Question about Ovens
Oven Hi Benimur Maytag Oven (Older Model) CHG9800BAE When I put the touch controls on to start my oven at 350 it usually starts at 85 and takes 10 minutes to reach correct temp. Now, it takes over an hour and the whole house smells like gas. Any ideas? Thanks Jules
  • 725 Answers
Sounds like a oven valve is not opening all the way...
part # VALVE, OVEN 74006427
Posted on Aug 16, 2008
This touch 850 series double oven is only heating up to 170 when dial is on 350 do I have a bad element?
Elements usually either work or they don't, if it comes on the but does not give enough heat the thermostat is bad. If it was cleaned inside recently, check the routing of the stat lead perhaps its kinked etc.
Mar 16, 2015 | Maytag Ovens
I have a Maytag model #MGR5754QDW gas oven. The oven isn't getting hot. I think it is also called a Precision Touch Control 500. The top works fine, just the oven will not heat up at all.
Hi, the likely cause to the problem is the igniter. Pull the floor of the oven out and then the flame spreader. Now set the oven for 350, if the igniter does not glow unplug the range and test the igniter with an ohms meter. If as i suspect it shows open you should replace it. If the igniter is glowing when set for 350 it may still be bad. An igniter should glow bright yellow to the point you can't look at it. If it glows an uneven yellow/orange it's bad and you should replace it. Mike
Dec 18, 2009 | Ovens
Our oven started randomly beeping last night with an error message of what looks like "F1" and when we push a button it stops for only 5 minutes then starts up again. Any suggestions on how to get it to...
Hi. This Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Dec 08, 2009 | GE Ovens
Maytag oven shuts off?
Hi. This is a possible touch pad, or EOC(Electronic Oven Control Board) failure code. The test below will help isolate the issue.
This simple test will help determine whether the EOC (Electronic Oven Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the EOC as a single assembly, in which case this test is not necessary. Simply replace the EOC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 20, 2009 | Maytag MEW5530D Electric Single Oven
F1 error/touch panel not working on GE Monogram Dual Oven
Usually, the F1 means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
I recommend a service call for this repair.
Jun 02, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
F7 code on maytag cwb3100aab 24" wall oven.
Hi, The Function key is shorted or stuck.
Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Apr 11, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Maytag gas oven cycles every 20 seconds
yes it is normal . but i know your not the first to think its not , todays ovens are so tight , it only takes 10 seconds of heat to keep them at proper temp . it used to be that ovens where kept at a 3 degree sweep that is set at 350 turn on and up to 353 then off ,cool down to 350 and back on . this was a longer time off and a longer time on topday we keep to 1 degree ! 350 on to 351 off to 350 on and so on ....... so short berst of heat make for a more even oven ........ but i know i hate it too ! good luck
Jan 18, 2009 | Maytag CWG3100A Gas Single Oven
Front Panel Buttons not responding
The touch control panel is a piece of ****! Call MAYTAG, and get a new one, you should still be under warranty. Make them send you the part direct ( its the WHOLE front top panel ), then call a tech to put it in for $50 bucks. Takes about 10 minutes to do. The panel plugs into the electrical Board behind the panel.
FYI...the Top panel includes the Stainless Panel + the Touch controls! Its all one integrated part. The part that goes bad is the "cable contacts" that latch to electrical panel.
FYI....the Cable is made of "thin clear film " similar to Film you put in a Camera.
Jun 19, 2008 | Maytag MEW6530DDS Stainless Steel Electric...
Thermador Built-in Oven Model SMW272
usually this is because you have the connecter on the touch pad off by a pin or not seated well. sometimes all it takes is taking the front touch panel off, re seating the connectors, and putting it back together. these thermadores are very sensitive to it for some reason. if all else fails, take all of the small multi pin wire connectors off one by one and re seat them. it should take care of the problem if it wasnt there before you started. good luck!
Apr 12, 2008 | Thermador C301U Electric Single Oven
Ovens Logo
167 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
