My asus x52n laptop sometimes has small white lines flickering on the right hand side of tthe screen it is hard to notice and doesnt happen all the time?
  • 2,404 Answers
Sounds like the LCD is going bad on that laptop. It can show up when the screen is not processing the voltages properly.
Found one on Ebay for less then $100. Its located here. If your machine is under warranty then call Asus to get them to replace it.
Posted on May 25, 2011
How do i solve a problem with a Lenovo G555.
try connecting the laptop to an external screen if you can not get a picture then the motherboard is faulty
May 11, 2014 | Lenovo G555 Laptop
Asus x52n
What's wrong with it?
May 21, 2012 | ASUS X52N PC Notebook
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
Jul 18, 2011 | Compaq Presario 700 470024-192 Notebook
HP HDX 16 laptop
check in the bios
if it flickers on the bios then needs to send the laptop in for a repair....
if it does not flicker in the bios then needs to
1> update the display driver
2> perform a recovery
regards
DJ
Mar 16, 2010 | HP Pavilion zd8000 Notebook
Toshiba laptop screen goes white while in use
The problem actually will happen to all notebooks. Some problems happen on certain models more often. Also, it depends on how often the user closes and opens the notebook.
The data cable is usually the problem and it happens where the most pressure on the cable lies. The data cable will most likely need to get replaced. It is recommended that you take it to a service center. The cost should not exceed $145.00
thanks adi
Jan 12, 2010 | Computers & Internet
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Screen Problem
Unfortunately the fix is a new lcd. The tab welds at the top of the lcd are not allowing that portion to work correctly. As these tabs are fused to the lcd you will need to replace the lcd. My Toshiba M105 is almost the same.(I Have 4" Gone) on the right side. so to use it I clicked and dragged my system tray from the bottom to the side. And shrunk my web pages to utilize tthe good portion.
I suppose I should replace it but being only 18months old the LCD's run about 160.00 USD.(sometimes I just hook up an external monitor.
Apr 16, 2008 | Toshiba Satellite P105-S6207 Laptop
Flicker
I had the same problem with the flicker. Mine was a Flicker followed by a greenish line through the screen. It got worse then after 2 months the tv stoped working the power didnt come on at all. I Im taking it to bget fixed. The guy said it has somthing to do with a burnt out switch in the unit.
Oct 13, 2007 | Daewoo DSP4210GM 42 in. Plasma Television
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
