Question about Bose Companion 5 Multimedia Speaker System (3-Piece)
I bought a System 5 from US with 110 volt. How can I change it to 240 volts? Sydney. Australia
    Sergeant:
  • 158 Answers
The best solution will be to buy a power converter 100V to 240V according to the power consumption of the device, that must be written on the device or in the technical guide. However, it's not more than 200W.
Posted on May 25, 2011
    Scholar:
  • 79 Answers
Hello, I searched around to see if there was any way to change the voltage into the speaker system, unfortunately there's no way to change it internally, so you have to buy a transformer from 240 volts @50 Hz to 110/115 volts @ 60Hz, plug the transformer to the outlet and from the transformer outlet to your speaker system. The rest of the connection settings are in your speaker system manual. You can get a transformer in any Radioshack store.
Check the transformer outlet matches the American standard.
Have a nice day.
  • 25 Answers
You use the conveter to convert the volt.
Want to know if I will be able to use Sony Bravia KDL 32S4ooo bought in Australia, in South Africa?
if south africa power supply is 240 volts then yes -but -- you will have to go to the onscreen menu and change the setting from PAL to what ever is used in south africa
if the voltage is not 240 volts then leave the set behind
Jan 14, 2017 | Sony Televison & Video
Is a Rowenta DW 5080 240 volt available for Australia
all electrical equipment imported into Australia have to conform to Australian electrical regulations and that includes insulation properties ,voltage
Basically if it is not on the market then it is not 240 volts so if you are considering buying overseas then it is not advisable as it will be the wrong voltage and will fall short in meeting the strict regulations for electrical equipment
Aug 22, 2015 | Rowenta Dw5080 Focus 1700 Watt Steam Iron...
Ion tailgater speaker - changed the ac switch from 240 to 120 and now it wont work? Live in uk if it helps
Hi
The fact that you live in the UK is key to this. The mains voltage in the UK is normally 220 - 240 volts and your system should be set to 240 volts. If you changed the voltage switch to 120 volts and then tried to use it, you will have connected circuitry within the box designed for 120 volts to 240 volts. This will have damaged some of the circuitry for sure.
Your best bet is to return the ac switch to 240 volts and hope that the 120 volt and 240 volt sets of circuitry are completely isolated from each other within the box, so that resetting the ac switch will allow the kit to work.
I strongly suspect that the kit will need to be professionally repaired, and will be useless until it is.
Not perhaps the answer you would have preferred but hopefully of some help, if so would you please register that with Fixya
Cheers
Mar 06, 2015 | AC Cars & Trucks
I just bought KitchenAid Artisan Stand Mixer KSM150PS with 110v and 60Hz online and received it today and realised I cannot use it on australia. Can I use transformer which I can get here to convert 110V...
You need a Step Down Voltage Converter (also called a Voltage Transformer)
which steps down 240, 230, 220 volts to 110 volts and
allows you to use 110 volts Devices from USA in 220 v / 230 v / 240 v Countries
Aug 10, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Activem1 usb 320 speakers. Live in Australia. Right speaker does not have voltage select switch. Only supplied with american power cord. Can I plug an Australian power cord straight into 240 volt...
No you cannot plug it directly into 240 volts, you will damage your speakers.
You need to get a step down transformer 240 volts down to 115 volts. These are available from Jaycar. Make sure you select a unit with a wattage equal to or greater to the wattage rquirements of the speaker system otherwise you will overload the transformer and it will fail.
Jul 04, 2011 | Computers & Internet
I bought an AOC 2036s monitor in the usa, came back to australia to connect it to my laptop as a second screen. yet it wont seem to work, i keep getting no signal. the box saids compatible with XP, yet...
USA mains equipment operate on 110 volts. Unless the AOC monitor can operate on multi voltages ie 110 to 240 volts, when you connect 110 voltage equipment into 240 volts mains in Australia you most likely will damage the AOC monitor.
To operate equipment that has been designed for 110 volts, you need to purchase a step down transformer from 240 to 110 volts that has suitable wattage rating for the AOC monitor.
Feb 24, 2011 | Computers & Internet
I just bought a maytag 24 inch double oven.it is 240 volt and i need to know if i need to put a 3 wire or 4 wire for the power
I trust that your voltage system in your house is 240 volt. The number of wires or the size of the wiring will depend purely on the kilowatt rating of the oven. Normally on a 240 volt system a 3 wire 32 amp circuit will generally be used on ovens/ranges up to at least 6.0 kilowatt. If you need more information please reply.
Feb 14, 2011 | Maytag CWE5100ACB Oven
Will they work in Australia where we have 240 volts?
Yes if this UNIT has the specified mains voltage set for 240 volts then it must work in Australia.
If you have to bring up the voltage from a 120 volt supply then USE a STEP-UP transformer with a conversion factor of 120 volts in the primary to a 240 volt in the secondary.
Nov 16, 2010 | Whynter SNO ICE-100S 3 in 1 Portable Ice...
I have a 1997 caravan in Australia, in the caravan is an Electrolux three way refrigerator, it operates OK on 240 volts, I expect OK on gas, but it isnt working on 12 volts, I checked the power supply at...
chances are the power inverter has gone,(it takes 12 volts upto 240)
easy to check,use a lightbulb and the two wires to check power output.BE CAREFULL NOT TO TOUCH THE WIRES.
Sep 10, 2010 | Electrolux Refrigerators
Bose Companion 5 Multimedia Speaker System (3-Piece) Logo
314 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
