Question about Little Giant VCMA-15ULT 1/60 HP 3/8" Condensate Pump Model# 554411 with 20'
VCMA-15 Have a catch pan overflow switch which goes in series with the thermostat circuit, but there are two low voltage wires coming from the pump and these have been connected together since installation 12 years ago. They are obviously for a high level shut down but how can this function if they are wired together. Seems to me they should be in series with pan overflow switch and thermostat. Anyone with first hand experience?
    Problem Solver:
  • 12 Answers
You should have it wired in series with the wire on the 'R' terminal of the control board to the thermostat. Usually the red wire. This will shut down the complete system if the pump fails. The pan switch should be wired this way also, so they can both be in series with each other.
Posted on May 25, 2011
  • dryearwood May 26, 2011
    The pan switch is no problem for it is two wire, but the high level shut off wires and the float switch wire have been wired together for 12 years operating properly and producing a single wire and I do not understand how a single wire can be put in series. Still puzzled.
Overflow pipe
In most cases, they do not come with a overflow valve, That is a addon that most companies install when they do the install. They can be purchased from most ac suppliers I recommend the SS-2 or SS-1 safety overflow switch, comes with two wires you can tie into your low voltage wiring to your thermostat.
Hope this helps.
Jul 06, 2013 | Goodman Manufacturing Goodman CAPF1824C6...
Hello, im trying to install a booster fan to add more CFM to one room, my question is what is the best way to wire it up so it goes on and off with the furnaces blower motor? thnaks in advance
The "best" way would depend on you system's layout. If the booster fan is not too far away from the blower motor, you could drop pair of low voltage wires from the booster fan to the blower motor relay switch (coil side) along the duct. Connect the low voltage wires to a relay switch for the booster fan (again... coil side). This way, when the thermostat closes the circuit and engages the blower motor relay switch, it would also engage the booster fan relay switch; thus turning on the booster fan. If the booster fan is close to the thermostat, you would connect the low voltage wires to the thermostat instead. Either way, the wiring is essentially the same.
Aug 05, 2011 | Heating & Cooling
I have the c8866 cycle timer I want hook it up to a low presure pump switch. from the panel I have 10- 2 w/ ground this is 220. My question is. Is the ground my nuetral and if so is this also ground? the...
You have 220Volts (same as 240V), then that circuit does not need a neutral.
All household single phase voltage requires two wires to complete the circuit.
With 120V, you have 1 hot wire and 1 neutral wire.
With 240, you have 2 hot wires, and these hot wires are called 'out of phase' since each comes from separate side of breaker box.
Notice that your 220V 10-2 wire goes back to a double breaker. This double breaker snaps over two different busbars. The breaker pulls 2 out of phase 120Volt lines, and when testing voltage across those two out of phase 120V wires, you get 240V potential.
The ground wire is redundant safety in both 120 or 240 Volt circuits, and is not necessary for either 120 or 240 to operate.
http://waterheatertimer.org/240-v-water-heater-circuit.html#120-240
Apr 15, 2011 | Intermatic C8865 Timer, 1HR CYCLE TIME, 30...
No deisel getting through so will not give hot water
The fuel solenoid is controlled by two switches, the flow switch or pressure switch and the thermostat or snap switch. These switches are wired in series which makes them relatively easy to test.
First pull the electromagnet off the fuel solenoid valve on the fuel pump hooked to the side of the burner. Slide a screwdriver inside of the magnet and turn on the burner. It should magnetize. If it doesn't you need to pull the electromagnet from the wire it is hooked to and test for voltage. The voltage will be either 12V-24V, 110V or 220V depending on the solenoid you have. It will tell you what voltage it should be on the side of the solenoid. If you have voltage you need to replace the electromagnet. If you do not you will need to follow the wires back into the electrical box.
The next switch you will test is the snap switch or thermostat. It is wired in series to the solenoid wires. If you have a thermostat test for voltage on the outgoing side. If you have voltage the wiring to the solenoid is bad. If you don't have voltage, test for voltage on the incoming line to the thermostat. If you have voltage your thermostat is bad. If not you need to test the flow switch. The process is the same if you have a snap switch however instead of testing the terminals you will test each wire going into the switch for voltage.
Next you will test the flow switch. First test for voltage coming out of the reed switch on the flow switch. If you have voltage your wiring to the thermostat is bad. If you do not have voltage then test the incoming side of the flow switch. If you have voltage your reed switch and or flow switch are bad. If you don't you will need to test your main power switch as the problem lies in the system sending voltage to the burner circuit.
This is a complete test of the burner circuit and should help you isolate your problem. If it doesn't feel free to contact me at 800.247.8103 and I will help you trouble shoot further.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Mar 09, 2011 | Karcher Garden
How do I wire the safety overflow switch to my furnace humidifier thermostat? I have a Little giant VCMA-20ULT and a Aprilaire 700.
The overflow switch needs to be wired in a manner that interrupts the HOT (black?) side of the wires going to the water inlet valve or it's circuit.
Feb 28, 2011 | Little Giant VCMA-20ULT 80 GPH - Automatic...
Water is dripping rapidly from my VCMA 15ULS. Do I need to replace it? Or can it be fixed?
I assume the unit is overflowing, because the pump is not running. Check th hose connection and be sure the line bringing the water into the pump is inserted in the opening. Can you hear the motor run? You can remove the top, and be sure the float switch is working and that the pump inlet is not clogged with debris. Sometimes you'll get mold and dirt mixed with water clogging the inlet. If the motor doesn't run, and the switch works, then it probably isn't worth fixing as you can buy these from 35.00--50.00
Jul 04, 2010 | Little Giant VCMA-15ULST, 1/50 HP, 65 GPH...
Little Giant Condensate pump runs for 1 sec when res not full
Is there a check valve in the pumps discharge fitting? If there is it may be stuck open or broken allowing some of the water to return to the reservoir once the pump shuts off which then may lead to the brief cycle between full cycles.
If there is not one, install one to keep any water from backing back into the reservoir and that should stop the short runs.
Aug 06, 2009 | Plumbing
LOW VOLTAGE ON A FEW WIRES WILL NOT RUN
Many wires on most autos will have low voltage around 5 volts is common for wires going to most sensors. What you described with the fuel pump sounds normal for this truck. I would guess the fuel pump is not your problem cant say for shore with out any more info. I am unclear as to what the symptoms are, is the truck not starting. What led you to check the fuel pump. Did you check for spark.
Jan 10, 2009 | 1991 GMC S-15 Jimmy
A/c unit won't come on
if unit uses a manual switch to turn on suspect it faulty if a circuit board is used the main fuse blew out.
May 17, 2008 | Intertherm Heating & Cooling
Little Giant VCMA-15ULT 1/60 HP 3/8" Condensate Pump Model# 554411 with 20' Logo
203 people viewed this question
Top Little Giant Electrical Supplies Experts
 Kenneth
Kenneth
Mike
ken skalski
Are you a Little Giant Electrical Supply Expert? Answer questions, earn points and help others
