I have an HP 4500 officejet printer. I want to keep others from making copies, which depletes the ink supply. Is there a way to set a password to enable the printer to print or a way to disable the copy function?
  • 32,281 Answers
The easiest way is to remove the printer cable and lock it away.
Posted on May 25, 2011
Tip
HP OfficeJet 4500 drivers for Windows 10
To install Drivers for printer and scanner of Hewlett-Packard Officejet 4500 same as G510 don't try to install it on Windows 10. You may found that. So what to do.
find in main HDD c: programfiles x86 hp and delete. (check if you have other hp machines so be careful) .download free program auslogics registry cleaner or with regedit in cmd command and find and delete all entries.
now for example you have the hp officejet 4500 wireless and you have download the OJ_AIO_4500_G510n-z_Full_Win_WW_140_408-5 . find it in the folder and with free 7zip or other like winzip extract it in a folder.
go to printers and add printer. When Win asks for drivers guide the request in extracted folder with checked the subdirectories.
That's it.
Have Fun and make a pray for me.
Nick.P.
on Nov 24, 2016 | HP Officejet 4500 Wireless All-in-One...
How do i find ink levels in Windows 8 for HP Office Jet J4580
It depends on what type of ink cartridge you have installed.....with HP genuine ink cartridges and HP Solution center installed, everything should be there. However, if you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels will not be displayed nor can they be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
NOTE: These types of 'SEVERE' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
HP Officejet J4500 J4600 4500 Printer Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts - Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500 J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
Apr 12, 2013 | HP OfficeJet J4580 All-In-One InkJet...
ATASCO HP OFFICEJET J4585
When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
Additionally, severe cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
Feb 22, 2013 | HP OfficeJet J4580 All-In-One Laser...
When trying to print my printer makes a grinding noise and the paper keeps getting jammed.
First, inspect the printer compartments for clog materials or debris. Usually observe the paper feeder area and dispenser areas for unsuccessful printer outs. Also, inspect the computers ink cartrigdes for any depleted supplies. Prior printers would least attemp jobs when supplies were amost depleted.
Feb 03, 2011 | HP DeskJet 6840 InkJet Printer
Hi, I have a HP Officejet Pro 7680 for light office use. The copies that we are making on it have been coming out with blank white lines running all down the page (portrait orientation). I have cleaned...
OK, first of all, cleaning can only be done a few times before ink is depleted. So, I would replace the ink jet cartridges in question with new ones from hp. If one experiences the same symptoms, then I would remove the ink jet cartridges and blow wih compressed air on the contacts. If that doesn't solve the problem, the printer may require service at hp.com.
Check out the following site for contacting hp.com and finding a solution through support forums, videos, and customer care for out of warranty items, and contacting hp.com for in warranty items:
http://h71036.www7.hp.com/hho/cache/427347-0-0-225-121.html
Jan 31, 2011 | HP Officejet Pro L7680 All-In-One Printer
I HAVE A MAC OS X 10.4.11. HP OFFICE JET 4500. HOW DO I SCAN? WHAT OPENS ON MY COMPUTER? WHAT SOFTWARE SHOULD I HAVE? I SAW I PHOTO OPEN BUT DID NOT SEE MY DOCUMENT.
OS X driver which allows your Mac to interface with a HP Officejet 4500 wireless all-in-one printer
This is a free Mac OS X driver installer package for the HP Officejet 4500 wireless all-in-one printer.
Enjoy the convenience of wireless connectivity with the Officejet 4500 wireless all-in-one printer. You'll be able to print, copy, scan, and fax all from one device, plus print at speeds as fast as 28 pages per minute in black and 22 in color. And with tje Officejet inks, you'll get professional-quality color printing at a low cost per page.
http://mac.softpedia.com/get/Drivers/HP-Officejet-4500-Driver.shtml
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 13, 2010 | HP Office Equipment & Supplies
"incompatible ink cartridge"
Printer needs to be reset:
1. Power OFF printer
2. UN-plug power cord at wall/surge protector
3. Turn ON printer (w/o power cord plugged in)
4. Plug in power cord
5. Turn ON printer
(This will reset the printer)
Sep 01, 2009 | HP OfficeJet J4580 All-In-One Laser...
Cartridge Error: Cart. on left is not intended for this printer
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab64
Jun 29, 2009 | HP Officejet 5610 All-In-One InkJet...
My hp officejet j4580 says incompatible black ink cartridge
I've been in print cartridge hell since I bought a J4580.
I spent an hour on chat with HP customer service and was able to resolve the problem by partially resetting the printer. Here's how:
  • Make sure your print cartridges are installed.
  • Unplug the machine, wait 20 seconds
  • Press and hold the # and 3 keys
  • Plug the machine back in
  • You'll see a reset message on the machine, release the # and 3 keys
  • Follow the prompts to set the language and location
Cross your fingers, hopefully your printer will print now!
Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
22 people viewed this question
jasbo
jasbo
