Question about OKI C5200n Laser Printer
Error 030 fatal error - OKI C5200n Laser Printer
  • OKI Master
  • 4,338 Answers
error 030 fatal error - ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply meanserror 030 fatal error - ecblank.gifhas occurred requiring you to take action. It does NOT meanerror 030 fatal error - ecblank.gifprinter has "died". ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
Posted on May 25, 2011
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
SERVICE CALL 030:FATAL ERROR
CU Resident RAM Check Error
Replace Fiery PCB (must move EEPROM to new board)
Aug 01, 2011 | Xante Ilumina Digital Color Press Printer
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
My pc`s screen is blue and it sais stop:c000021a ,is there? anything I can do to fix it
hello there
here is some information that should be able to explain this error and how to fix it ok?
best regards michael
  1. How to troubleshoot a "STOP 0xC000021A" error ... presents advanced troubleshooting steps for the STOP 0xC000021A error. ... STOP: c000021a {Fatal ... Note Most STOP 0xC000021A errors occur because Winlogon. ...support.microsoft.com/kb/156669
  2. "STOP: c000021a (Fatal System Error)" Error! RE: "STOP: c000021a (Fatal System Error)" Error! Ya, thats what I thought I might have to do ... RE: "STOP: c000021a (Fatal System Error)" Error! just input the ...www.msghelp.net/showthread.php?tid=66202 - 52k - Cached
  3. How I fixed my Windows XP Stop c000021a {Fatal System Error} with ... How I fixed my Windows XP Stop c000021a {Fatal System Error} with Knoppix Linux. 2008 March 14 ... Message: Stop c000021a {Fatal System Error} The Session ...healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-f... - 53k - Cached
Sep 16, 2009 | Microsoft Windows XP Professional With...
Iomega HDD Fatal Error 05
Fatal Error 5 is normally indicative of a Disk Failure. Because the OS can't read the portions of the drive.
Jul 05, 2009 | Iomega ScreenPlay
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Have OKI c5200 Printer Message window reads Service Call 030: Fatal error Mac Mini OSX system What do I do? Prior to Message  Black Ink cartride was low and replaced cartridge after message appeared
I had the same error with an Oki C9600N. Called OKI, and was told one of two things has apparently gone bad: a DIMM (in slot 1) or the controller board. I removed the RAM, cleaned the contacts, blew out the slots (w/canned air), and reseated the RAM. Printer is back up and running. Hope this helps someone.
Feb 02, 2009 | Office Equipment & Supplies
Emachine will not start up it says fatal error regeristery not updated, then turns off
Linux and UNIX ld command help -z defs, Force a fatal error if any undefined symbols remain at the end of the ... which are marked lazyload will not be loaded at initial process startup
E-mail CHID: 5369 Unfortunately we were unable to find anything about the Fatal Exception error message you are encountering we suggest you go through the basic fatal.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | E-Machines eMachines Desktop PC
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
OKI C5200n Laser Printer Logo
1,047 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
