Question about Marantz SR5500 Receiver
Hi Dear Would you please help me regarding my problem on: I cannot turn on my Marantz 5500 Amplifier. This problem caused after problem on city power distribution network. When I try to turn on device with mechanical button, continouslly I hear a peridically sound from inside (tick tick - tick tick - tick tick), and device is still off without any display action. Your answers will be appriciated. Best Regards, H.Vahedi
    New Friend:
Sounds like you need new transisters which fire up the main output Tran
Posted on Jan 30, 2014
SOURCE: Marantz Model SR5500 AV Surround
Thanks,
I decided to take it to a service centre,much easier really.
Posted on Apr 14, 2008
nuwan chinth
  • 111 Answers
SOURCE: MARANTZ SR 5500 will not turn on
the protection circuit is your amp is turned on by itself or its protecting your speakers from burnt output transistor stage of amplifire circuit.sometimes it happense because of bad solder joints of the printed circuit board.if you are technicaly sound please resolder all the joint of pcb power and putput sections.if you need more help please comeback.
try to do it by yourself.
nuwan..
Posted on Jan 12, 2009
SOURCE: need to give a FULL RESET in a MARANTZ SR5004 RECEIVER
marantz sr5004 power led is blinking very fast pls give me the solution
Posted on May 25, 2010
sonicboomele
  • 1557 Answers
SOURCE: For no reason I know of, my Marantz SR8001 will
blinking power lights are a factory setting to inform the customer there is an internal electronic fault. and the unit needs to be repaired by a service pro in 99% of cases the owner can do nothing to fix it.
send it in
best luck
Posted on Oct 14, 2010
dunnbiker
  • 8546 Answers
SOURCE: Hi - I have a
It goes in the Tape Monitor Loop (either one: DCC or Tape). OUTs to INs.
http://www.hifi-pictures.net/amplifiers-home/Marantz%20PM-55SE/amp.htm
The EQ itself has a Tape Loop to replace the one it uses and allow pre- or post Tape recorder Equalization.
http://digilander.libero.it/pasqua49/COLLEZIONE%20HI-FI/MARANTZ%20EQ551/Marantz%20EQ551.htm
Posted on Jun 21, 2011
Red flash light blinking.
That's a short circuit indicator. If you have some electronic skills u can repair it, else send it to a repair shop.
Apr 20, 2014 | Marantz PM6004 Integrated Amplifier
Connecting Marantz Power amp to Marantz reciever
Please see my answers regarding the hookup of Marantz amps and preamps.
Feb 21, 2014 | Marantz MM7025 Amplifier
I am thinking of replacing my now very old JVC AX 330 amplifier with a Marantz PM7003 amplifier and want to know if this is a suitable replacement in terms of power output etc.
You, sir, are a rare adherent to stereo-only electronics. Are you replacing it for cause (showing its age)? The PM7003 is only 2 x 70 watts like the JVC but it also has separable preamp/amps so you COULD upgrade or augment the power output with external amps and still control it all locally.
Of course, any current AVR's do that too and bring digital sources and multichannel audio to the mix for as little as the PM7703 may cost.
Jun 23, 2011 | Audio Players & Recorders
I just want to see the Marantz PM8004 service manual
Please go to this link:
http://us.marantz.com/us/Support/Pages/Manuals.aspx
Then choose "HiFi Components" from the drop down
Then choose PM8004 and click the submit button.
The download button for the manual will then appear below.
Please rate my answer if this has helped you.
Many thanks,
Chris
Mar 02, 2011 | Marantz PM8004 2-Channel Amplifier
Dear Sir, Can I use my marantz tower speakers
Yes, the impedance is perfectly acceptable, just that it wont be a perfect acoustical match.
Sep 04, 2010 | NAD C325BEE Amplifier
Marantz pm 550 dc, service manuals and schematic diagram
Hi,Give this a try. I think it is what you are looking for.
http://www.eserviceinfo.com/download.php?fileid=48367
Click where it says "Download >> To download the file, please, click here
It's a multipart file, so you need to download Multipart 0,1
open it using winrar and the open it to view the pdf file.
Note: you must have a pdf viewer to read the file.
If you need anymore help with the amplifier, then please ask.
Regards - Anthony
Feb 28, 2010 | Marantz Audio Players & Recorders
The fuse keeps blowing in my marantz pm-57 amplifier. It says it takes a T 2.5A 250V fuse. I can only find 2.5A 250V fuses. What relevance is the ''T''.
Goo day sir, the T on the fuse has nothing to do on you marantz fuse blowing up, chances are you amplifier is shorted, check you IC amplifier/power transistor for shorts. Check also your speaker impedance. usually they are 8 ohms. You can use a technician's multitester device to check the impeadance. An imbalance or mismatch speaker can cause a fuse to blow and destroy your amplifier. hope this helps.
Jul 31, 2009 | Marantz PM-15S1 2-Channel Amplifier
nuwan..
Jan 12, 2009 | Marantz Audio Players & Recorders
Marantz PM-34 Problem
Hi there
The part that you speak of is called the emitter stabilizer resistor. It is common to the output pair on one channel. You will find that the large "output" transistors mounted to the heat sink either side of this resistor will most probably be faulty.
Best not to run the amp at all whilst in this condition.
To be sure that you have an effective repair, you will need to change both these parts, and also the "driver" transistors that connect to the outputs. They too are in symmetrical positions close to the the output transistors. You should also check that the 3 legged resistor you mentioned is measuring its correct value, and check all other low value resistors in the output stage area to that channel.
If you are not familiar with repairing this sort of equipment, perhaps you can find a repair guy with some experience on audio equipment, then this work should be all he needs to do to repair the amp. I would also ask him to "blanket resolder" the output/bias stages and power regulator stages in the amp as problems with heat stressed cracked/failed soldering and dry joints often cause these amps to blow the output transistors.
BE SURE THAT THE CORRECT PARTS ONLY are used for the repairs. Different transistors could cause future problems with the amp. The parts can be obtained relatively easily from a marantz distributor(we can find one in a country near to you). OR if you can give me the markings to each of the parts you need, I can provide you with an international source to get them from.
The amp is decent HiFi, and worth repair. Happy to provide you any assitance I can, Good Luck
regards
robotek
Nov 02, 2008 | Carver PM950 Amplifier
My Marantz PM-45 integrated amplifier will occasionally cut out by switching off a relay.
Hi HouseofBlues
The problem you are facing is the speaker protection is turning on to prevent the amplifier from damaging your speakers. It will need some service work done to it to prevent it from happening. I suggest you get it attended to sooner than later, as the problem will be caused by dry solder joints that will need to resoldered, or a semicinductor that is failing. If you are a gun with a soldering iron, you could do this yourself. Check about parts of the amp that runs hot, particularly transistors and resistors in the output stages. resolder all output transistors, and any parts that are mounted to a heatsink. Also focus on areas of the PCB that has discoloured. This is often where the problems occur.
I am more than happy to answer any other questions you may have about it, just give me a hoy :)
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 01, 2008 | Marantz Audio Players & Recorders
Marantz SR5500 Receiver Logo
85 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
