Question about Kitchen Ranges
Need to know error codes E.OC1 & E.OC3 is telling me on this inverter, mitsubishi+FR-Z320-7.5k-UL Thanks, Roger
SOURCE: HOBART HL200 error code oc3.
For $9.95....I'll tell you
Posted on Dec 11, 2008
SOURCE: mitsubishi inverter
mitsubishi fr-520s-02k-ec inverter drive.
Keep flashing a P5 code and will not reset. With the rest button.
How do I reset
Posted on Jul 01, 2009
protek480
  • 1714 Answers
SOURCE: mitsubishi inverter FR-A024-2.2K
www.newark.com
Posted on Jul 03, 2009
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi ws-65809 powers on for 2 seconds.
2,2 error code is short protection---98% of the time it means one of the two soldered in pico fuses this set uses is blown----there are several---but your problem means if it is ws-65809 one of the two stk-392-570 convergence chips has failed.
I will attach a photo---they are on the middle circuit board and the two to the right are for convergence--both are green and 5 amp--with the set unplugged check both of them like any fuse--no reading means bad.
If you find this--I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET--SHOPS WILL GET 300 or more but you if you can do it yourself buy everything you need for under 40 dollars--I can tell you the best place to get the chips, fuses, etc.
If you want the instructions let me know and I will post them here for you---they are based on my own actual experience doing this repair in this kind of set hundreds of times.
If this information helped you rate this solution as I do this here for free.
SD TECH
Here is a photo of what the two chips look like--The one in the picture says 392-560 but yours uses two that look just like it--STK-392-570.
Posted on Dec 28, 2009
Testimonial: "SDTECH provided me the information I've been seeking for the past 2 years, and he did it the same day as I posted the problem. YEA!!!!!!!"
app_3rp12227
SOURCE: Trouble code is gen fr.
it's your alternator (64)
1 Engine control module malfunction
11 O2 sensor malfunction (Car usually runs weak when this code appears) (If a V6 this relates to the O2 sensor on the drivers side In a 4x4 Or the one at the back of the engine on a Galant)
12 Mass air flow sensor circuit malfinction
13 Intake air temperature sensor (Comes on if you have chucked the sensor away to fit some big fancy K&N induction kit!)
14 Throttle position sensor fault
21 Engine temp sensor malfunction (Check the spark plugs too because they carbon up if this sensor is causing the car to run rich)
22 Crankshaft position sensor (Try cleaning the dirt off the end before replacing)
23 Camshaft position/distributor hall sensor (Common on Galant 1800)
24 Vehicle speed sensor
25 Barometric pressure sensor (Another name for the MAP sensor)
31 Knock sensor circuit
36 Ignition timing adjustment connector fault
41 Injectors circuit malfunction
44 Ignition coil/ignition amplifier cylinders 1 and 4
52 As above for 2 and 5 (on a V6)
53 As above for 3 and 6 (On a V6 too)
54 Immobiliser control module to engine control module malfunction (comes on if you have changed one or the other and not had them programmed in by Mitsi)
55 Idle speed control actuator malfunction (A good injector cleaner and a thrash up the motorway usually fixes this!)
59 O2 sensor (if you have a V6 this is the sensor on the passenger side ona 4x4 and the one at the front on a Galant etc.)
61 Transmission control module/engine control malfunction
62 Intake manifold air control actuator/position sensor malfunction
64 Alternator malfunction (remember to check under load and when revved up)
71 Traction control vacuum solenoid malfunction (check the pipes for leaks)
72 Traction control vent solenoid malfunction (usually blocked with dirt)
Posted on Jan 26, 2012
Can anyone give me some advice on the details below? Thanks.
if people using a similar washer as yours are having problems there are two possible explanations
one is a problem in the design of the washer or in the program board and the other is the inverter is not large enough to cover any extra current draw from the machine
At this point I would be getting the machine , brake resistor and settings checked as that will cause excessive current draw as the motor is tripping the thermal / overload switch
you operating temp environment is no greater that anywhere else in the world
call in a service technician to have your machine fully inspected and any adjustments made
Jun 11, 2016 | Speed Washing Machines
What is error e6
e6 error air conditioner Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your e6 error air conditioner question. Get free help, tips & support from top experts on e6 error air conditioner related issues.
air conditioner e6 code Questions & Answers - Fixya
...one inverter 12k I have a DeLonghi one inverter and when I want to turn On the heater then the code error display E6 and the error code is Communication ...
1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 1 of 3 for Mitsubishi Electric .... Ductless Air Conditioner ...
Jan 23, 2016 | Heating & Cooling
Fr-s520e-0.4k manual ac vfd
www.999mitsubishi.com/support.html
https://www.hmisource.com/otasuke/files/manual/.../new/.../mit_freq.pdf
Jun 13, 2014 | Inverter Mitsubishi Fr-s520e-0.4k Freqrol...
I put my car on a scanner and got this code...generator fr internal, what does it mean? its a mitsubishi eclipse
Call the dealer and ask them what that means. They know your vehicle better then anyone and could tell you in a second
Aug 21, 2013 | Mitsubishi Eclipse Cars & Trucks
Inverter error OC3 (over current fault)
Here is a complete guide must have Adobe Reader it's PDF... You will find the error code in this manual and more information on it.
http://www.stroeter.com/preview/_upload/51_00_ENG.pdf?documentID=4934
Mar 25, 2012 | Electronics - Others
When run comand is enable I get an error OC1. I disconnected the load and still get the same error. The inverter has been working fine for the last three years
Overcurrent on acceleration is what the code is supposed to be. There may be a capacitor failing in the finals of the output stage, or a resistor has shifted value..
Sep 04, 2011 | Toshiba Tosvert 130g2 Transistor Inverter
Mitsubishi inverter
How do I reset
Jun 06, 2009 | Xantrex Technology Ags Harness Cable...
Kitchen Ranges Logo
143 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
