Question about Microwave Ovens
Recently purchased a used Hoshizaki Cube Star model KM-452DWU for my church. Need a manual or instructions on how to hook up the water supply. The cooling water inlet and outlet is marked AND what I suppose to be the ice water inlet which is connected to the cooling water inlet. There is a small plastic drain BUT what is the larger connection at the bottom of the ice making/cooling unit. Is it another drain?
5 Suggested Answers
najah
  • 180 Answers
SOURCE: I have a Sharp Carousel microwave model R438DV 1200 watts. There is a small 5x7 screen on the right side wall. It now has a small hole and has char marks on it. When I use the unit a fire starts o
You have to replace that small screen which is called wave guide. If there is a sharp authorised service centre near to your place you can buy the part from them. Do not work the oven without replacing that part.
Posted on May 30, 2009
woodchuck789
  • 4070 Answers
SOURCE: Model # trt18GREW5 ice maker will not make ice,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Water doesn't flow unless the ice maker calls for water which it does immediately after dumping the previous load of ice.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Posted on Dec 18, 2009
espressonist
  • 1711 Answers
SOURCE: DCE33A-1BC Scotsman Ice Maker will
From your description it seems that the refrigeration system of the ice cube is not cooling enough. For this reason the production per day is much lower than it should be. That is why the unit never stops since by the time it have produce new ice cubes the first ones already melt. So it can never be able the ice been container to full enough to rice up to sensor bar.
So first you should reach for the condenser and with a brush and a vacuum cleaner try to clean it from all the dust on it. This will increase the capacity of the cooling system.
You need also to check that the condenser fan is working since if it don't then you will need to replace it.
If the two above case are ok then you need to check the freon charge and it might need some additional Freon charge, but this is not a DIY job since you will need special expensive tools and also a license to deal with freon.
In any case try the two first cases since are the most possible ones.
Posted on Feb 03, 2011
vko007us
  • 254 Answers
SOURCE: I have just been given
Plz specify the make & model no of ur microvave to avail the manual..for any other support plz revert
Posted on Aug 20, 2011
WE NEED AN INSTRUCTION MANUAL FOR OUR CHURCH'S 3.6L MICROMARK DUAL COFFEE MAKER
Hello there, can i get more specific instructions about the model of the coffee maker. A specific model number would be helpful as well as a country of origin. Hoping to hear from you soon.
Thank you for visiting FixYa.
Sep 11, 2011 | Microwave Ovens
Hi, i bought recently a mini oven, but the problem that i lost the cataloge and i don't know how to use the buttons. i have bottons with fans, and buttons without. what is the difference between them?
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 28, 2011 | Microwave Ovens
Magic chef mcd990b,microwave, purchased 3-17-11 from kohls, need the manuel
I hope this helps.
Mar 17, 2011 | Magic Chef CHEF9 Microwave Oven
I need a hook dogh a701 kenwood mixer
I hope this helps.
Mar 14, 2011 | Microwave Ovens
There was no manual inside packing box when purchased. the model is MGE25 for the Hitachi microwave.
I hope this helps.
Mar 10, 2011 | Microwave Ovens
Where can I get an instruction manual for a Breville combi microwave oven. Model No BRE997SSG. It's about 5 years old, but like new, and was recently given to me. Thanks Patricia Robertson
I hope this helps.
Mar 07, 2011 | Microwave Ovens
I don't know how to use my microwave oven due to have no instruction,, my manual is not in english,, i need english manual instruction,,
I hope this helps.
Mar 02, 2011 | Microwave Ovens
I would like to purchase the dough hook for my Braun mixer - Model No. KM 32B. It is an old machine but still works very well. If available I could have the hook sent to an address in the UK
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service, as required.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Jan 09, 2011 | Microwave Ovens
I need to know operataing procedures or the user manual for bajaj microwave oven model :2100 etc
Sir/Madam
I have purchased a new bajaj microwave oven 2100ETC from Alive star cj through tele shopping. Just after purchase this oven is not working in microwave setting. Please suggest me how to use this oven in microwave setting.
Oct 27, 2010 | Microwave Ovens
Microwave Ovens Logo
55 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
