Question about Abit IC7-G Motherboard
I have an Abit IC7-G motherboard. Machine has died with no reaction from pressing power on and reset buttons. Power cable in is OK and when connected, green light behind IDE1 socket lights up (which says to me not a power supply problem?) but otherwise nothing. Is this a dead motherboard or could it be a battery/fuse problem? Many thanks
  • 917 Answers
Most obvious problem would be the power supply. The green LED only indicates that the 5V rails os working enough to power the on/off circuit on the motherboard. First disconnect everything except the mother board from power supply. Then try switching on again. If this does not work, then disconnect the power connectors from the motherboard. ON the big power connector (P1) there should be a green wire with two black wires either side. This is the power on sensor wire. Use a paper clip or similar bit if wire to short out the green wire with one of the black wires. This should start the power supply and the fan in the PSU should spin. If this does not work then the PSU is definately faulty. If it switches on when there is no load connected then it is probably only slightly faulty (not able to provide sufficient current). Since the green LED is coming on, my guess is that you have bad capacitors in the PSU (they will probably have domed tops instead of flat). Try a power supply from another PC if possible.
Posted on May 25, 2011
Testimonial: "Many thanks indeed; definitely power supply. Will replace and try again."
Expantion of my hdd
to add hard you need to put it in then hock cables to board and power then startup computer then open up decktop click on sec drive then fomat it
Jan 14, 2014 | Abit IC7-MAX3 Motherboard
I had 2 x 512mb memory installed with no problems. I recently installed 2 x 1Gb but the bios does not recognise it. The pc always hangs on boot up just before loading windows. The pc will work with the 2 x...
Hello gphillips397!
Abit has released an updated BIOS for the IC7-MAX3 motherboard which fixes quite a few issues with your motherboard including one that can cause the system to hang with certain memory modules. The updated BIOS is HERE and instructions for the upgrade are in Appendix G of the User Manual or a general guide is HERE
Nov 22, 2010 | Abit IC7-MAX3 Motherboard
How do I reset bios on this motherboard? I've tried to find a user manual to download without success.
This link to Abit will get you the manual for the IC7-MAX3 board, which may what you need.
If by resetting BIOS you mean clearing CMOS, just remove the battery.
Feb 14, 2010 | Abit IC7 Motherboard
I have an Abit IC7 G motherboard and I can't get sound. I just reformatted windows XP. Updated drive etc. But under my Other Devices in Device Manager it has a "?" on "Multimedia Audio Controller" As far...
If you can locate the chipset on the mainboard for the sound card.
then download driver from other manufacturer ..
You will see for eg Intel ac97 or realtek audio something like that..
For your mainboard configuration it may be
Realtek Audio driver
OK
HERE ARE LINKS TO DOWNLOAD
http://www.nodevice.com/driver/IC7-G/get40802.htm
l
2ND
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Abit-IC7-G-Realtek-Audio-Driver-376.shtml
OK
Jan 22, 2010 | Abit IC7-G Motherboard
Need ethernet drivers
abit has a great site for this here is yours
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&fSEARCHTEXT=IC7
Aug 14, 2009 | Abit IC7 Motherboard
IC7-G MB after changing bios memory to F1 on reboot getting
You'll need to reset the Bios.
Take the battery out inside, it's usually on the lower right of the motherboard, it looks like a watch battery.
Unplug the computer and press the power button to get rid of any extra juice from your power supply.
Wait about a minute.
Put the battery back in and plug your system in, the reset should be complete.
Some motherboards have a pin setup to reset the system. If the jumper is in (oox, x being the free pin) for example, then just switch the jumper to (xoo), turn your computer on...nothing will happen, all good.
Put the jumper back from (xoo) to (oox) and it should be reset.
Keep in mind, doing this a lot isn't good for the system. Make sure you know how to switch up the options in your BIOS.
Jul 16, 2009 | Abit IC7 Motherboard
Were do i get audio and video drivers for 1bit- ic7 motherboard
Try http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=IC7&fMTYPE=Socket%20478&pPRODINFO=Driver
However the IC7 does not have an integrated Vidoe card so you will need to go to the manufacture of the AGP card for this
Simon
Jul 09, 2009 | Abit IC7 Motherboard
Abit IC7 Moterboard Manual wanted
Hi, follow this link #http://www.manualnguide.com/manual-get/6193/# excluding the hashes, if you can't download or view the page, the contacts should be found at the bottom right hand corner of the motherboard, as shown on pic attached, Hope i could be of any help.701ec0f.jpg
Oct 14, 2008 | Abit IC7 Motherboard
Abit IC7-G Motherboard Logo
252 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
