While opening my tally 6.3 i found"Tally lock setup " "Try repair in maintance mode? (Yes) Remove any existing driver ,will require reboot (No)cancel setup"
    New Friend:
Sir i want to removed lock setup
Posted on Jun 28, 2013
  • Mani Suresh Jun 28, 2013
    sir tally6.3 open but error in tally lock setup
2 Suggested Answers
SOURCE: tally 5.4 exiting tally error
i want to install tally 5.4 in my computer. I am using Window7. Does tally5.4 compatible with windows7? Plz give me solution for install tally5.4 in my computer with windows 7
Posted on Feb 26, 2010
How to export in tally 7.2
This applies to Tally 7.2 and above.
1. You can export only registers and not masters
2. In any view register mode the export / import option becomes availble.
3. Click export.
4. Tally prompts you for a file name. The default name is always Tally.txt.
5. Pl rename the file to represent the ledger you are exporting else Tally will over write an existing file.
6. Tally will always save the file in the same drive / folder where Tally data resides. You cannot change this.
7. The file saved is the CSV file.
8. Open this file with Excel and map the fields.
Jan 20, 2015 | Tally Office Equipment & Supplies
How to export tally 9 to excel sheet
Great question and there are two way export date. Please follow step by step instruction.
  1. In the Balance sheet screen click E : Export or press Alt+E.
  2. Select the required language from the list of Languages displayed.
  3. Select a format from the list of Formats displayed.
  4. By default, the exported file will be stored in C:\Program Files\Tally.ERP 9 for Windows 7 and C:\Tally.ERP 9 for Windows XP operating systems
  5. Press Enter to accept the default Output Filename or type the filename of your choice in order to save the file with a different name.
  6. Press Enter to accept the default Output Sheet Name.
  7. To update the existing file select Yes in Update Existing File.
  8. To format the contents of the file select Yes in Excel (Spreadsheet) formatting.
  9. Select Yes for the Field with Colour, to retain the background colour in the exported file.
And Second:
selecting the ASCII (Comma Delimited) format, the user can export all the reports or data from Tally.ERP 9. The data exported is converted to plain text separated with commas and stored in a file with the extension .txt. This file format is widely used for emailing and used for importing data into another company using Tally.ERP 9
More information please visit this link.
http://www.tallysolutions.com/website/CHM/TallyERP9/Data_Management/Export_Formats.htm
Thanks,
Jun 10, 2014 | HP Office Equipment & Supplies
How do I correct error code 2147483650?
To fix this, follow the steps below:
1. Back up your Tally data.
2. Make a new folder under the Data and then change the name of the folder with a 5-digit number such as 11111.
3. Copy the files below from the corrupted folder to your folder 11111.
Company.900, Linkmgr.900, Manager.900, Tranmgr.900 and Camsave.900
4. Click Start and then Run and then type the command C:\Tally.ERP9\tally.exe data 0.
5. Press Ctrl+Alt+R and click Yes to confirm. Wait until the process is done.
6. Exit Tally and re-open it to see if the problem has been resolved.
Alternatively, if the above steps didn't work for you, remove Tally and all its components completely. And then restart your computer and reinstall it again to replace all the corrupted files.
Mar 29, 2013 | Office Equipment & Supplies
EXPORT TALLY7.2 DATA INTO EXCEL SPREADSHEET
Please follow the below step for your problem.
Go to Gateway of Tally> Balance Sheet (Here you can choose any report which you want export in tally)
Step 1: In the Balance sheet screen click E: Export or press Alt+E.
Step 2: Select the required language from the list of languages displayed.
Step 3: Select a format from the list of formats displayed.
Step 4: By default, the exported file will be stored in C:\Program files\Tally.ERP 9 for windows 7 and C:\Tally.ERP 9 for windows XP operating systems.
Step 5: Press Enter to accept the default output sheet name.
Step 6: To update the existing file select yes in update existing file.
Step 7: To format the contents of the file selects yes in Excel (Spreadsheet) formatting.
Step 8: Select yes for the filed with color, to retain the background color in the exported file.
Step 9: Accept to export the Balance Sheet to an excel file.
Thanking you
davevipul197
Jun 04, 2011 | Tally T2245 Matrix Printer
EXITING TALLY!! Internal Error. Contact Tally
My tally 5.4 not open when to try open tally when see exiting tally! file not found. Please give the solution immediately
Apr 27, 2010 | Tally T2245 Matrix Printer
Tally Data Problem
EXITING TALLY!!
INCORRECT VERSION.
DATA OF INCORRECT VER.(10)
CAN ONLY RUN VERSION 9!
Jun 27, 2009 | Tally T2245 Matrix Printer
Tally 5.4 error
try to configure your configuration setting. change the data source where you data saved.
Exp (from program files, configuration setting) :
;; Tally eis 5.4 workstation specific parameters file
[Tally]
; Specify location of Data files
Data = D:\data tally\Tally 2\DATA
;; Specify list of companies to preload
; ** TO STOP DEFAULT LOADING set the following line to NO
Default Companies = Yes
Load = 0001
;Load = 0002
; Specify list of TDL files for user defined reports and changes
; ** TO STOP LOADING TDL FILES, set the following line to NO
User TDL = Yes
;TDL = <TDL file 1>
; Specify location of TALLY.SAV (saved configuration of Tally)
Config = c:\TALLY
; Specify Color details of local monitor
Color = Yes
a bold letter is the source of data that you must change.
Jun 22, 2009 | Computers & Internet
Software Exception c0000005
to solve this type of problem first of all take backup of your tally data then right click on ur tally icon on desktop go to properties then click on findtargate open ur tally configuration file see the line
load comony=yes (change yes into no) save the file & exit start ur tally pres ctr+alt+r selct the company which was giving error press enter tally will ask to rewrite the company press y to yes let the finish rewrite task then start working on tally
try this this works
RAKESH RANA
98682225794
Feb 02, 2009 | Computers & Internet
Tally Printer Code
Switch off the printer.
Hold down the SETUP key and while doing so
switch on the printer.
Aug 04, 2008 | Tally T2340/24 Matrix Printer
Corruption of tally 7.2file
Exiting Tally!
File Damaged
File:C':Tally7.2\Data\009\manager.500
Size 180180
Position: 180352
Charj : 128 (done128)
Jul 04, 2008 | Tally T2250 Matrix Printer
Computers & Internet Logo
462 people viewed this question
David Payne
David Payne
