Question about Sonicwall TZ 210 Appliance
How to disable team viewer in sonicwall TZ-210?
    Scholar:
  • 67 Answers
You can disable Team-Viewer using Sonicwall TZ-210. This is process that you need to understand with some examples. Please visit " http://www.fuzeqna.com/sonicwallkb/consumer/kbdetail.asp?kbid=6038&catID2=110&catID1=143". This will help you.
Posted on May 25, 2011
Give me the procedure to block G talk. I have facing problem to block google talk,Skype & IM clients Please suggest me.
Praveen,
1. You will have to be administrator on the computer.
2. Start the Fire Wall and block all these sites there.
Feb 10, 2011 | SonicWALL TZ 210 (01SSC8786) Firewall
Problem in Sonic FireWall
Check with your ISP for whether they have blocked Port POP3 Port 25 or not. also allow (Open) this port in Sonic Firewall also.
POP3 Default Port 25 but many provider use different Ports so also make sure that you configured correct port.
Feb 26, 2010 | SonicWALL TZ 210 WLS-N TOTAL-SECURE NTWK...
I need to add an ip range to my sonicwall tz 170
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port.
However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous.
This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased.
I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Jan 23, 2010 | SonicWALL TZ 170 SP Firewall
Sonicwall Safe mode Problem
How do I access the SafeMode menu?
In emergency situations, you can access the SafeMode menu by holding in the Reset button on the back
of the TZ 180 (it’s the small pinhole button located to the left of the Console port) for 12-14 seconds until
the ‘Test’ light begins flashing yellow. When the SonicWALL is booted into the SafeMode menu, assign a
workstation a temporary IP address of 192.168.168.200 and attach it to a LAN interface on the TZ 180
Then, using a modern web browser (Microsoft IE6.x, Mozilla 1.4+), access the special SafeMode GUI
using the device’s default IP address of 192.168.168.168. You will be able to boot the device using a
previously saved image, or you can upload a new version of firmware with the ‘Upload New Firmware’
button.
Apr 07, 2009 | SonicWALL TZ 170 Firewall
Not able to see HP C6180 on SonicWall TZ 180
Not sure if you've done this already or not, but I would suggest installing the printer manually as a local printer, and create a TCP/IP port that points at the IP of the Printer. Rudimentary way to go, but should help.
-Backu
Jan 16, 2008 | SonicWALL Total Secure 25 VPN Gateway, WL...
Adding offices to my remote server
The SonicWall TZ 190 is a good appliance for the Tampa location.
The SonicWall TZ 150 is a good appliance for the remaining locations.
For the remote locations, a decision has to be made as to how many sites you want to interconnect to. If you want the network to be such that each site connects to every other site, then you will need the SonicWall TZ 190 as it supports VPNs for up to 15 sites.
In the end, everything comes down to cost. For a Small-to-Midsize Business, this is considered operational cost.
Hope this helps :) Kindly leave a rating. Thanks..
Nov 27, 2007 | SMC TigerSwitch 6508TT
Site to Site VPN Link with dynamic dns
Hi Rajmeet, Here is the documentation on the SOnicwall TZ170 the detail configuration can be found on page 211. Please let me know if this helps you and if youhave any other questions. http://www.sonicwall.com/downloads/SonicWALL_SonicOS_Standard_3.1_Administrators_Guide.pdf
Apr 02, 2007 | Sonicwall TZ 170 NFR (01-ssc-5564)...
Sonicwall  TZ 210 Appliance Logo
841 people viewed this question
Top SonicWALL Computers & Internet Experts
Raymond Ramirez
Raymond Ramirez
Frank Zabroski
Frank Zabroski
Steve P
Steve P
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
