Question about Orion1934 19" TV
No sound we had a storm and after that the tv won't give me sound. i checked the main board and the sound ic was a bit black and it was getting hot. the number on the ic is 7511. what can i do????
    Genius:
  • 1,139 Answers
Hello sgaffar,
This may mean that you audio detector/amplifier IC in the TV was rendered defective by an electrical surge. Now I would check to see if the circuit was getting and sound from the audio detector (which might be in the IC also). After checking to make sure the bias circuits are ok I would suggest replacing the IC.
You will need a schematic, a multimeter, and if possible an oscilloscope to troubleshoot this problem.
I hope this helps,
Thank you,
Shuttle83
Posted on Aug 23, 2008
L G TV model 47LN5400 black no video sound ok.IC on main board running hot.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 25, 2015 | Televison & Video
Tv plays about 2 minutes and picture and sound goes off, comes back on.Does this 3 times then tv shuts.turn tv back on and repeats sequence.
there is main board defective please replace the main board 3 time blink is dc alert which is happened in side the system ic & we cant replace the system ic so we replace complete main board
Apr 20, 2015 | Sony BRAVIA KDL55HX750 55-Inch 240Hz 1080p...
I have a 32"flat screen with DVD feature. When I turn on the TV, its telling me to run auto scan.I have already run the auto scan 3 times. Can you give me the phone for the technical service dept. Thi
It sounds that the main system control memory IC to set is faulty. Contact any service technician. It is a very small IC, can be located very near to the main system control IC. It won't cost more. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Sep 22, 2014 | RCA 32LA30RQD 32-inches 720p DVD/ LCD TV...
Have a JVC LT-32DM22 Television. The power went off due to a storm. Power is back on, TV has power-red light is on, but TV will not come on. Please Help-Thanks
The power light is ON, means, the power regulator board is working properly. You have to troubleshoot the main board. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Nov 01, 2013 | JVC LT Televison & Video
My Mitsubishi CS-2610 S-Monitor suddenly blacked out! I am having a difficult time finding a job, and cannot replace my TV right away. Can it be fixed?
tried to re soldered first cold soldered component parts at the main board which may get loose contact. if can not get with re soldered check bulged or leak capacitor at the vertical section. and then try to observed if the vertical ic is too hot, that was mean the ic get bad.just replaced with new one and re check other component near the ic.
Aug 09, 2012 | Mitsubishi CS-26201 TV
Tv will not turn on
This sounds like it might be a main board issue. Depending on the television brand there are different replacements you can get at different prices. I would try unplugging the tv from the wall first then try plugging it back in while holding channel up/volume up on the tv as you are plugging it back into the wall. If this doesn't change anything it is most likely a problem with your main board.
Jul 23, 2012 | Vizio VO47L 47 in. LCD TV
On_Off light blinks three times but power will not come on.
Hello
Your tVs horizontal output and oscillator has some trouble with it. When the power supply gets ON, the horizontal frequency that drives the horzontal output section won't generate the horizontal frequency, that output section wont' work, the main system control microcomputer IC will sense this situation, and give shut off signal to the power supply. That is happening now with your tV.
A through checking on the main board should be done to detect this fault. you must have sound knowledge in electronics, how the TV works. Also must have all testing equipments with you including a high quality digital multimeter. Normally this fault occurs due the main chorma-video jungle IC. But before replacing it, you have to check all other components in it. Some loose soldering contacts may also make this problem.
If you have the ability and skill, Inform me. I'll assist you. OK.
Jun 27, 2011 | RCA 32F530T 32" TV
Tv got a straight horizontal line
Hello
A straight horizontal line across the center of the screen denotes the full failure of vartical sweep in your tv. There is two main reasons for this. The first one is vertical output Ic and any of its related parts inside the printed circuit board of your tv is faulty. The second one is deflection yoke [the coil fitted alongwith at the neck of the picture tube] is open. The second fault said here is very rare. The fist one is reported more.
There may be, as said earlier, the IC [Integrated Circuit], may be faulty. You just locate the vertical output Ic inside your TV. normally in most televisions, it will be screwed into a heatsink metal, as it will be get heated during operation, the metal conducts the heat gereated by this Ic to the surroundings, to make it at a constant safe temperature. In most cases, we have seen, this Ic may opend. That is its inside drive integrations got faulty. It has a particular number marked on it. You must note that number and replace it with a similar type and number.
You just open the back cover of your tv, while it has been isolated from the mains supply, by unpluging it from the wall socket. There are four wires run to the deflection yoke (stated earlier), amoung, two of them will be thicker than the other two. Catch up the other two thinner wires, and look from where it is connected to the main board. You can see very near to this connection, an Ic fitted into a heat sink screwed. That is the Ic in suspect.
With set open, supply it and wait for 5 minutes or so, and unplug the tv from wall socket, and touch the heatsink of that ic gently, and see whether it overheats or not. Some amount of heat will be there, but it should not be overheated. If overheat is there, the Ic has damaged. Replacing it is the only remedy.
Another possibility is, the said Ic doesn't get the proper supply voltage to it to work. To find this, you should have a multimeter in hand, and the ability to find out the points I am going to report. Refer to the schematic diagram of your TV [not the manual, It gan be get from electronic book shops], and find out the main supply point of that Ic. It is a hot check, that is you only can check it with your tvs printed circut board pulled out, and the tv is switched on. Every precaution against electric shock shuld be taken before that. Keep children away from you, and let an adult beside you.
If the main supply voltage is correct, it may be around 35VDC or so, check the voltage of its output pin. It should be neare to 1/2 of the main voltage. If ther is exess votage shown, or no voltage at all, surely the said Ic is faulty. Replacing it will solve the problem.
Find any difficulty, report it to Fixya. They will give alert yo me. Ok.
Oct 21, 2010 | Quasar SP-3235 32" TV
42 inch LCD Philips TV - TV screen is black, but the sound comes through perfectly on all channels. Same result when a DVD is played into it. Model number 42PFL9632D/79. Plugged into a power centre...
hi sir
this type nof problem occurs mainly because of 3 issues...
1.jungle ic in D -board
2.colour wheel
3.cathgode ray tube/..please check them
thank u,,/please rate it
Jul 01, 2009 | Philips Televison & Video
No sound black screen
You can see the Vertical Outpu IC(must be damage and resistor from the flyback tranformer), but check the main power supply STR. Some times this STR not seems damage when you test out of main board, but with voltage it funtion not well.(Sorry my English).
May 21, 2009 | Panasonic Televison & Video
Orion1934 19" TV Logo
77 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
