Question about Samsung SCX4623F Laser All-in-One Printer
SAMSUNG SCX4623F PRINTER HAS A LINE DOWN RIGHT HAND SIDE OF PAGE WHEN USING DOCUMENT FEEDER
  • 82 Answers
Check the scanner glass (the narrow side), it might be dirty, clean it with a soft cloth and alcohol
Posted on May 25, 2011
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
How do i copy 8 1/2 x 14 on samsung SCX-4623F
Dear
You can use the ADF to scan the size documents.
Thanks.
Mar 30, 2012 | Samsung SCX4623F Laser All-in-One Printer
Black line down page but only when i use document feeder. occurs both in scanning and copying
Can you see the left side the small glass? that is where your scanner will scan from if you feed through the feeder on top. So inspect if there is some dirt on this if you find anything on that do clean it and this will solve the problem. The other problem could be with the cable connected to the assy. but for now you can try cleaning it.
DO RATE MY SOLUTION
Jun 28, 2011 | Samsung SCX4623F Laser All-in-One Printer
Black line just left of center when using document feeder to copy or scan. This doesn't happen when i put only one copy directly on glass.....
Hi jenni
The problem is in the scanner area. What you need to do is open the ADF (Automatic Document feeder) cover and inspect maybe something is stick to the glass and it appears always. Try to inspect carefully you may see some dirty if you find anything removable like piece of paper do remove it or you can clean it with a dump cloth specially the area where the scanner stops then you use document feeder. This will sure solve your problem.
DO RATE MY SOLUTION
Take care
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Orange line running down page
lift lid on scanner and clean the thin glass on left hand side
you usually find when you scan alot of docs dust builds up and leaves lines down page
Mar 08, 2010 | HP Scanjet 5590 Flatbed Scanner
Line through middle of page when document scanned
Clean the ADF roller and the far left hand side of the glass, the small strip outside the 'main' panel.
Jun 24, 2008 | HP LaserJet 3030 All-In-One Printer
White line down side of page when scanning
If this is happening only when you are scanning using the automatic document feeder, check for something blocking light above the scanner. If you open the scanner top, look along the left side of the scanner glass where the paper is scanned by the automatic document feeder. If you see anything on the glass there, clean it with a soft cloth dampened with clean water.
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Samsung SCX4623F Laser All-in-One Printer Logo
503 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
