Question about Bosch 24 in. SHU43 Built-in Dishwasher
Error message F on shu 6800
Problem started with the dishwasher not draining. Dishwasher "flooded"...water everywhere. I was able to get it to drain and I cleaned out the filters. I then tried to restart the cycle and got a letter F on the display. I tried to reset the system, but it did the same thing....displayed the letter F and the motor would just run.
I got the manual out and it doesn't say what the letter F means, or what to do to get the thing working again.
Thanks much!!
Kayla
  • 725 Answers
Float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Posted on Aug 21, 2008
SOURCE:
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
How to fix anti flood error on F60860
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Dado
Sep 28, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Dishwasher wont fill up with water
When you start the dishwasher you have probably noticed that it first drains water and is very important to hear that drain pump running all the time or stops after a while? Why?
If the drain pump runs constantly then the fault is in the phase of "drain water" or is activated anti-flood system. Reset point of pressostat is not reached after max. 120secs. Programme stop and can be continued after error remedy by pressing the programme key.
If the pump is running for a while and then stops, then the fault is in phase "fill up water". Switchpoint of pressostat is not reached
after max. 60 secs.
Usually built-in dishwashers has anti-flood system that responds in the event of water in the bottom of the dishwasher. Such a case, find and repair water leaks.
Dado
Aug 06, 2014 | Electrolux 23 in. ESI6104 Built-in...
Bosch SHU runs even when the door is open, what do i need?
Hi Jeffrey,
This depends what you mean by "runs". If the dishwasher continues with a wash cycle - i.e. circulating water - with the door open, the simple answer is that you have a defective door microswitch.
However, I suspect what you perceive to be the dishwasher running, is actually the drain pump running continuously. This happens when the anti-flood protection system has been activated and continues even when the door is opened. The simplest way to check is to open the door (while it's "running") and pour some water into the tub. If the water drains away immediately, this shows the drain pump is running and the anti-flood protection has been activated.
This may be due to water having leaked into the base of the dishwasher, but it could be as simple as a stuck or defective float-switch.
Please try the simple test above then post back for further assistance. If you're planning to investigate or repair this yourself, you're going to need a Torx T20 screwdriver and a multi-meter would be useful as well.
Regards, BElectric
May 25, 2011 | Bosch SHU9915UC Dishwasher
Want drain or pump water
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Dec 13, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
What does an F1 erroor message mean. I have a
F1 means "flood. there is a flood sensor underneath the drawer, and if there is any water under the drawer the control will show that error. Check the drain hose linkage for cracks. Remove drawer and dry the area underneath.
Jul 14, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
Dishwasher not completely draining
Make sure the drain screen is not clogged at the bottom of the dishwasher or that you water drianline is not pinched or clogged behund the dish washer. if you are confidant in doing this you may be able to troubleshoot it. It possibly could be a water pump issue too.
May 16, 2010 | Dishwashers
Drain does not fully expell the water
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 13, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Bosch SHU 43C06 UC17 dishwasher the dishwasher is just draining with no water in the tub, and is not filling, it does not seem to begoing out of drain mode
water in the bottomof the base remove side panel and dry out the bottom base . the float is up . thats why its in drain mode. bosch old tech speaking.
Oct 10, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
428 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
