worn gears that won't engage. I cannot get replacement gears due to age of unit. Is there a way to repair the gears by we
There is no way to repair a worn gear, this is due to the heat treating of the metal to toughen it against wear and tear of use, otherwise it wouldn't last but a few hours of operation, this precise heat treating of the steel can only be done with special equipment and requires special skills to pull off correctly, so no you will need to get new gears. I know from personnel experience that you can get parts for these old farm implements, call around and see what you can find out. I will say that worn gears are not the common reason for hard gear engagement, that would be worn shift dogs and synchro ring cones or worn gear shaft bearings.
Dec 13, 2011 | Garden
Spreader propeller doesnt turn when i push it
I would think it is either it is stripped or loose gears or the roll pin which holds the impeller to the rod is missing. those things happen on the industrial spreaders I use at work.
Sep 17, 2010 | Scotts Company Scotts& Accugreeen 2000...
I just bought a Scotts 2000 discontinued model because it was the last drop spreader that lowes had,the problem is it works better in reverse then it does forward,???? is the hopper on backwards ?
Very likely, the gears that turn the horizontal distribution bar were installed backwards, causing this odd problem you're discribing.
If you bought it already assembled, I recommend returning it. It's your call whether you have them fix the problem, give you a new functional spreader, or give you your money back.
If you assembled it yourself, then you probably already realize by now what component was assembled incorrectly.
Apr 30, 2010 | Scotts Company Scotts& Accugreeen 2000...
Agri-Fab tow behind 125# Spreader. The gear
Not sure of the assembly but try to loosen the set screw and move the gear, if you assembled this unit the drive wheel may be on the wrong side...
Dec 01, 2009 | Agri-Fab Garden
I have a Scott Rotary Fertilizer Spreader. When I load up the bucket and move the spreader, the fertilizer on the rotor does not spread because rotor does not move
If the wheels turn( that is you can push the spreader easily) but the vertical shaft that spins the broadcasting plate doesn't, seems like the gears connecting the axle to that vertical shaft are worn; but if the wheels just slide along the gropund without turning then it would seem something right under the bin is keeping the verical shaft from turning. But I'm NOT an expert; I'm looking for an answer myself,
Mar 09, 2009 | Scotts Company Garden
Garden Logo
91 people viewed this question
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
