I recently bought a 13" Koncepts (by Cosmo
  • 133 Answers
SOURCE: Can't watch dvds with my dvd player
Try two different things 1) on some of these tv's you could try pressing 00 to see if it will put you in input mode or 2) with your remote you should be able to push the input or tv/video to go to the input selection . In both of the above make sure you push the tv button first then step 1 or 2 . Good luck
Posted on Mar 07, 2008
  • 21 Answers
SOURCE: input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Posted on Jul 26, 2008
ebrus
  • 30 Answers
SOURCE: Emerson Spongbob tv broken remote...cant change input?
Then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me.
Posted on Oct 15, 2008
  • 1214 Answers
SOURCE: I have sanyo tv with
Try some new batteries in the remote, or, just roll the batteries in the holder.
Posted on Feb 03, 2009
  • 104 Answers
SOURCE: Can't find the input/video channel for my Emerson TV
universal remotes are tricky, if you have the pamphlet, often times there are several codes for each brand. you have to try all the emerson codes for your universal even tho the power, volume and channel functions may work with several emerson codes, some of these specialized buttons (like input) may only work on your TV with one specific code.
also, if there are any unlabeled buttons on the universal try them with each new emerson code.
Posted on Feb 12, 2009
I have a 13" Cosmo Communication TV. It green and white with sprring feature on the buttom corners. i will like to know what is the code for it because my remote control input buttom stop working so i...
Most universal remotes have a self-tune facility and the details will be found in the instruction booklet. They usually also have a helpline which I have heard is generally fairly good.
Universal remotes tend to offer basic functions only and so you could be disappointed to discover only a replacement OE remote will perform the function you require.
Mar 03, 2015 | Televison & Video
Tip
Riding Mower No Start Troubleshooting
  • First check the air filter to see if it getting air and gas.
  • Check your gas cap. If your gas cap is clogged, your fuel tank can get a vapor lock, and you will have no gas flow. Loosen the gas cap to see if it will run longer.
  • Check the gas filter (if you have one on the mower) to be sure it is clean and has good gas flow.
  • Check to see if you are getting spark at the plug. Check out the video below.
If the engine clicks but will not start, the battery or solenoid is often to blame. To find the battery on a riding lawn mower:
  • The battery may be under the hood
  • The battery may be located under the seat
  • You may need to lift the hood to find the solenoid
  • Check the owner's manual for the battery or solenoid location
Check to see that all wires are securely connected and that the terminals are clean.
If the lawn mower still does not start, the problem may be with the fuel, if it was left in the mower over the winter months the fuel may have become stale or watered.. If the fuel appears dirty or contains water, you will need to drain the fuel tank and replace with fresh gasoline.
Other reasons for the mower not to starting also include:
  • Damaged or loose wiring
  • Problems in the carburetor
  • Maladjusted or damaged engine valves
  • A blown fuse
  • Ignition switch may be faulty
on Oct 18, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
The AV button from my remote isn't working at all.I bought a new one but the catalog doesnt have Cosmo Communication TV brand.I would like to know what code I need to put so the AV can appear on the TV.
Read the manual that came with the remote. Most of the time you can find your device when you put the remote in a "search" mode and then you have to press a button several times, till the TV switches off. Then press anything again and your remote should be set up. Something like that should be on the remote for setup. When the TV responds, check all buttons, to see if any of the keys switches the AV.
Feb 24, 2015 | Televison & Video
Cosmo communications corp tv
If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
May 06, 2013 | Televison & Video
Replacing fan. Wires from ceiling are grey pink white & bare copper. Wired to light switch. What wire connects to what? Ok so we just bought the place. The painters removed the old fans that had no...
Sounds like you have two hot wires. Just need to find out which wire goes to the wall switch. Try gray to black from fan,pink to black/white wire.white to white & green to green. If this doesn't work swich the pink & gray wires.
Feb 03, 2013 | Dryers
I have the pink 13"
You will have to use the search method described in the instructions for the remote.
Dec 27, 2010 | Televison & Video
Password problem
Here is a quick fix for resetting your Mac password.
1. Hold Apple+S when your Mac is booting to enter "single-user" mode.
2. Type "sh /etc/rc" without the quotes.
3. Type "passwd USERNAME" without the quotes, replace USERNAME with your actual Mac username you forgot the password to.
4. Reboot your Mac by typing "reboot" without the quotes.
Hope this helps.
Mar 29, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Cosmo Communications DVD Model WPDVD-296 Password.
If you push the eject button so the little lcd screen says open then type in 5168 with your remote. This will take you to a special menu if you go down to ratings then hit enter you can choose the rating you want. You can also set up the password. Default password is 0000. Then hit setup to finish.
Oct 22, 2009 | Televison & Video
Can i hook up PS2 using only the white and yellow jacks?
i download and read your owner manual .
http://www.funai-corp.com/6pdf/om/DWT1304.pdf
i do see you only have a video and a mono sound input jack , so , your ps2 as in all RCA style jack inputs , yellow is video , red and white is audio , i will assume you have yellow plug in video and red or white in audio , and on your TV remote you hit the GAME button , i'm suprised they don't use the term VIDEO , but , anyway , are these the steps you have taken ?
Dec 30, 2008 | Durabrand DWT1304 13" TV
Durabrand 13 inch tv
the remote need to clean pcb board ..... the chroma section pcb need to resolder loose parts such as resistor, capacitor or transistor that you may see on it.....
Feb 27, 2008 | Durabrand DWT1905 TV
Televison & Video Logo
339 people viewed this question
Top Televison & Video Experts
