Gemini GX-250, amplified speaker has power but no output
  • 44 Answers
SOURCE: Denon Power AMPLIFIER
Try these links
http://ca.denon.com/ServiceCenterLocator.asp
http://www.fredsoundofmusic.com/denon_audio.html
Hope this helps!
SEO EXPETS - Increase Search Engine Ranking / Position
Posted on Dec 16, 2007
leecom72
  • 4806 Answers
SOURCE: Hardly used this amplifier in conjunction with a Panasonic TV Quintrix
just about any decent amp with surround sound capabilities will solve your problems there !!! all you need is male - male phono jacks and your away
Posted on Sep 11, 2008
srinivasb81
  • 51 Answers
SOURCE: Center channel speaker output problem
Check for the speaker separately for proper working? If needed change the speaker and check it ok.
Posted on Jan 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: Amplifier Power & Speakers
It's a common misconception that a high-powered amplifier will hurt a speaker when the opposite is more true.
Power ratings are specified within certain parameters at or below certain distortion levels. The problem with UNDER-powered amplifiers is that when they reach for the loudness beyond their clean capabilities they get really dirty and start to distort their output. Distortion will kill even a good speaker faster than a loud clean signal will. Stronger amps run more within their comfort zones and rarely strain for more than brief periods.
In no case should you ever try to do like Spinal Tap in their Mockumentary and turn the volume to '11'. ;-)
The HK's are fine. Speakers are a matter of (mostly) personal preference while amps running within their design limitation don't really sound different so go try out some speakers, see if they'll let you audition them at home and have some fun.
Posted on Apr 28, 2009
  • 40 Answers
SOURCE: connecting a car stereo to an amplifier
you have to connect your 4 speakers to 4 speakers output direct to your car stereo no need of amplifier to 4 speaker but speakers should be small not like a woofer, and you have to connect your sub woofer by using amplifier don't connect direct. connect the output of your car stereo (using 2 RCA) to the 2 RCA inputs of amplifier. If u connect your 4 speakers to your amplifier then your car stereo does not support Left Right channel.
You can also connect your laptop or iPod direct to your amplifier.
Good Luck
enjoy music
Posted on Nov 24, 2009
Testimonial: "very helpful. Thank you"
Have a xga 4000 amp only channel 2 works fine . Channel 1 very very low
Switch input connection pairs and if the 'fault' doesn't changes from one channel to the other it is almost certainly an amplifier or output fault.
Likewise switching the speakers. If after swapping the speaker connections the fault changes to the other speaker it is an amplifier fault. If not a speaker fault.
Aug 16, 2014 | Gemini Sound Products GEMINI XGA 4000 4000...
How to hook up a gemini amplifier?
typically (unless your useing other gear besides mixer and amp) you'd come out of the L/R outs. ( Main outs ) to the Main inputs of the power amp then out to your speakers (outs of power amp). Now the amp could be in bridge mono or other factors but typically, like i said, just
Mixer Out- Amp In- Amp Out- Speakers.
Oct 22, 2011 | Gemini Sound Products GEMINI XGA 2000 2000...
I bought a factory refurbished xga-3000 gemini amplifier and conected it to my behringer mixer expecting a thump. but it barely sounded like a sound of earphone at maximum volume. I read power supply to...
A large amp like this likely has protection circuit (probably a relay) that doesn't connect the speakers until the amp is stable and balanced. You relly need the schematics for the amp.
Jun 21, 2011 | Gemini Sound Products GEMINI XGA 3000 3000...
Gemini gvx 15, were is the fuse located, we can't find in nor inside or outside ?
It may NOT have a fuse. If too much power was sent or an amplifier drove DC to the speaker, the voice coil may have fried. The specs do NOT brag aboput protection, so it is likely either the speaker is blown or the internal wiring is broken. Open the unit and use an ophmmeter to tesst the speakers.
May 30, 2011 | Gemini Sound Products Gemini GVX-15 15"...
Where do i plug my speakers in on my cdj 600's? got it working through the headphones everything else is useless??
You connect POWERED speakers to the left and right outputs... You MUST use POWERED speakers or an external amplifier. This unit has a small headphone amp, but that CANNOT power passive speakers.
Apr 22, 2011 | Gemini Sound Products Gemini CDJ 600...
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Gemini P601
the gemini p-601 is not bridgeable. you can select either speaker pair a, speaker pair b, or both pairs, but you can not bridge it without potentially damaging the unit.
Oct 27, 2007 | Philips GEMINI P-601 Fan CooledStereo...
Left Channel Not Working
Hello fakeman_56, You may have blown the power output amplifier on the left channel. This is what this looks like. You will have to take some measurments to determine if the output power amplifier is indeed malfunctioning. I hope this helps, Thank you, shuttle83,
Oct 06, 2007 | Philips GEMINI XG-2001 Fan...
48 people viewed this question
 Grubhead
Grubhead
