Question about Toshiba DR570 DVD Recorder
I recently purchased a new Toshiba DVD recorder DR570. This has 5 recording modes,1,2,4,6 & 8 hours- I have experimented with all 5 modes and find that I am only getting approx half the recording time in each mode . I am confused by the formatting instructions for a DVD-RW,you have to set for VR mode or video mode, how do I know which format to choose and would that affect the recording times ,or is it simply a fault with the unit ?
    Top Expert:
  • Toshiba Master
  • 74,383 Answers
Hello
Before start predetermined recording modes, be sure the clock has been set to current time. this is most important.
[1] Turn on the TV and press
[ON/STANDBY], and be sure to
select the input of the TV to which
the unit is connected.
[2] Press [OPEN/CLOSse] to open the
disc tray. Place the disc to record on
properly.
[3] Press [OPEN/CLOSE ] to close the
disc tray.
[4] Select the input of the unit which the
external device is connected. (L1, L2
or L3)
[5] Press [REC MODE] repeatedly to
select a recording mode
[6] Press [ REC] on the unit to start
recording
Posted on May 25, 2011
  • The Knight
    The Knight May 25, 2011
    From these proceedings, still you feel the troube, surely there is some fault with that unit. Repalce it immediatle. Timer recoding and mode recording section inside the set if faulty. OK.
Want to copy vhs to dvd.
I convert VHS to DVD using a Toshiba DVD Recorder that I purchased from Costco a few years back. I plug the VCR into the DVD recorder using RCA jacks, press PLAY on the VCR and REC on the DVD recorder and let it sit and record. I can record up to 8 hours of video onto one DVD at low quality. After this, I finalize the DVD so it can be read on other DVD players.
Jan 03, 2012 | Hitachi DV-PF33U DVD Player/VCR
I recently purchased the Toshiba DR570KU DVD recorder. I live and purchased this machine on a small Caribbean Island,and with respect to local people they have no technical knowledge of what they are...
Hi -
I'll try to explain without confusing you any further, but if anything doesn't make sense, please let me know. The instructions on page 79 are contradictory, which doesn't help very much. The upper part of the page suggests you can create extra space on a DVD+RW disc by deleting titles, while the lower part, in the grey box, states you cannot. The bottom part is actually correct.
I'll split this into two sections - blank/unused and used discs then explore a few scenarios.
Blank/unused discs
A DVD+RW is typically 4.7GB and will record approx. 2 hours of video in SP mode or 4 hours inLP mode. If you record more than one programme, they will appear consecutively in the disc editing menu, and shown as numbered blocks in the Title List. The last block shown will always be 'EMPTY', but the actual size of this block can be all or none of the total capacity of the disc.
If you insert a blank DVD+RW disc into the machine and view the title list, you will see this:
Although you can't 'record' to a block labelled EMPTY, this doesn't mean you cannot record to this disc. The blank space on the disc precedes the block labelled as 'EMPTY'.
If you then record one programme of 1 hour duration in SP mode. the title list will look like this:
Once again, although you can't 'record' to the block labelled EMPTY, this doesn't mean this disc is full or that you cannot record anything else on it. The next programme recorder will appear between title 1 and the 'empty' block - as long as there is sufficient space on the disc remaining to record the programme.
If you then record a second programme of 1 hour duration in SP mode. the title list will look like this:
This disc is now full as 2 hours of video has been recorded in SP mode. However, if you'd only recorded 1 hour in total for these 2 programmes, you would still be able to record another hour of video in SP to this disc. The additional programmes would appear between the last numbered title and the 'empty' block - until the disc is full.
The empty block is always present and you cannot 'get rid of it', but it doesn't mean the disc is full or cannot be recorded on.
Hopefully, this goes some way to explaining it, but I still need need to explain what happens with used / full discs when you want to delete programmes and re-record.
There is a maximum length for messages posted on FixYa and I may be getting close to this, so rather than break off in mid-flow, I will continue the explanation for used discs in another message below this one. I will do this right now, but it will probably take me 20 minutes or so to write part 2, so keep checking back. It will be less confusing if you hold any questions until I've written part 2, but I will be happy to answer any after that.
Regards,
BElectric
May 02, 2011 | Toshiba DR570 DVD Recorder
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
Toshiba DVR19DTKB2 user manual
i have a dvr19dtkb2 video and dvd freeview recorder it has froze on channel 800 tried unplugging it still froze when turned back on can you help please
Oct 12, 2010 | Televison & Video
Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
May 28, 2009 | Toshiba DRW2 DVD Recorder
EVERYTHING YOU NEED IS IN MY LETTER BELOW.
1. On your remote, find the record mode button; it is near the bottom on the left side. This button sets
the recording speed for the DVR. Faster recording speeds provide higher quality recordings.
2. Look at the display on the front of the machine: it should say XP ( records 1 hour on the disc,)
SP ( 2 hours, ) LP ( 4 hours, ) or EP ( 6 hours. ) You can also set it to record 8 hours on a disc,
but the quality of the recording will be poor.
3 Press the record mode button until the screen displays the recording speed that you want.
4 Note: if the powers fails or the Machine is unplugged, the machine will automatically reset itself to
SP mode.
Apr 29, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
SCREEN SAYS "SAFE" ?DO IDO TO GET RID OF IT???????/
To remove "SAFE" from the front display, using the remote control, press and hold "INFO" for 5 seconds until it disappears. This was probably acitivated while you stopped a recording which can trigger it, of you may have activated "Safe" by pressing the INFO button several times. This is to prevent access of the recorder by locking all controls. This is for the DVD Recorder/VCR combo VR320 and the 1st generation DvD Recorder DVR-130.
Even though this was a product I regret purchasing, it isn't as bad a people make it out to be. It works best with DV cable recording from 1 Hour Mini-DV tape camcorders to 1 Hour XP Record DVD mode. It is probable one of the best. Only issue I have is when you try playing a finalized DVD-R disc in another DVD player, there is a chance it might not work because of the Highest quality 1 Hour record mode. Standard is 2 Hour SP. You will have to burn an exact copy using DVD copy software on your computer to DVD-R. This will fix the problem.
May 31, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
DVD copying
There are double layer DVD's that they make which usually have about 2x the memory. check to see if your DVD recorder supports these types of DVD's. You could also just divide your media on to two sides of a double sided DVD (each side has the mirror look and you can record onto both sides)(still the same disc) or you could record on to multiple DVD's (may be inconvenient but is still an option). Also, you could reduce the recording quality just a bit so that it is not noticable when you watch it but it still uses less space on the disk. I would tell you how to do these things but I have no experience with the individual model that you have.
Mar 22, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
How long can I record using a DVD-RAM disc?
• Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Toshiba DR570 DVD Recorder Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
