Question about Kitchen Ranges
Why Samsung SW-903FX clothes washer panel gets a display but turns off immidiately after Power On button is depressed.
SOURCE: Fischer Paykell 7.5kg Smart Drive top load washer
Have you checked the lid micro switch under the motor controller which activates when you close the lid to start the machine?
Posted on Jul 24, 2008
appldoctom
  • 311 Answers
SOURCE: front load washer maytag stopped working during wash
the start button is part of the board their.if you hear frying noise their when pushing it there ,you may have a failling board.god bless your way.Tom
Posted on Jan 01, 2009
Daniel S
  • 4323 Answers
SOURCE: The drying cycle on my
Hi
The issue is either with the thermal fuse of the unit that is bad or the motor that has gone bad. To check what is causing this, first check the fuse which is located inside the rear panel to the exhaust duct and try to jump start the thermal fuse or test its continuity with a voltmeter, no continuity means bad fuse. If the fuse is okay then replace the motor as that part usually makes a hum sound when it is unable to run. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 23, 2011
SOURCE: Hello, I have a whirlpool Caprio
i would suggest sticking to a simple washer. newer washer are digital and they look very nice and easy to manage. But the warranty will not cover washer if motor gets wet. not even the factory warranty. Here in Dallas we had a hard winter storm around the time of the super bowl. it was hard to get around. the pipe in the laundry room froze and as it thawed out the pipe burst causing the washers motor to get wet. It is going to cost me more to fix it then whats its worth. Now im out 400.00. My suggesten to anyone thinking of buying a digital washer don't warranty only covers normal wear and tear. ive only had my washer for 5 months.
Posted on Mar 04, 2011
richroth
  • 9472 Answers
SOURCE: DISPLAY PANEL BUTTONS WORK EXCEPT THE START
Start by checking the door switch. Here is a link to a video to help you with it.
Posted on Aug 29, 2011
Samsung S3 just stopped working
It could be a faulty power button, you should have it checked out. The power button is a switch with two contacts and a common. When you depress the power button, it closes the circuit to common and lets the phone know that it should either turn on, turn off (after holding the button for a few seconds) or lock the screen if only depressed for a second. A faulty power button has the circuit CLOSED all the time so the phone never turns on, gets stuck in a boot loop, please visit http://www.zfixit.com/samsung-s3-power-button-repair/ for a better description and repair options available for this common Samsung problem on all Galaxy models.
Jan 15, 2015 | Samsung Cell Phones
Was washing clothes hit the pause button to add another piece of clothing now will not turn on. Totally dark
Possible that the interruption could have reset the processor or memory. Allow the machine to be off power for a long time , even overnight. Press down all panel buttons and check if there is any moisture within the panel. IF so use a dryer to warm off.
Now connect the washer while holding the start/stop/pause button, If there is no display at all then check the main power to the board and also the sub-voltages within the board. If not it is possible that the board has failed.
Jan 23, 2013 | Kenmore Elite 45986 Front Load Washer
Samsung j1045 washing machine
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Oct 14, 2012 | Samsung Front Load Washer Control Board...
My Samsung VRT washer was working fine. The cycle appears to be finished but the door remains locked. I get no response from any of the buttons. You would think that the washer wasn't getting any...
I don't know if I have the same model SAMSUNG front loader, but I have a similar problem. The door has decided to stay locked at the end of the cycle. I can turn it off and on and even send it through another cycle, but at the end of the washing, it drains, goes to END but does not go the extra step of unlocking, like it usually would about 1min after ending the cycle.
My clothese have been through about 6 different cycles, hoping it will magically clikc open at the end. I assume they are very clean, but getting dizzy.
Any help out there?
Aug 12, 2011 | Samsung WF337AA Front Load Washer
What does the code s e and u e on the washing machine samsung wf8704rsw display panel.
I think you probably mean 5E. This means that there is a water drain error. To clear it, turn the POWER SW OFF and back ON.
The code UE means a load unbalance and must be manually rectified by separating the clothing. To clear the error code, use the procedure outlined above.
Apr 27, 2011 | Washing Machines
Ive got a samsung t1253 its shows error code 5e how do i fix it
5E - WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 24, 2010 | Samsung WF337AA Front Load Washer
What two buttons do you push to have the firmware version displayed?
I think you hold down menu, then power on, and keep menu depressed. But that is for an sw-35... Still might be the same.
Check the service manual for the sw-35 here, I think the units are similar.
http://yama.co.za/forum/index.php?topic=146.0
Nov 18, 2009 | Sanyo PLC XU35 Multimedia Projector
'test' displayed on washing machine
After pressing different buttons and waiting 10 to 15 seconds after turning the power off, I have finally found the solution.
When you have pressed the "Start/Cancel" button to start your wash programme the LCD shows "test".
You must then press the "Start/Cancel" button which will give you the normal temperature and washing time and then importantly you must depress both the "Start/Cancel" button with the "On/Off" button which will give you a different LCD message and then it will automatically resets itself.
ALL THE BEST!
Jul 31, 2008 | Hotpoint Aquarius WD640 Front Load...
Jul 24, 2008 | Fisher Paykel EcoSmart GWL15
Kitchen Ranges Logo
96 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
