Question about Tech Solution TS-6000 Shredder
Motor wont run - Tech Solution TS-6000 Shredder
04 goodman furnace model GMS8 ciculator blower wont stay on gas fires and runs but high limit trip because of no air from blower any ideas bad motor or control module
You need to check the motor amp draw against the spec tag on the motor. If the motor has power to the motor wires it's either the motor or the run capacitor.
Nov 17, 2014 | Heating & Cooling
Heater wont start;don't hear blower motor
there are a variety of causes for this. any one of the safety systems may have detected a fault and thus wont let the heater run. if there is no electricity, the heater wont run. if there is insufficient water flow, the heater wont run.
Jun 02, 2014 | Hayward 100,000 BTU Pool Heater H100ID1 -...
I let the clutch out the motor wont run
The motor wont run or the car will not move ?? If the car will not move sound like its time for a new clutch . If the engine is stalling out you might need to raise your ideal speed or let your clutch out slower and give a little ore gas.
Apr 11, 2014 | Cub Cadet Garden
Replaced the clutch and motor coupler a month ago. Ran great. Washed tennis shoes. Came in to remove clothes, didn't spin. Wont agitate or spin, i could hear the motor running. Just replaced the motor...
Check for a failed capacitor under the control panel It is a start/run capacitor that the motor needs to start running. The motor will hum and if left will eventually burn out.
Aug 17, 2013 | Kenmore 23822 Top Load Washer
Motor wont rev up when starting cold with choke on trys to run on idle but will not rev up
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
Dec 26, 2010 | Honda 8 HP Engine
Motor wont start but runs if spun by hand
It's capacitor has got weak. Try replacing it.
It'll help you. :)
Jun 06, 2010 | Aquabot Pump Motor A6001a
I have a maytag performa it wont run the cleaning cycle and wont pump out wtaer
check your motor coupling,it could have broken,if you hear the motor running but no agitation i'm sure it has broken. cost about $20 between motor and transmission
Jan 09, 2010 | Maytag PAV2300 Top Load Washer
Dryer wont stay running
Chances are the motor switch is stuck (most likely)or the motor run circuit has failed (least likely but possible).
Disconnect unit from power and expose motor for thorough cleaning. Clean centrifigual switch sliding mechanism on motor shaft. It should move one direction under spring tension and spring back when released. Re-assemble and test.
Jun 12, 2009 | Dryers
Car window wont go down
try a new window regulator
Jun 07, 2009 | 1991 Honda Accord
Tech Solution TS-6000 Shredder Logo
Top Tech Solution Office Equipment & Supplies Experts
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
