Zebra 105SL Thermal Label Printer Logo
Posted on May 25, 2011
HI, our Zebra 4m+ is currently set to a Darkness of 30 as that seems to eb th eonly way it will print enough detail on the label. We have tried adjusting the pressure settings to no avail. Now we are finding the print can be scratched off the label even thouhg we are using tamper proof labels and resin ribbons. Any sugggestions will be most welcome
Thermalman
Level 1:
New Friend:
  • Contributor 44 Answers
  • Posted on May 25, 2011
Thermalman
Contributor
Level 1:
New Friend:
Answers
44
Questions
0
Helped
21322
Points
67
Full resin ribbons tend to require higher darkness settins on all thermal printers.
It could be a mismatch between label and ribbon. This would need to be looked by your supplier.
  • cbridg Nov 28, 2014
    Also, the printhead to platen roller parallelism may need to be adjusted.
    A darkness setting of 30 is the max on this printer and will result in ruining the printhead. I would have the printhead parallelism checked with an authorized tech.
2helpful
I have a Zebra s600 that is set to 30 darkness and the head is screwed down fairly tight. I can print this way but if the printing lightens up, I don't have any more adjustment. The barcode reader picks up...
0.print config label (printer off, press Cancel button and tur on printer, wait 5 secunds and relese button)
1.press the last button until the ligth set on Darkness (Darkness on),
2 press the 3rd button 10 times( darkness down from 30 to 20 (3rd button=less 2nd button=more),
3.press 2 times the last button untill the 3 leds flash(save)
4.turn printer off.
5.Press pouse button, turn printer on, still pressing for 8 secunds, and then release te button.
6.The printer go to print the test label, let run 3 or 5 labels, then pause.
If not happy, repeat steps 1 and 2 (less times 2 or 3 times at the time and save)
print configuration label again ans se if you happy.
If the printer still going to darkness 30, chek if you forgot to save or check the driver settings and change.
Last option Resect to Factory Defult (this drop darkness to +10)
The barcode cannot be printed on the direct label
Your description is not very specific but no printing can be the result of:
1. The darkness is not set high enough
2. The ribbon is loaded backwards
3. You are trying to do direct thermal printing (no ribbon) but the label stock is not direct thermal stock.
Maybe you can provide more details.
Hope this helps,
Changed the ribbon, but the labels are to light.
The DARKNESS setting controls the amount of ink released to the label. The 105 has a range of 1-30, 1 is the lightest - 30 is the darkest. The setting used will depend on the combination of label / ribbon used. There is no "correct" number, always try to use the lowest setting with acceptable print quality.
The DARKNESS can be adjusted from the front panel by pressing SETUP and changing or DARKNESS can be controlled from the software or printer driver. The printer driver or software usually overrides the setting in the printer.
Hope that helps !
2helpful
3answers
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
1helpful
4answers
Can't save the printer darkness in the printer
go to printer driver properties.. 1.click printing preferences set it to USE PRINTER CONFIGURATION 2.go to advance click Printing Defaults set it to USE PRINTER CONFIGURATION
you must set this two configuration note: fresh installed driver defaulth to software control
1helpful
2answers
Zebra S600 Thermal Ribbon Ripping after printing
Hi chunnon,
What darkness setting are you using? If the darkness is at or near 30, you may be burning through the ribbon.
Try defaulting the printer and running a Pause test. Does the ribbon tear during the Pause test?
5answers
Zebra 105 SE Printing Blank Labels
You need the correct driver for the 105Se. The 300 dpi SL driver is not compatible.
Unfortunately, Zebra does not make it's older drivers available online. You will need to locacte someone with the correct driver for whichever version of Windows you are using.
Steve
2helpful
Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
