Question about Frigidaire Dryers
Laundry soap was spilled on top of my dryer and leaked into the cracks of it which leads to all the buttons. It won't work now. Please!!! Help me..what can I do to fix my dryer?
imufo2
  • 3773 Answers
SOURCE: I have a stackable washer
First check your WASHER. IT MAY NOT BE RINSING AND/OR
SPINNING THE CLOTHES DRY ENOUGH.
I would suspect not rinsing more tho.
Leo Ponder
imufo2@sbcglobal.net
Posted on Jul 30, 2010
TheMobilian
  • 8220 Answers
SOURCE: The soap door is in the front of the machine.
Problem:
The detergent and softener dispenser is gravity feed and builds up with "gunk". It has to be cleaned regularly and while the tray is removable, the inlets are not; so you have to fish out the sludge with a paper towel.
Solution:
This common on almost all front load washers.
Remove the dispenser tray. Remove the blue liquid detergent cup. Add all to the top rack of the dishwasher---run a cycle. This makes much less a chore of cleaning the dispenser tray assy.
I have your service manual along with notes on these washer problems and solutions HERE
Posted on Oct 17, 2010
caroldon
  • 17130 Answers
SOURCE: Model 6800AYW Neptune dryer won't
It seems quite possible that the fault seems linked very closely with the main program controller unit. So it is important to take the program controller unit and check on the power to the processor. Check the power supply voltage and voltage feed to the processor. If the processor in not reacting then it might be best to change the board as a whole.
As a final resort, check or solder the board connections,check all leads and connnectors to see if the board/processor resets.
Posted on May 14, 2011
heatman101
  • 43501 Answers
SOURCE: Soap door is open when cycle is over but soap does
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenanceDishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Jun 01, 2011
heatman101
  • 43501 Answers
SOURCE: my maytag dryer got to hot heating a blanket and
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jul 05, 2011
The soap compartment has water left in it
does the unit work? if so, dun worry about the water. unless the soap has not been gone into the wash?? do not use powder! these are liquid soap washers! lol.
Apr 13, 2014 | LG 14-inch Front Load Washer/ Dryer Top...
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Sears laundry center 92702 burning smell and won't drain spin out
If the motor is running and it won't drain or spin, then the motor coupler has failed and needs replacing. Here is a link to the part.
Here is a video to show you how to replace the coupler. If you could post the model number that is located on the unit I can get you the service manual to help you a little better.
Oct 18, 2012 | Sears 24 in. Electric Laundry Center with...
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
My maytag dryer got to hot heating a blanket and now it won't work at all. When u push the power button I feel it wanting to kick in but it won't do anything!! I know nothing about dryers Help...
heatman101
Jul 04, 2011 | Maytag Dryers
Water Leaking From Calypso, Won't Drain Completely
the bag type device is an overflow and should never have "water"in it, but it will get suds if you are using the wrong type of soap.
you need to use "HE" soap as it is a non-sudsing soap and thats why you are getting suds leaking from your unit.
just run the rinse and spin cycle until the suds are gone. then use the right type of soap and it will work properly with no leaks.
Jan 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Hotpoint Ultima WT965 - Water gushing out from door and soap drawer
in this case i would remove the pump (bottom, back, right hand side)
this is easy cleaned.... then remove dispenser and dropdown pipe and clean out clogs
Jul 29, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Water won't work but dryer does
Mine did the same thing and it ended up being an overloaded older breaker in the electric box. It would allow the dryer to work, but the washer was too much for it to operate. Had the breaker replaced with a new one and it works fine. Hope this helps!
Jun 14, 2008 | Frigidaire FEX831CS Top Load Stacked...
I put laundry soap in the dryer by accident
DO NOT pour water down the lint filter of a dryer! This could have catastrophic results. There are live voltages present in a dryer even with the power shut off. You have a blower fan and a motor in the air baffle. Pouring water in there will definitely damage something (if the soap hasn't already). Detergent is a corrosive and will damage anything electrical and any painted surface if left too long. I hate to say it, but you must open the dryer up and remove the air baffle and clean it out thoroughly. Unplug the machine before you attempt. You need to wipe up all the soap residue with rags. You will need to let me know if the dryer has a lint filter on the top of the machine, or in the door before I can suggest how to disassemble. This will make a big difference in the amount of effort required to correct this. Post me back with the info...
Aug 08, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
81 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
