Error030 fatal error on oki c5200 - Office Equipment & Supplies
    Scholar:
  • 67 Answers
Error030 indicates that an error has been detected in operation checks on the RAM in slot 1. First note the 24-digit addresses (generally 3), then restart the printer. Check reproducibility if possible. Repeat the same operation after restarting the printer and check if the same service call message appears.
Posted on May 25, 2011
Why can't I use a toner and drum set from an OKI c5250 in an OKI c5200
While the drum units may appear the same, chances are Okidata puts a different chip on it that makes in incompatible. The C5200 will use drums from a C5150. The C5250 appears to use different supplies.
Sep 14, 2014 | OKI C5250n Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Fatal error 122 on a oki c5200 printer
YOUR DRIVER CD IS CURREPTED.ANOTHER DRIVER CD USE.
Jun 23, 2009 | OKI C5200n Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Have OKI c5200 Printer Message window reads Service Call 030: Fatal error Mac Mini OSX system What do I do? Prior to Message  Black Ink cartride was low and replaced cartridge after message appeared
I had the same error with an Oki C9600N. Called OKI, and was told one of two things has apparently gone bad: a DIMM (in slot 1) or the controller board. I removed the RAM, cleaned the contacts, blew out the slots (w/canned air), and reseated the RAM. Printer is back up and running. Hope this helps someone.
Feb 02, 2009 | Office Equipment & Supplies
Fatal error 002
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
Take the printer off the network. (Remove the network cable) Then enter the menu and select network menu. You want to change the settings as described below:
Change the Hublink Setting to "100 base tx full"
Change the FTP Setting to "Disable"
Once done and machine says online, shut it off, reattach the network cable and restart the printer.
You may also want to change the printer's IP address.
If this does not help, or you cannot get past the 002 fatal error then the machine will require service.
Aug 08, 2008 | OKI C5200n Laser Printer
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Apr 15, 2008 | OKI C5500n Printer
Oki c5200 "Fatal Error 106"
from your service manual....main board issue
Jan 16, 2008 | OKI C5200n Laser Printer
C5200 printer
177 - Replace fuser
Dec 12, 2007 | OKI C5200n Laser Printer
56 people viewed this question
k24674
jasbo
jasbo
