Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
I recently changed my carriage belt.The print quality has ever been so bad.Does not print clear lines,especially with the black ink.Always have some white lines within...Thank you. Nima
  • 4 more comments
  • nima saani May 25, 2011
    The plotter is hp designjet500.You mean i cld wash the printhead?Thank you
    i recently replaced the carriage belt of my hp designjet 500.The print
    quality is now very bad especially with the black ink.It does not print
    straight black lines.There is a kind of shadow print with white lines
    within.Thank you.
    Nima
  • nima saani May 26, 2011
    i cleaned it with running water.The ink seem to be flowing out easily.But it's still not giving good quality print.Is the process possible without ammonia.I don't have any presently.Thank you
    Hello Alpug,when iwent through through the process,the ink was flowing so freely with the distilled water.After putting it back,the print is still no any good.
  • nima saani May 27, 2011
    Hello Alpug,
    well,i got a new printhead and the printing is pretty good now,but the other is issue is,the plotter stops in a middle of printing.The carriage stops the service station and doesn't continue or sometimes complete the printing on the next page.
  • nima saani May 30, 2011
    Hello Alpug,
    I asked you a question about my plot stopping midway but you since not replied.Waiting to hear from you as soon as possible.Thank you
    President:
  • 1,961 Answers
The printhead for black ink cartridge could be blocked.
It is better to run the Clean Printhead operation on your printers tools option.
You can manually clean the print head so that next time when you execute the Clean Printhead from HP solution center it will be successful.
First, remove the printheads.
then, pull up the lever at the top of the cartridge holder, this releases the print head.
The print head could be blocked, most common is the dried ink blocking the small holes in the print head.
Washed it in running tap water. It is best if you soak it in a mixture of water and ammonia and leave it overnight.
After soaking, you can spray it with canned air and blow those little holes to unclog it. Once it dry, return the print head and the ink cartridges and performed the alignment.
this video will show you how
Posted on May 25, 2011
  • Danilo Baraquiel
    Danilo Baraquiel May 25, 2011
    Hello Nima!
    First of all I want to apologize for giving you a wrong video of a different model because I thought it was officejet pro 8500.
    The answer to your question is yes! But not the whole part of the printhead, just the nozzle where ink flow out. The part at the bottom of the print head.
    Remove first the the black printhead. Examine the nozzle below it. You can place it under running water to unclog. Or leave the nozzle part soak on a mixture of ammonia and water solution to remove the dried ink.
  • Danilo Baraquiel
    Danilo Baraquiel May 26, 2011
    Using a mixture of ammonia and water is the last option to consider. If resources is not on you at this time, it is better to flush the printhead properly.
    flushing the printhead of the cartridge directly
    from the tap water ....Open your printer cover, remove the
    cartridge..place the printhead directly on a tap water running slowly.
    This will help flush the dried ink that clogged in the printhead. Turn
    the print head over, bottom side up until you see the ink flowed out
    from the printhead, do this until you see the a smooth flow of
    ink..(better result if the water is warm).. tap water contains residual
    minerals that can clog also the printhead..so it is advisable to final
    flush the printhead with a distilled water (it has no impurities) and
    dry it with cloth..
    As substitute to ammonia... soak the printhead portion of your cartridge in a
    hot distilled water, (please make sure that the
    contact point of the cartridge to the printer is not soak).. Place the
    printhead on the hot water and leave it there for about 4 to 5
    hours..move it on different location from time to time..After soaking,
    rinse it with distilled water and dry it with cloth...
    After doing the instructions, return back the cartridge to the printer and do the printhead alignment..
    Try printing a test page and see the outcome..
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
When printing all black areas have vertical lines going through ,have cleaned print heads and changed toner - no change in quality.
Clean the encoder strip, the clear plastic band that runs behind the print carriage. A Q-tip damp with alcohol will wipe off any grease or ink. You'll find a grease spot just above the area on your print that has the vertical line.
Jan 15, 2010 | Canon PIXMA MP130 All-In-One InkJet...
White lines across print
If you lay the print on the exit tray face up and open the cover. Look on the encoder strip, the clear plastic strip behind the carriage, you should see an ink or grease spot right above where the bad spot on the page is. Wipe the encoder strip with Q-tip or wiper with alcohol. Prints should look better.
Jan 08, 2010 | HP OfficeJet Pro k550 Printer
How do I change ink cartridge on my HP inkjet 6500 wireless printer.
Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
The methods of replacing the ink cartridge of the printer follows here:
Open the printer cover
The printer ink carriage will automatically goes to center
Once the carriage is in the center, the printer was ready to replace the ink.
Pull the down slowly the ink tank off the carriage..
Remember the place where the color/black position.
Remove each tank one at a time, and replace the ink with a new one.
Close the printer cover and it now ready to printer.
HP Deskjet 6500 Series Printer - Setting Definitions
Hope the instructions provided helps.
Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
I have just changed my black ink cartridge however still patchy
Typically you do not have to change the color cartridge when you replace the black cartridge.
As far as the spotty printing, it sounds like you have some clogged nozzles caused by the lower quality of ink in refilled or aftermarket cartridges. There cartridge inks may not be up to specification. This is especially true for the ultra fine printers.
To clear the problem you need to insert an OEM cartridge, run the deep nozzle cleaning utiliity at least twice followed by the alignment utility. This should clear up the problem with the spotty and washed out printout.
Let me know if this solves your problem otherwise we can explore other solutiions. For the record, which printer do you have?
Please rate this solution. Thanks.
Oct 07, 2009 | Office Equipment & Supplies
Problem with printing in black writing not clear and very faded.
It sounds like you need to run a printhead cleaning. The print head is what you put the ink cartridges into, it's responsible for placing ink directly to the page. If the some of the nozzles are clogged up, it can give you bad print quality. Without knowing the exact model of your printer, I can't tell you exactly where to find the menus needed to run the cleaning. Sometimes you can do this via the "maintenance" tab in the printers properties. If you need any further assistance, feel free to let me know.
Jul 30, 2009 | Brother Office Equipment & Supplies
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
HP Officejet 7310 carriage jam
I'll start by explaining some of the components you need to understand to troubleshoot the carriage system.
The Carriage is the thing the cartridges are mounted in, it slides on the carriage rail, the bushings in most newer carriages are made of plastic, (or maybe it would actually be called a polymer, or composite material). The bushings are the pieces that wrap around the carriage rail.
The carriage rail is a shiny round rod that the carriage rides on, it is driven across the rod by the carriage belt, by the carriage motor, at the opposite end of the belt there is an idler pulley, ".
In a HP printer the device where the carriage parks, (sits at), when the machine is not printing is called the service station, it is responsible for cleaning the print heads, and for capping the heads when you are not printing, (so they won't dry up). The bottom of the service station is the "Spittoon Base", ink is spayed into the base before printing to prime the heads, there is an absorbent pad in the base to soak up the ink. Note that the pad does not always soak up all the ink, so if you tilt an HP printer you can spill the ink out of the service station, (especially if it is a heavily used printer). The piece that moves back and forth in the service station is the "Sled", it was wipers to clean the heads on it, and the caps that keep the heads from drying out are also part of this assembly. The sled is moved back and forth before the carriage leaves the service statio to wipe the heads, this happens after the heads are primed, then the carriage is moved off the service station and the sled is again moved back and forth to clean the wipers.
The encoder strip is a plastic timing fence that looks clear at first glance, but has black lines painted on it. The strip is threaded through an optical sensor on the back of the carriage.
When the printer initializes the carriage has to leave the service station, or, if the machine was powered off when the carriage was somewhere else, whatever spot it is sitting in, and travel the way to the other side of the printer, and then return to it's home position which is the service station.
When the carriage reaches the side of the printer away from the service station it sets that as a reference, then it counts lines on the encoder strip as it travels home, if it doesn't see enough lines before it gets all the way to the other side and can't move any more then the printer decides the carriage must have something blocking it.
Sometimes a service station will fail in a way where the sled does not retract fully, if that failure happens when the carriage is parked then the carriage will usually not be able to leave the service station. If the service station binds when the carriage is off of the station, then the station may not be able to move all the way to that side, and will detect a carriage jam. When the service station binds you might hear a grinding noise as it's motor tries to drive the sled back and forth.
If the encoder strip is dirty the printer may not see all the lines and detect an error, often when the strip is dirty the carriage will move too fast and slam to one side of the printer.
I use water to clean the encoder strips in HP printers, water works well on water based inks, if your printer uses ink with another base you might use alcohol, but "ONLY" if the ink is not water based.
One end of the encoder strip is attached to a spring mount, if you wipe the strip starting at the end that is attached to the frame, and wipe only towards the spring mount, then the strip will stay attached to the printer.
A dry carriage rail will cause the carriage to bind, if the carriage does not move fast enough a carriage jam will be detected. Some newer HP printers use grease on the carriage rail, many models use a liquid lubricant, Use "ONLY" light synthetic or silicone based lubricants on printers that use a liquid lubricant, Petroleoum based products may melt the plastic bushings and ruin the carriage. (YES, Petroleoum based means WD-40)
some HP printers have a timing disc on the service station, and if the service station binds, or the timing sensor fails they report a carriage jam, but as far as I've seen that jam always occurs before the carriage moves.
You can use a synthetic lubricant on the carriage rail :hope this helps
Jan 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
206 people viewed this question
Seeker5211
Seeker5211
