Question about Garden
Write protected idVendor: 0x058F (Alcor Micro, Inc.) idProduct: 0x6387 (Transcend JetFlash Flash Drive)
MyTechGuru
  • 93 Answers
SOURCE: My Transcend JetFlash V10 16GB USB
Look for a "write-protect" key that is made physically on your USB FDD. Mine doesn't have one, but it should in most major new products. Switch it off.
Or, you can do it the soft-way. Right click on your UAB Flash Drive icon, then look for the Read-Only property, disable if it's enabled. or you will find that after right click click on properties
But according to my experiences, it seems that your USB FDD is locked physically
Posted on Aug 14, 2008
Go to the transcend site. In the support section, click drivers/downloads. Type in your model number or search for it. Mine was a Transcend 4GB JetFlash V10 drive. So the model number was TS4GJFV10. There will be a download called Recovery Tool. Get it. Run it. That's it.
P.S: use the global download link, its faster.
-TheIVth
Posted on Dec 16, 2008
saqeb
  • 47 Answers
SOURCE: Transcend 16GB Pendrive - error while copying
If your drive is partitioned with FAT32 then it cannot copy larger files. You have to format it using NTFS.
Posted on Jan 28, 2009
  • 11 Answers
SOURCE: Transcend jet flash showing write protected message
hey, i was having the same problem with the same flash drive... there are two ways how you can fix it..
1. try formatting using cmd
Go to start-->run and then type cmd and press enter
now the command window will open
in that type format X: (x being your drive)
This should work fine if not try the second method
2. Go to this website and download the recovery tool software which is exclusively for transcend flash drives.. click the link below to so to that site..
http://www.transcendusa.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=107&ItemID=TS16GJFV30&Controller=#5
Download the recovery tool software under the topic software and install it in your system.
Now connect the flash drive in your pc and run the recovery tool application.. This will format your flash drive
Posted on Feb 02, 2009
  • 291 Answers
SOURCE: Transcend JetFlash V60 16GB pen drive is write protected
Flash drives by default use the FAT32 file system. FAT32 has a limit of 4gb per file. So you could have four 4gb files on your pen drive, but no files bigger than about 4gb. You could use the NTFS format, but it's not suggested for flash drives since it reads/writes much more often than FAT and will make the drive lifetime MUCH shorter.
Posted on Aug 26, 2009
Testimonial: "It is not 4GB per file ! The 16GB Transcend pen drive is accepting only files upto 3.71 GB only. After reaching 3.71 GB it gives a message. "
The disk in write protect
When formatted, the disk is write protected (there is damage to firmware)
Damage to firmware, there are two types
1. Damage to firmware, data can be saved
2. Damage to firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair Damaged and repair firmware.
JetFlash Online Recovery, you can download here Transcend Customer Support
How to use JetFlash Online Recovery, and analyze damage to the flash drive, can you read in my blog. To find my blog, how:
Write a keyword in Google seach engine "Aplus Computer Fix Transcend Flash Drive". Analysis and how to use the JetFlash Online Recovery can you read in my blog.
Hopefully this information helps
Dec 19, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My transcend 4 gb pendrive is write protected .how can i remove the write protection
When formatted, the disk is write protected (there is damage to the firmware)
Damage to the firmware, there are two types of
1. Damage the firmware, data can be saved
2. Damage the firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair and repair the firmware.
Nov 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Removing write-protectiion
1. Damage to the firmware, data can be saved
2. Damage to the firmware, data can not be saved
To fix the Transcend flash drives, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, partition table repair and firmware repair.
Oct 24, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
4gb sony pen drive do not format
Flash drive can not be formatted, there are two possible
1. Damage to partition table
To fix Transcend flash drive, you can use the JetFlash Online Recovery software, customer support from Transcend. This program can be used to save data, repair damaged partition table and damaged firmware.
How to use JetFlash Online Recovery, and analyze damage to flash drive, can you read in my blog. To find my blog, how:
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My trancend 8 gb has become write protected. I used the regidit formula but the problem continued
Flash drive is write-protected, meaning there is damage to the firmware. To repair damaged Transcend firmware, use JetFlash Online Recovery software.
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download)
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
I hope this information helps.
Before repaired
After repair
Oct 06, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My flash dik is write protected
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 20, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to remove write protect on my 8gb transcend jetflash
If you dont have any switch for 'write protection' in the USB body, then download the utility called 'Jet Flash Recovery Tool' from trancend web site. It could help you.
Please come back and rate my solution if it turns to be helpful for you. Thnx
Mar 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cannot remove write protection of my transcend 4GB pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jan 05, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cant format my transcend 2 gb pen drive it says write protected
do you see any switches on the side of it ? if so move it to the other position and try again.
Jan 09, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Garden Logo
798 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
