Question about Pioneer VSX-D711 Receiver
MODEL VSX-D711.....STANDBY LIGHT IS ON.......UNIT WILL NOT TURN ON ......HAS POWER TO UNIT
  • boneman1975
    boneman1975 Apr 25, 2012
    Use remote to turn it on.
    Sergeant:
  • 187 Answers
Happened to me too. I just turn it on from the remote.
Posted on Apr 25, 2012
Bulldog AV
  • 52 Answers
SOURCE: after turning ON the power/standby switch, the
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Posted on Nov 24, 2009
petraman7
  • 1175 Answers
SOURCE: VSX-D409 - Standby Light - Does not Power On
Hi...
Make sure all the speakers are connected properly at BOTH ends.
If still **** then seek a service tech
Posted on Feb 08, 2009
  • 4 Answers
SOURCE: the power standby light doesn t go on when my my
that is becaus eit should only come on when on stadby
Posted on Apr 02, 2009
XSdB
  • 80 Answers
SOURCE: My Pioneer VSX-D704S WILL NOT POWER ON. WHEN I
It is in protection and will need to be serviced. Find a local AUTHORIZED pioneer service center.
Posted on Jun 12, 2009
dragster301
  • 12 Answers
SOURCE: Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Posted on Jul 31, 2009
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Pioneer vsx-01 receiver, standby light burned out. Button works fine, just no blue light. Pioneer sells a replacement standby button......is this easy to install and will it solve the problem? Do you have...
the light is an ledt they very rarely go bad ..to confirm its bad you must first see that the led is getting power --a voltmeter one end to the frame of the unit and the other to either lead on the led will confirm if its bad or not a typical led will run on or near 3 volts dc... if theres no power at the led than the problem is elsewhere
Aug 30, 2010 | Pioneer Elite® VSX-01TXH 7.1 Channels...
Hi...
Nov 27, 2008 | Pioneer VSX-D509S Receiver
Vsx-d711 sound problem
HI...
Sounds like ( no pun intended) poor speaker wire connections.
Check the wires at both ends and make sure theyre firmly attached.
If one speaker isnt connected , the amp will reset over n over
Nov 27, 2008 | Pioneer VSX-D711 Receiver
Pioneer VSX 915 powe off
Had a power surge last night and got the same problem. Unit wont power on and has a blinking blue light on standby button. I found the solution from the service manual for a similar model.
Hold down ENTER and ADVANCED SURROUND buttons.
This resets the DC overvoltage sensor and bingo the unit comes back to life again.
Jun 18, 2008 | Pioneer VSX-915 Receiver
VSX-D711
Yes.
There's an integrated circuit that steers all the input signals thru.
That has crapped out.
Jan 28, 2008 | Pioneer VSX-D711 Receiver
The Sound is Gone.
Hi....
The circuits that routes all the audio signals thru the amp has either died OR the power supply that runs that circuit has died.
Estimate to fix : $75-125
Apr 22, 2007 | Pioneer VSX-D711 Receiver
Pioneer VSX-D711 Receiver Logo
233 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
