Why does my Dell Vostro 330, running Windows 7 Pro 32-bit go into sleep mode, even though I am telling it not to?
  • 2,404 Answers
If your sure after going into the control panel and going into the power options icon that all your power settings are set to none then there could be something in the background that is causing the laptop to go into sleep mode.
Click on the windows logo in the bottom left hand corner and in the search box type in the word MSCONFIG. Press enter and then go into the startup tab. You'll see all the programs that are running. Best things is to click on the box that says disable all. click on apply then okay and let the computer restart. Let it run for a while and see if it goes into sleep mode still. If it does then that means there is an issue with the Operating system and you should try doing a system restore (located in the system tools section) back to the last date the laptop was working properly.
If it stays out of sleep mode then that means one of the programs that was disabled is the culprit. You'll have to go back into msconfig and enable all the programs and then disable the ones you know you dont have to have starting up when you go into windows.
Posted on May 25, 2011
Is it possible to install Windows Vista in dell vostro 2520 laptops(3rd gen ci5)?
The same drivers for win 7, 32 bit, are on some occasion working so try these... download from vendor site and install manually each driver
Apr 22, 2014 | Dell Vostro 2520 15.6" Notebook - Intel...
Dell windows 7 pro 32 bit windows dvd maker says video card
The drivers may now be default Windows instead of original, so you could try forcing by right clicking the setup and using trouble shooting mode. Or just go to Dell support and enter service tag on their web site, then look for updated Win 7 drivers. gl
Jan 25, 2013 | Dell Latitude E6410 Notebook
Installing adobe acrobat pro 6 to windows 7
This is an old version of Acrobat that was written for NT, Win2K and XP. Due to changes in the OS, it's hard to get the program to install in Windows 7.
Which version of Win7 do you have? (32-bit or 64-bit and Home Premium, Pro or one of the other variants) Since you indicated this under the Dell Dimension E521 with 1 GB of memory, I'll guess Win7 Pro 64-bit. (This uses the 64 bit CPU) You can check by clicking Start > Control Panel > System and Security > System. If the Windows version ends with x64, it is the 64-bit version. Otherwise, you have the 32-bit version.
Under the 64-bit OS, you need one of the following workarounds: a second computer, a dual boot computer or a virtual computer running an older version of Windows. If your hardware supports virtualization, this might be a good bet if you can add memory to computer. With Win7 Pro or Ultimate, you can download and install Virtual PC and XP mode from Microsoft and run XP for free. Then install Acrobat in XP mode as if it were your only machine. (Note: the Virtual PC requires a share of your total memory and doesn't give it back to the main computer while it is running.)
The other methods listed require a licensed version of an older Windows OS.
If you have the 32-bit version of Windows 7, you can try the compatibility mode. Right click on the installer and choose Properties. In the compatibility tab, check always run in the compatibility mode and select an older version of Windows. Then click Apply to save the changes and then click OK. Then right click again and choose Run As Administrator. You may have to repeat the compatibility mode changes for the program itself.
You may want to consider upgrading to a Windows 7 compatible version of Acrobat. The current version is Version X.
I hope this helps.
Dec 26, 2011 | Dell Dimension E521 AMD Athlon 64 X2...
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
How do I install it on my new (Windows 7 Dell Vostro 3300) computer
Just plug it in and see if Windows recognizes it. If your OS is 32-bit you could also try the Dell Vista 32-bit driver
Jan 29, 2011 | Dell 922 All-In-One InkJet Printer
Which windows 7 is compatible in dell laptop vostro 1015.......... is windows 7 ultimate 32-bit is not compatible with vostro 1015........ nd also can be there any solution to extend internal speaker in...
Hi.
I have checked all the information online.
The Dell Vostro Notebook supports the Windows 7 32-bit Operating System.
The Drivers for the Windows 7 Operating System are also available on the Dell Support website.
I have also mentioned the link from which you may download the Drivers for the Windows 7 Operating System.
http://supportapj.dell.com/support/downloads/driverslist.aspx?c=in&cs=inbsd1&l=en&s=bsd&ServiceTag=&SystemID=VOS_N_1015&os=WLH&osl=en&catid=&impid=
Please click on the above link to download the Drivers for the Windows 7 Operating System..
Also, could you please re-phrase the second issue which you have mentioned in the problem description?
Hope this helps.
Please feel free to contact for further information and assistance.
Oct 23, 2010 | Dell Computers & Internet
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
I have the same network card.
Never had this problem with Vista (32 bit) but recently switched to Win7 (64 bit) and had the same problem as you.
I solved by going under Control Panel->hardware->network card properties->power save and unchecking "Allow pc to switch off the device to save power"
Jul 13, 2008 | Intel Ethernet 10/100 Network Adapter
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
