Question about kawasaki 19.2V 4 Piece Cordless Tool Kit
Having charged both batteries the drill will not work. It seems to not get any power.
    Filmmaker:
    Uploaded 5 video answers.
  • 68 Answers
Hi there, let me see if I can help.
1.Since this is a 4 piece kit, test the batteries in some of the other tools to make sure the batteries are good
2. This could be a malfunctioning unit, If you just bought it, take it back to the store and get a replacement, (you may have to take in all 4 and do a complete swap but most home improvement stores have no problem doing this)
3. The Forward and Reverse selector just above the trigger is stuck in the middle meaning, the drill is not in forward or reverse and when you press the trigger nothing happens. See Page 15 of this PDF for more information.
4. If none of this works, there is a Recall for that Battery Unit. Check This PDF to see if what you bought applies.
Hope this helps.
Brian
Posted on May 25, 2011
I have a makita 8391d cordless drill The problem is that the drill runs incredibly slow even when both batteries are fully charged I have checked the voltage and both batteries are showing the correct...
You have to check the batteries with a new machine. If the new machine works ok then the rotor of the motor of the old machine is broken.
Jan 18, 2014 | Drills
My Ryobi HJP001 drill and it doesnt seem to have enough power even after the batteries are fully charged.
The batteries may not be charging fully even though indicating otherwise.
Aug 13, 2013 | Ryobi Drills
Hitachi drill charger keep blow fuse
This helped me!! I happen to have 2 batteries for my Champion cordless drill. I managed to replace the fuse without having to re-solder anything, tried the battery, and again, fuse blown. Replaces the fuse again and tried the other battery, and voila (fingers crossed) it seems to be charging. My question is - is there anything I can do to resurrect the old battery or test it to see what/where the problem is?
Apr 11, 2013 | Drills
What lights indicate that the battery is charging and when the battery is full. Neither of the two batteries will charge and i have lost my receipt from argos
generally the red light indicates charging and the green one indicates full charge. If both flash at the same time it usually means the battery or the charger has a problem. Let me know if you need more assistance.
Apr 13, 2011 | Drills
I have an 18volt Dewalt XRP 1/2 inch drill. The drill has been working perfectly up until this morning when I took it froms its case. I was using it the evening before to screw in some 2 inch screws into...
Check electrical contacts in drill body where battery connects. Check wiring inside the drill, trigger and check also brushes. You do not have to invest 329, you can buy "body only" machine for few bucks and reuse your charger and battery packs. Juraj
Oct 20, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Drill only attempting to drill, its only working for very short periods
If the unit is battery powered, the battery may be on it's last legs. Replacement of the battery pack is the usual fix, but there is a battery repair service available that can replace the individual cells for roughly the same price as a new replacement. Go to: www.primecell.com I have had very good luck with a Skill battery pack rebuild with lithium cells instead of the original NiCads. Seems like a much longer run-time per charge and it holds right up to the end for power. Hope this helps!
Aug 11, 2010 | Garden
Power Driver is charged - won't work
If you are sure that battery is fine, problem can be in the switch or brushes. I would check switch first - open the driver, take 2 wires and attach battery directly to motor contacts, in case it works, problem is most probably in the switch. Juraj
Jul 11, 2010 | Skil 2362-01 Factory-Reconditioned 7.2V...
Battery won't charge on my ryobi 14.4v cordless drill yellow and green lights stay on
I had the same problem and found a solution on another forum...
Plug the battery into the charger. The yellow and green lights come on. Leave the battery plugged into the charger. Plug and unplug the charger power cord from it's power source a few times until the the red charger light comes on..... problem solved!
I think the "smart" circuit in the charger that is supposed to trickle charge before the regular charge cycle needs at least some battery power to test and start the cycle. If the battery is totally discharged, the test can't deternine the battery status and will not charge.... Plugging and unplugging the charger seems to bypass this teat and charge the battery normally. The charging process should work normally after this method.
Oct 22, 2009 | Drills
Milwaukee 28V Lithiom-Ion Battery loses power in storage
It is not recommended to leave the battery installed in the drill while not in use. The system of the drill will eventually pull the battery down, especially if the battery has had a lot of use. When the battery begins to weaken it will not hold its charge as long.
If you haven't, try charging the battery, 24 hours max and then keep it detached from the drill for several weeks. Then try it aand see how much power you have left. If it is low or depleted, battery is weak.
Nov 15, 2008 | Milwaukee Drills
kawasaki 19.2V 4 Piece Cordless Tool Kit Logo
96 people viewed this question
Top kawasaki Drills Experts
jasbo
jasbo
Jim London
Jim London
Are you a kawasaki Drill Expert? Answer questions, earn points and help others
